JonathanMilbank
Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
Posted: Wed Mar 29, 2017 1:18 am Post subject: Forward white light choice UK |
I'm thinking of installing a forward facing white light for conspicuity purposes and would appreciate your advice. It seems that LED is what I need to meet the requirements of low current drain, brightness and preferably small frontal area. It will never need to provide illumination for landing in poor daylight or dusk.
While I'm sure that the choice is great in the USA, I'd rather not have to import and therefore I'm addressing my question to the UK pilot fraternity (and sorority as well).
A friend advises me to avoid those LED lights which state that they can cope with a wide voltage range, due to having active electronics which might cause a little radio interference. Perhaps another factor is that the light should be a "softer" white than the extreme whiteness of some LEDs which might be less visible on a bright day. Maybe!
Roland
Posted: Wed Mar 29, 2017 2:45 am Post subject: Re: Forward white light choice UK |
Jonathan,
I had a forward facing ACL installed in my XS-cowl just below the spinner. It costed me 370 Euro and worked for about one year. Replaced it with the same model and that broke after another year for whatever reason (the manufacturer suspected cooling issues, although it had a seperate cooling inlet).
Now I changed to the other extreme and installed a conventional 20 W chinese-made model (4 LED without cooling inlet) for 8 Euro inclusive shipping(!) and this works flawlessly for half a year now - no interferences.
Maybe I had just bad luck with the expensive one - maybe....
That said, I still think, that a forward facing ACL is a nice thing to have from a safety point of view.
Roland
PH-ZTI
XS TG 914
JonathanMilbank
Posted: Wed Mar 29, 2017 3:59 am Post subject: Re: Forward white light choice UK |
Roland, I'm very interested especially at 8 Euros. More details of suppliers please.
Jonathan
JonathanMilbank
Posted: Wed Mar 29, 2017 4:01 am Post subject: Re: Forward white light choice UK |
The other light which would interest me is a replacement for my old Filser glider strobe. Surely after 20 years since it was fitted, both battery and strobe technology have moved on and the gliding world might now be benefitting from brighter flashing equipment which doesn't drain their batteries any quicker. Ideally any replacement should fit the same hole which the Filser occupies on top of my tail fin.
When I was flying professionally I noticed that one of our rival companies saw fit to install strobes which "double-flashed" on the same type of aircraft as I flew. That stood out and caught the eye immensely better than only a single flash.
Roland
JonathanMilbank
Posted: Wed Mar 29, 2017 5:03 am Post subject: Re: Forward white light choice UK |
Many thanks Roland. I admire your enclosed trailer to accommodate a tri-gear Europa. Perhaps I'll modify my old enclosed trailer which was built for a mono-wheel.
Jonathan
graeme bird
Posted: Wed Mar 29, 2017 9:27 am Post subject: Re: Forward white light choice UK |
For UK, there seems to be only one approved MOD to fit a light 13072 (even though others are flying around), I submitted a MOD2 form to fit an LED one (a jeep light)
http://www.ebay.co.uk/itm/2Pcs-10W-Cree-LED-Off-road-Spot-Flash-Head-Light-Lamp-for-Bike-Car-Jeep-12V-32V-/261826855985
Which looks like my MX5 spot lights. However, I have rolled over and proposed to the LAA that it may be easier to do a repeat mod of 13072 than to get approval for a new lamp. There are a couple of others putting head light Mods through, one with lights in the outrigger brackets and another with the light embedded in the GRP under the air inlet. They are both at the MOD3 stage I believe.
I have also put a MOD2 form in for own designed combined resin potted LED nav/stobe lights in the same form factor as the airworld strobes and a tail light on the tail wheel cross member. I havent heard anything back on these for a while.
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
JonathanMilbank
Posted: Wed Mar 29, 2017 10:29 am Post subject: Re: Forward white light choice UK |
Goodness! It hadn't even occurred to me that mod approval would be needed for this. To my way of thinking, such a small addition should be between the owner and his inspector. Ah well, I'll just give up that ambition and hope that other aircraft see my strobe light in good time.
In fact because my strobe's on top of the fin it should be visible in all azimuth directions, therefore the head lamp is superfluous provided that the strobe's bright enough, which mine isn't! So now the search is on to find the brightest and best value for money fin-mounted strobe. The Microavionics MM031 has my interest at the moment, but I'm open to other suggestions.
Many thanks.
Remi Guerner
Posted: Wed Mar 29, 2017 11:58 pm Post subject: Re: Forward white light choice UK |
Jonathan,
As most general aviation products come from the US and importing is very easy, deciding not to buy from them is a strange idea!
I have installed a Kuntzleman LTR LED light (US made, sorry!) in the lower starboard air intake (which is useful for 914 installations only). I turn it on all the time from take off to landing as long as I am below about 3000 ft AGL. Cost 234 US dollars. Works fine after 3 1/2 years and 300 flying hours. No interference.
Remi
290.76 KB |
12522 Time(s) |
JonathanMilbank
Posted: Thu Mar 30, 2017 1:15 am Post subject: Re: Forward white light choice UK |
Remi, once again I stand guilty of a lack of joined-up thinking when I started this thread. Actually what I really need is to improve conspicuity from all directions and a forward facing light isn't really necessary because I already have a strobe light on top of the fin. But it's a 20 year old low-powered Filser intended for gliders, which is how they described it.
So now my objective is to find a reasonably priced modern strobe which throws out bursts of intense flashes. Thanks anyway for your advice.
dpark748(at)icloud.com Guest
Posted: Fri Mar 31, 2017 7:18 am Post subject: Forward white light choice UK |
Roland,
Is your trailer home built from plans? Or from comercial builder?
Dave G-LDVO
Dave Park
Roland
Posted: Sun Apr 02, 2017 9:12 pm Post subject: Re: Forward white light choice UK |
Hello Dave,
my trailer is commercial built http://www.anschau.de/english-version/
Roland
PH-ZTI
XS TG 914
