heater fan wiring
kenryan
PostPosted: Tue Mar 28, 2017 12:00 pm    Post subject: heater fan wiring Reply with quote
I am building a cabin heater (Rotax) and the fan draws 4.3 amps. I have read that on startup it can draw 12 amps. It is a permanent magnet type fan. It looks like a large computer fan on steroids.
I have decided to use my "defrost" circuit, which was originally going to power a couple of small, low draw computer fans. I wired it with 20 AWG wire.
I would like to use the existing wiring for the fan, but I might need to put in a 12 amp fuse, and am a little concerned that might be too much for the 20 AWG wire.
The wire from the bus to the switch is about 18 inches and the wire from the switch to the fan is about 24 inches.
I guess I have two questions:
1. What would be the largest fuse I could use and still be safe?
2. If I test it and it doesn't blow a 5 amp (or 7.5 amp) fuse, do you think it would be likely to continue working indefinitely?
Ken
 Filesize:  727.05 KB
 Viewed:  20159 Time(s)
PostPosted: Tue Mar 28, 2017 1:11 pm    Post subject: Re: heater fan wiring Reply with quote
I would try a 7.5 amp fuse. I usually prefer fuses. But for a motor,
a circuit breaker will not nuisance trip as easily. Some day the motor
bearings will freeze up. If fused higher and the motor draws 12 amps continuously,
the wire will then get hot enough to boil water.
How hard is it to replace the wire? Sometimes it is easier to go ahead
and do it the hard way to start with. When faced with a decision like this,
I ask myself, what is best in the long run, not what is easiest right now.
Joe Gores
ceengland7(at)gmail.com
PostPosted: Tue Mar 28, 2017 1:58 pm    Post subject: heater fan wiring Reply with quote
AWG wire.
Ken
Somebody on another forum recently posted a link to Cooper Bussman ATC
format circuit breakers. The time-to-trip vs overload percentage looks a
lot like traditional circuit breakers, instead of the near-instant trip
of an ATC fuse. Might be worth a look. The longer time constant should
allow for momentary startup loads.
http://www.cooperindustries.com/content/dam/public/bussmann/Transportation/Resources/catalog_pages/BUS_Tns_227_ATC_CB.pdf
http://www.cooperindustries.com/content/dam/public/bussmann/Transportation/Resources/catalog_pages/circuit-protection/bus-cbt-ds-series-22x-circuit-breakers.pdf
That's a really sturdy looking fan box. Smile What's it weigh?
kenryan
PostPosted: Tue Mar 28, 2017 2:36 pm    Post subject: heater fan wiring Reply with quote
Charlie, it weighs 3 pounds 14 ounces, but that does not include hoses or fittings (or the additional fluid required). I estimate 5.5 pounds all told, 6 pounds maximum. The stuff that I will be removing (heater box, scat tubing, cables, etc. weighs about 3 pounds, so 2 or 3 pounds heavier the airplane will be.
To me this is a no-brainer, as I look upon the typical method of scavenging off the exhaust as a kind of Sword of Damocles, always poised to kill you. Plus, I live in Alaska! Lots of cold weather flying, so a better heater is really appreciated.
So anyway, I got my speed control this morning. I hooked it all up and tried to blow the 5 amp fuse. I was not successful.
I am thinking that maybe the information that I read about 12 amp startup draw is bogus. As I said, this is a permanent magnet type motor, very similar to what I have seen on computers. Does this type of motor really have large startup loads?
So now that I have tried and failed to blow the 5 amp fuse, unless this list implores me to rewire for safety, I will stick with the 20 AWG.
I'm pretty sure Bob has said that there is no problem using a 7.5 amp fuse with 20 AWG, right? If I did blow the 5 amp, I would still have the 7.5 amp fuse option.
Ken
On Tue, Mar 28, 2017 at 1:57 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
Ken
Somebody on another forum recently posted a link to Cooper Bussman ATC format circuit breakers. The time-to-trip vs overload percentage looks a lot like traditional circuit breakers, instead of the near-instant trip of an ATC fuse. Might be worth a look. The longer time constant should allow for momentary startup loads.
kenryan
PostPosted: Tue Mar 28, 2017 2:45 pm    Post subject: heater fan wiring Reply with quote
That's a good point Joe. Update: I got it all hooked up (temporary) and it works great with a 5 amp fuse, so I think I will be okay. If necessary I will go to 7.5 amp, but I won't go higher than that. Do these type motors really have large startup current requirements? Would it make any difference that I am running it through a PWM speed control? Like I said, I am not blowing a 5 amp fuse.
On Tue, Mar 28, 2017 at 1:12 PM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=467764#467764
PostPosted: Tue Mar 28, 2017 4:01 pm    Post subject: Re: heater fan wiring Reply with quote
Ken, Some fan speed controllers put out a steady DC for several milliseconds to start a motor, then change over to PWM. The motor might very well draw 12 amps to start, but only for a fraction of a second, too short of a time to heat up and blow a fuse. It looks like you have answered your own question by testing. As long as it works, it is good enough.
Thanks for those links Charlie. I never knew ATC circuit breakers existed.
Joe Gores
Eric Page
PostPosted: Tue Mar 28, 2017 4:11 pm    Post subject: heater fan wiring Reply with quote
Does your speed control have a power on/off switch separate from the speed knob, or do you twist the speed knob from the "off" detent to the lowest speed setting, and up from there?
If the former, then it's possible to start the fan in its highest draw setting (PWM at 100%). If the latter, it will always turn on at the lowest PWM value, so inrush should be well controlled (unless you slam the knob to max speed, I suppose).
In either case, the speed control may have inrush limiting as part of its design. The best way to check this issue for sure is a DC clamp meter or series-connected ammeter with max-hold function.
Eric
On Mar 28, 2017, at 3:39 PM, Ken Ryan <keninalaska(at)gmail.com> wrote:
[SNIP] Do these type motors really have large startup current requirements? Would it make any difference that I am running it through a PWM speed control? Like I said, I am not blowing a 5 amp fuse.
arcticarrow(at)gmail.com
PostPosted: Tue Mar 28, 2017 5:01 pm    Post subject: heater fan wiring Reply with quote
This question is about USB charging ports and radio interference/noise.
I’ve check out a couple charging ports that plug into the cigarette lighter and they both produce noise when charging. Both purchased from pilot shops. Also tried a couple direct wire USB charging ports from marine/auto applications with the same result. Is there any way to filter or shield these devices to reduce or eliminate the radio noise. The noise can’t be eliminated with squelch adjustment. I’m using a hand held icom radio for the test, it doesn’t see to make any difference if the radio is 12 to 36 “ away from the charging port.
Bernie
Joe Gores
http://forums.matronics.com/viewtopic.php?p=467771#467771
kjashton(at)vnet.net
PostPosted: Tue Mar 28, 2017 5:02 pm    Post subject: heater fan wiring Reply with quote
I understand the desire for a good heater but running lean of peak minimizes the carbon monoxide
On Mar 28, 2017, at 6:32 PM, Ken Ryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
Ken
Ken
clr(at)redingaviation.com
PostPosted: Tue Mar 28, 2017 5:51 pm    Post subject: heater fan wiring Reply with quote
On Mar 28, 2017, at 8:58 PM, Kent or Jackie Ashton <kjashton(at)vnet.net (kjashton(at)vnet.net)> wrote:
Ken
--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> On 3/28/2017 2:49 PM, Ken Ryan wrote:
I am building a cabin heater (Rotax) and the fan draws 4.3 amps. I have read that on startup it can draw 12 amps. It is a permanent magnet type fan. It looks like a large computer fan on steroids. I have decided to use my "defrost" circuit, which was originally going to power a couple of small, low draw computer fans. I wired it with 20 AWG wire. I would like to use the existing wiring for the fan, but I might need to put in a 12 amp fuse, and am a little concerned that might be too much for the 20 AWG wire. The wire from the bus to the switch is about 18 inches and the wire from the switch to the fan is about 24 inches. I guess I have two questions: 1. What would be the largest fuse I could use and still be safe? 2. If I test it and it doesn't blow a 5 amp (or 7.5 amp) fuse, do you think it would be likely to continue working indefinitely? Thanks, Ken
Somebody on another forum recently posted a link to Cooper Bussman ATC format circuit breakers. The time-to-trip vs overload percentage looks a lot like traditional circuit breakers, instead of the near-instant trip of an ATC fuse. Might be worth a look. The longer time constant should allow for momentary startup loads. http://www.cooperindustries.com/content/dam/public/bussmann/Transportation/Resources/catalog_pages/BUS_Tns_227_ATC_CB.pdf http://www.cooperindustries.com/content/dam/public/bussmann/Transportation/Resources/catalog_pages/circuit-protection/bus-cbt-ds-series-22x-circuit-breakers.pdf That's a really sturdy looking fan box. Smile What's it weigh? Charlie ==================================== - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List ==================================== FORUMS - eferrer" target="_blank">http://forums.matronics.com ==================================== WIKI - errer" target="_blank">http://wiki.matronics.com ==================================== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ====================================
kenryan
PostPosted: Wed Mar 29, 2017 8:54 am    Post subject: heater fan wiring Reply with quote
Thanks Charlie. If I ever start blowing fuses I will try these. Good to know that they exist.
Sent from my Android. Sorry Steve.
On Mar 28, 2017 2:10 PM, "Charlie England" <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Ken
stephencliverichards(at)g
PostPosted: Wed Mar 29, 2017 12:08 pm    Post subject: heater fan wiring Reply with quote
Bernie Not sure why you have put a question about USB chargers under this thread but I understand Anker products are noise free I have used a USB power drive 2 and can hold a hand held radio near this with no problem
Clive
Sent: ‎29/‎03/‎2017 02:09
Subject: Re: Re: heater fan wiring
--> AeroElectric-List message posted by: Bernie Willis <arcticarrow(at)gmail.com>
Bernie
Joe Gores
sp; - MATRONICS WEB F - NEW MATRONICS LIST WIKI -
_= p; &=======
PostPosted: Wed Mar 29, 2017 12:35 pm    Post subject: heater fan wiring Reply with quote
Also, try SteinAir. They sell one that's supposed to be noise free.
Clive
Subject: Re: AeroElectric-List: Re: heater fan wiring
--> AeroElectric-List message posted by: Bernie Willis <arcticarrow(at)gmail.com> (arcticarrow(at)gmail.com)
Bernie
> On Mar 28, 2017, at 4:01 PM, user9253 <fransew(at)gmail.com> (fransew(at)gmail.com) wrote:
> --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com> (fransew(at)gmail.com)
> Joe Gores
_=            p;            &=======
jim(at)PoogieBearRanch.co
PostPosted: Wed Mar 29, 2017 2:17 pm    Post subject: heater fan wiring Reply with quote
+1 on the Anker "aux port" chargers. They also make great USB and
Lightning cables, including 6-foot lengths.
Jim Parker
PostPosted: Wed Mar 29, 2017 4:27 pm    Post subject: heater fan wiring Reply with quote
This will be for milliseconds during spin-up . . . leave
the 20AWG in place and go with 10A fuse . . . it's probably
going to be fine.
Actually, 20AWG is pretty 'cool' at 12A. See
http://tinyurl.com/lk2tmhx
If a 22AWG at 20A just barely passes 100C in free
air . . . a 20AWG at 12A is pretty safe.
A 10A fuse would be fine . . .
kenryan
PostPosted: Wed Mar 29, 2017 4:50 pm    Post subject: heater fan wiring Reply with quote
Great! Thanks.
On Mar 29, 2017 4:35 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
