jmsears(at)adelphia.net Guest
Posted: Sat Jul 08, 2006 4:13 am Post subject: The TRUTH about MOGAS (very long) |
| Quote: | > I am not ANTI Mogas or anyone who uses it, but
I would like present some of the FACTS, negatives
or CON's, in addition to all the PRO drinking the
cool-aid comments for MOGAS. <<
George and I have had some discussion on this subject
off line; and, I thought the topic was over with. I guess
he doesn't feel that way. Actually, George has thought
seriously about using mogas in an airplane. However,
George is like many on this list who have a nice sum of
cash to work with. With that, he doesn't have the
need, or desire, to try alternative things to help keep
his aviation expenses down. George also has an
engineering background; so, he's not dumber than a
box of rocks, like some of us out here.
| Quote: | > I appreciate the passion and support some have
for MOgas. Hey 5,10 and 15 years of successfully
operation is not bad. I appreciate the sense of
humor as well.<<
Where we lack in education, those of us who've used
auto gas with FAA's blessings do have a background
of experience. Mine has lasted for about 20 years and
about 2000 hours of flying time with auto gas. Some
of the others have been flying with auto gas for just as
long, if not longer. I don't consider my good fortune
with auto gas to be an exception. It's most likely more
the rule.
Now, this is where George, in his good meaning way,
has messed up a little. He's got most things right; but,
he's just like us in that some of his information is not
correct. I don't know all the facts, either. I'm no
engineer and am no expert. I do read a lot and have
the experience with mogas.
| Quote: | > besides the OCTANE molecule (distilled petroleum).
Gas has 200 of chemicals in it, some are good
for aviation some not, <<
This can be true. In the past, we've been alerted about
some of those chemicals. However, I think it was found
that some of those chemicals were harmful to the
environment and were disallowed. MTBE seems to be
one of the chemicals that is mentioned often. However,
it is approved for our usage. What works in a car should
be OK for the airplane, in most cases. Of course, that's
just speculation on my part; but, I don't think the fuel
manufacturers want autos to fail any more than we want
our aircraft engines to fail. I certainly don't want my fuel
delivery system to melt down, my engine to detonate,
and my engine to melt down, whether it be my auto or
my airplane.
| Quote: | Auto gas has lower vapor pressure, which means it
is more susceptible to vapor lock.
Sorry, Goerge; but, you still have that one backwards,
which helps to debunk the rest of what you say. Don't
worry, I have had a hard time keeping this one straight,
myself.
| Quote: | Auto gas, even premium does NOT have the same
octane as 100LL Avgas by quite a bit.
I've got to admit he's right. However, most engines
we use today, and certainly most engines we use for
our RVs don't require the use of 100LL. At least,
that's what I've read several times on this list and
in publications.
| Quote: | Low octane can cause detonation, and uncontrolled
burning of fuel which can lead to severe engine
damage.
If it's too low for the engine.
| Quote: | > In the past Av gas came in grades of 80-87; 91-98,
100-130 and 115-145. That has given way to the
ubiquitous 100/100LL<<
One can still sometimes find the 80/87 fuel; but, it's
pretty rare. However, what happened to those engines
that ran on 115/145 fuel? Did those go away; or, did
they get derated to run on 100LL? Surely the FAA
didn't say it's OK to run them on 100LL without some
sort of investigation into it. Can anyone answer that?
Isn't that sort of what we're doing? We're going to
a lower antiknock fuel that can be used instead of
one that is forced on us because nobody makes the
other, anymore?
| Quote: | Why two numbers? The low number is the lean octane
rating and the higher number is rich octane rating.
There are four ways to measure fuel for octane:
Automotive Research, Automotive Motor,
Aviation Lean and Aviation Rich.
There is more information in the archives about this.
It's interesting reading material for those who are
interested.
| Quote: | Auto gas has one rating and is average of lean and
rich rating and there are two methods as listed
above.
Yes. Check the archives for more info.
| Quote: | > Aviation gas lean is about equal to automotive motor
octane.100LL avgas if sold at the car pump would be
105. Premium 91 octane MOgas sold as Avgas
would be about equiv to 86UL. <<
I won't dispute this because I'd have to look it up;
but, I do remember that the octane rating is lower
for avgas, as he suggests. I think 87 antiknack is
translated to 82UL avgas.
| Quote: | STC for Mogas was when 80/86 went a way and
the low compression engines ran terrible on the
default gas grade 100/100LL.
And can be damaged by the lead content.
| Quote: | Despite the LL (Low Lead) designation,
there's a lot of lead in 100LL.
About ten times as much as leaded mogas
and four times as much as 80 avgas, per
Petersen's STC information.
| Quote: | > Therefor low compression engines
designed to run on low octane fuel did not
need or work well on leaded fuel. Lead boost
octane. That was the beginning of STC's for
automotive unleaded (UL) fuels for aircraft as
a substitute for low lead/UL 80 octane.<<
This may be a true statement. Many were
already using the mogas illegally, anyway. The
STC just made it legal.
| Quote: | Just because the FAA approves STC's is not mean
much in a high compression homebuilt.
Yep; but, I think many of us already realize that there
is a limit as to what engines can use it. However, the
FAA, which George doesn't trust to have the sense
to know what the experts know, thinks that over 90%
of the GA fleet can run on a lower octane fuel, if we
were to lose 100LL. I'm hoping that the FAA has
its own set of experts to work with. I'm betting
they're working with the fuel and engine manufacturers
on this. Surely, they have the right experts.
| Quote: | > Lycomings come in to flavors, which are certified
for 80 octane and have a compression ratio about
7.2:1CR or have about 8:50:1CR and are certified
for 100/100LL gas, or the old 91/96 Avgas grade. <<
According to my engine list, the engines are 7.5:1 and
8.5:1. I'm no expert on the subject, though.
| Quote: | > If you buy the Super gas at the mini-mart and it
said 92 octane it is only worth about 87 octane.
We assume you test it for ethanol and alcohol
every time of course. <<
I think it has to maintain what's stated on the pump
for a period of time. That means it's most likely
the octane that's stated, or very close to it. It
certainly won't be that much below what's stated
on the pump unless George really means the 87
is the avgas equivalent.
| Quote: | > Can you run your 91/96 octane Lyc on it? Well that
is subject to debate, but it does not fly in my plane.
I guess you can reduce the timing advance a little
as a precaution?<<
And this is where we differ. George won't use it in
his airplane; but, I might. It depends on what engine
I have.
| Quote: | Lycoming strongly recommends NOT using MOGAS.
As I told George off line, Lycoming is not going to stick
its neck out because its lawyers are dead against it. To
cover their asses, they'll stick with certified fuels in their
certified engines. Of course, the same company is
being left behind by companies like Superior and ECI
who aren't as afraid as Lycoming. Superior and ECI
tend to cater more to us and are willing to try new
things. Lycoming may end up finding itself without a
customer base, if it continues listening to lawyers
instead of the fastest growing segment of GA.
| Quote: | > Lycoming does know about auto gas and in fact
makes a very low compression O360 for flying in
third world countries to run on low grade fuel. <<
I'm betting that's the 167hp version with the 7.5:1
compression ratio. I've thought about building one
of those up for myself. With that, I'd have a lot
more hp than my current 150 hp engine and could
still run my engine on 87 antiknock fuel.
| Quote: | Unfortunately most 320's and 360's have 8:50:1CR
and need the 91/96 (100LL) gas.
I have a new car that requires 91, or better, antiknock
fuel. However, I read the fine print and found that it
will run on 87 antiknock fuel. There would be some
power reduction, though. I may be wrong; but, I'm
betting Lycoming has done the same thing. They've
given themselves a nice margin for error in their
fuel requirements. That's why it's been found that
we can actually run them on lower octane fuels with
no adverse effects. Of course, this is speculation on
my part.
| Quote: | > If you are willing to test, haul and store your
own auto gas and run your engine on less than the
recommended octane, than OK, do that. If you have
a low compression engine than auto gas makes more
sense. <<
Which many of us are doing.
| Quote: | You may want to look into reducing your timing and
all the other things
For those with very high compression ratios, and some
who have the lower compression ratios and want to
do it that way, having automatic retardation is the cat's
meow and may be the way of the future for us to get
away from 100LL, altogether.
| Quote: | >.I mentioned about keeping the
fuel cool, that where somewhat ridiculed by the
MOgas experts. I would do everything I could to
assure no loss of power due to vapor lock.<<
I don't know who ridiculed George; but, it was not I
I've flown three airplanes extensively on auto gas. Not
one of them had a fuel return system. Since I don't
consider firesleeve a good insulator in normal operation,
I don't have my fuel system insulated. I do have a couple
of blast tubes for the RV; but, my prior two aircraft did
not have them. All three have worked well with auto gas.
If I were going to use a FI engine, I'd most likely install
a fuel return system to make me more comfortable with
it. However, I've not had that much trouble with vapor
locking and would opt to stay with the KISS method
on my carb engines. That works for me. You guys may
want to go with fuel returns. That's what makes this
whole thing so neat. We can do what is right for each
of us.
| Quote: | >If you have a 7:1CR engine than it is safer from an
octane stand point, as long as it does not have the
alcohol and ethanol. (However ethanol does increase
the octane rating, see below).<<
I believe ethanol is a form of alcohol; but, I might be
wrong on that. I do think the 7.5: 1 engines have the
advantage, though. When one does the formula to
convert the 87 antiknock to avgas, it's the 82UL
we've seen in the past, if memory serves me. Since
7.5:1 engines are designed for 80, I don't worry
about the octane, as much.
| Quote: | > If you get a load of ethanol gas you run the risk
of water contamination since it absorbs water. Once
airborne it cools the water comes out of the fuel
and water contamination result in loss of power. <<
This could be a real problem in cold weather. Here
is one little rub in that, though. What about all the
cars that run on it? Why don't they have frozen fuel
lines, stopped up tanks, and stopped up fuel filters
from using it? Anyone ever given that one a thought?
It may not be that much of a problem, in that sense.
I wonder how cold it would have to be for the
separation to happen. I'm more concerned about
what it can do to components in the system. As
others have stated, that may not be as much of a
problem, anymore.
| Quote: | Carb ice is more likely with ethanol (alcohol).
I won't dispute that because I don't know. I do
know that my Lycoming engines have rarely, if
ever, showed symptoms of icing up. The C172
I owned had a Continental in it. Boy, that thing
would ice up, in a heart beat. I'm not saying it
won't happen; but, I'm betting it would be a
minor issue. I'd be more concerned about the
power output from alcohol. From what I'm
reading, it takes a lot more alcohol to produce
what gas produces.
| Quote: | >That is why it is important to test your auto gas.
Also ethanol is not compatible with the rubber
and gaskets used in aircraft and they will swell,
which has caused aircraft engines to stop in the
past. <<
I must admit I haven't been real good about testing
my fuels. I have tested it, in the past; but, I'm not
one to do it with every fuel purchase. Some will
critisize me for my lack of action; but, I tend to
buy gas where alcohol is not in the fuel. If I lived
near a large city, I'd test it regularly.
| Quote: | > These are facts. If you do go auto fuel please please
ask lots of questions of those who are experts in the
topic. I think we have a few on this list (seriously <<
I don't claim to have all the answers; but, I do try to
help. Our archives are full of good information on
the use of auto gas.
| Quote: | > I am not an expert but than I don't have to jump of a
bridge to know it might hurt when I hit the water. I
know if your engine stops while flying in a plane it
can be a bad thing. MOgas is NOT as good as
AVgas. The debate is it good enough. May be. <<
Actually, I think mogas is better than avgas. I have
less problems with mogas than I do with avgas. I've
had cylinders off my engines for problems not relating
to mogas usage and have yet to find symptoms of
detonation,etc. On the contrary, I've found the engine
to be clean on the inside. No lead. Every time I fill
my plane up with 100LL, I get the fouled plugs and
lead related bad run ups.
| Quote: | What I know about auto gas is enough to discourage
me.
George is lucky in that he has a job that pays very well.
Making his decision was easy for him. However, there
are those of us who are grass roots enthusiasts who do
not have large incomes. We have to think differently
and search out alternatives that work for us. Either is
just fine. As best I know, I'm probably the only one
at our airport who regularly uses autogas for fuel. I'm
probably one of the few who is retired, as well. The
rest are well paid folks, with most having businesses
of their own. They complain about the cost of 100LL;
but, they continue to use avgas because they can
afford it. I can't. Mogas works for me.
| Quote: | > Ethanol does help octane so if you can get some
"sub grade" fuel before the distribution puts in
the additives, like ethanol you can expect a 5% hit
on octane. So basic fuel planned for 91 octane
with ethanol is really 89 octane without the ethanol.
This is like 84 aviation. To get "sub grade" you need
to get it at the distribution terminal before they add
the ethanol.<<
Let me try to remember. If octane increases, that
slows the burn more to make it more uniform. That
translates to more power. Why is it that ethanol is
apt to give less power and require more fuel to do
the same thing as ethanol free fuels? Just curious.
I would think ethanol is more of an environmental
issue additive than for octane boosting. That's why
one will find it more around big cities where smog
is a problem. What say you experts?
| Quote: | > 84 octane is not enough for higher compression 91/96
engines. If you have a 80 octane O320 140/150HP Lyc,
than by all means go for it. <<
I'm sorry, George, I'm getting lost in your octane ratings.
They're jumping all over the map. However, if one is
using a 140/150/167/235 hp Lyc, one is safe to use
87 antiknock fuel. As for the 8.5:1, Superior stands
behind their engines using 91-92 antiknock mogas. I
suggest that they would not do that unless their engines
can be run safely on it. If I were to buy a new engine
for my RV, I'd look very seriously at buying a new
engine from an engine manufacturer that supports our
needs. It appears that Superior, and maybe ECI,
does. Lycoming would be my last choice, even
though their engine will most likely do as well as
the Superior engine on the same fuels.
| Quote: | > Some debate about reducing timing for the high
compression engines.<<
At some point, this will probably have to be done.
| Quote: | > Lycoming is testing UL blends and the gas companies
are working on the 95UL as a 100/100LL replacement. <<
Most of our engines can run on it.
| Quote: | >Remember there are more high compression than low
compression engines. Also the real fire breathing high
end piston engines, turbo charged and so on NEED
the high end gas, only make up 30% of the fleet but
use 70% of the gas. So all you C65 & C85 engine
Piper Cubs are stuck using the 95 octane but with
the UL it should be OK.<<
I'm betting a lot of cub drivers are pouring in auto gas.
Those engines will run nicely on it. They aren't stuck
with avgas. The ones in trouble are the ones with the
super hot engines.
| Quote: | > IF I HAD an 80 octane engine AND the gas prices
kept going up I would consider auto gas it. (THERE I
SAID IT, ARE YOU HAPPY....)<<
Not really. Gas is always going to go up. One has to
get to where the cost is prohibitive. It hasn't gotten
there for most of us. When it does, many of us will
just get out of aviation. Look at the other countries
where gas is way more than we pay. There is very
little general aviation. We'll see the same thing, here.
It won't have to go up much more to leave this
retiree behind. There is already talk around our
airport by some who think it's about time to get out.
The fuel is still cheap enough that we can sell our
airplanes at reasonable prices. If it goes up much
more, and aviation declines, we won't be able to
give them away. Oh, yeah. Aviation is declining,
it seems. That's why AOPA is asking us to help
out. The average Joe can't afford start in aviation,
anymore. Some of us may fall by the wayside, as
well. It will trully become a rich man's hobby. The
use of auto gas may not matter, then.
| Quote: | > As I said for the real world guy $400-$800 is about
what you can expect to save per year. Some of the
guys who live where fuel is cheap and ethanol is not
forced down their throat, good for them. If you have a
High compression engine and ethanol free fuel is hard
to find at the pump than not so good.<<
This is a fact of life. Not everyone can partake in its
use; but, many of us can and do.
| Quote: | > For the convenience of pulling up to the airport pump,
filling with very high octane fuel, with very high vapor
pressure and knowing there's no bad chemicals in it
with out having to test it, is worth it to me.<<
Yep. Isn't it nice you can have it your way? The key
is doing what makes you feel comfortable. Many of
us feel very comfortable pouring auto gas into our
tanks. It works for us.
| Quote: | >To each his own, I'll never say never but at some
point I just will not fly as much or at all, sadly. <<
That is a fate that all of us face. I see my end in
aviation coming too fast.
Sorry for the long response; but, I feel it's necessary
to defend what I believe in. Use of mogas in airplanes
isn't for everyone; but, giving false information isn't
going to help, either. George means well; but, he's
like the rest of us. He's learning. However, one
must realize that the old tales about how mogas will
cause us to crash have been disproved. Now, some
engine manufacturers are backing its use. That's
good enough for me!
Jim Sears in KY
ebundy(at)speedyquick.net Guest
Posted: Sat Jul 08, 2006 7:08 am Post subject: The TRUTH about MOGAS (very long) |
As someone who long ago made up my mind not to use Mogas (for a variety of
reasons) I still found this discussion interesting.
I personally don't think the *potential* risks outweigh the monetary
savings. I don't know if I fit into the "nice sum of cash" camp, but I know
that I DO give up other things that I would like (such as an automobile
built after 1988) in order to fly an RV.
One thing I haven't seen mentioned (although I confess I have skipped a lot
of this topic) is that a few years ago Avgas was twice as expensive as Mogas
($2 vs. $1). Now the same $1 differential exists, but at $4 vs. $3 Mogas is
"only" 25% cheaper.
Sorry, but with all the expenses of airplane ownership, a 25% savings on
fuel is not worth ANY possibility of Mogas problems. Not to mention the
hassle factor of lugging your own airplane fuel around. Yuck.
Ed Bundy
| Quote: | George is like many on this list who have a nice sum of
rocketbob(at)gmail.com Guest
Posted: Sat Jul 08, 2006 8:44 am Post subject: The TRUTH about MOGAS (very long) |
I don't think anyone can claim to be an expert on whether or not mogas is suitable for their airplanes unless they try it and see if it works in their airplane. Forget the numbers (compression ratio, octane, vapor pressure, etc.) For me 25% 100LL and 75% 87 octane sans alcohol mix works for me and I can't tell a bit of difference when I'm fueled up with 100% 100LL. My lines are firesleeved, no problem in the summer temperatures. It works for me and as far as I care those are the facts, everything else is conjecture. I've borescoped the cylinders to look for any signs of detonation, and there are none. My oil analysis reports always come back good.
I have 9:1 pistons in the rocket, will likely go 50/50 on the fuel mixture, but have to see what works best thru some trial and error.
Bob Japundza
RV-6 flying 700+hours, F1 under const.
ronlee(at)pcisys.net Guest
Posted: Sat Jul 08, 2006 9:14 am Post subject: The TRUTH about MOGAS (very long) |
| Quote: | Actually, I think mogas is better than avgas. I have
to mogas usage and have yet to find symptoms of detonation,etc. On the
Don't take this the wrong way but that may be operating
technique. I use 100LL and fly more than most folks and
I don't have fouled plug issues on every fillup. I think that
I have had three cases in 900 hours and most were probably
because I failed to lean the engine after startup. I would
prefer a fuel with little or no lead because it does require
periodic maintenance to clean the plugs.
Ron Lee
Posted: Sat Jul 08, 2006 9:24 am Post subject: The TRUTH about MOGAS (very long) |
| Quote: | As someone who long ago made up my mind not to use
Mogas (for a variety of > reasons) I still found this
These discussions can be very interesting, especially if there
is a distinct polarity between those who use auto gas and
those who don't.
| Quote: | I personally don't think the *potential* risks outweigh the
monetary savings. I don't know if I fit into the "nice sum
of cash" camp, but I know that I DO give up other things
that I would like (such as an automobile built after 1988)
Each of us less fortunate folks has to give up something to
get to fly. I had to give the idea of having a big fancy house
and the mortgage payments that go with it. As for the
potential risks, I've found very few. In fact, I feel good
enough about using auto gas that I've taken up over 300
kids in the Young Eagles program with auto gas in the
tanks. I've not lost one, yet. I've had more problems with
100LL and its fouling tendencies.
We all get so hooked on the risks involved that we forget
the risk we take by just driving to the airport. I'm not going
to belittle anyone for not wanting to try mogas; but, I would
not tell you that it's safe knowing it's not. I'm not the most
brave/macho pilot in the world; so, I'm not fond of taking
risks, either. I trusted in those who did the testing to be
right and gave it a try. I've not regretted it, yet.
| Quote: | One thing I haven't seen mentioned (although I confess
I have skipped a lot > of this topic) is that a few years
ago Avgas was twice as expensive as Mogas ($2 vs. $1).
is "only" 25% cheaper.
That's a neat way to look at it; but, it's more than that. There
is still that $1+ price differential that keeps that savings way
up there. Also keep in mind that our incomes haven't been
inflated at the same rate as gas; so, that savings that we were
talking about a couple of years ago is still substantial to us,
today. As a note of interest, my retirement income will never
increase; so, a dollar saved is a dollar earned.
| Quote: | Sorry, but with all the expenses of airplane ownership,
a 25% savings on fuel is not worth ANY possibility of
Mogas problems. Not to mention the hassle factor of
Ed is comfortable with his decision and has his reasons;
but, there aren't that many risks. I've had engine problems
with my aircraft, just as any aricraft owner does. I've had
to replace cylinders because the tubes in the sump loosened
up. I've had to overhaul an engine because it had sat for
a while before I bought it. The cam gave it up. I had to
replace a cylinder because the oil ring stuck. Have you
noticed I've said nothing about detonation, yet? There
hasn't been any that we've found. In each case, the
problem was something totally unrelated to the type of
fuel I was using. That's in about 2000 hours of flying on
auto gas.
Gang, I'm not here to recruit anyone from joining me
unless you want to. If you want to, there are those of
us who have chosen to try auto gas and have been
very successful at it. To me, it's worth the hassle. When
it no longer is, I'm sure I'll be priced out of aviation. At
that point, it will be moot.
Jim in KY
do not archive.
Posted: Sat Jul 08, 2006 9:33 am Post subject: The TRUTH about MOGAS (very long) |
| Quote: | I don't think anyone can claim to be an expert on
That's kinda how I see it. Those who haven't tried it,
and are listening to others who are dead set against it,
may be missing out on something that not only saves
money from fuel purchase. It could reduce costs in
operation from lead deposit problems, as well.
| Quote: | Forget the numbers (compression ratio, octane,
100LL.
Bob is using a little more conservative mix than I do;
but, I've found that having a 25% mix of 100LL all
but eliminates vapor lock problems on those days
when I'm doing quick turnarounds for Yound Eagles.
Like Bob, I can't tell the difference between the
performance of 100LL and the 87 antiknock from
around the corner. In fact, my little RV's engine ran
just fine on it, this morning.
| Quote: | My lines are firesleeved, no problem in the summer
I like this man's attitude.
| Quote: | I've borescoped the cylinders to look for any signs
Same here on both counts. In fact, I get better oil
analysis reports on auto gas.
| Quote: | I have 9:1 pistons in the rocket, will likely go 50/50
That kind of testing should be report to us, Bob. I'd
like to know how well the higher compression ratio
engines do with it. I'm confident with the 8.5:1 engines
because Superior has stepped up to back it.
So, you see, here is another happy RVer who is using
auto gas with no problems. We aren't alone, fellas.
Jim in KY
Posted: Sun Jul 09, 2006 4:54 pm Post subject: The TRUTH about MOGAS (very long) |
Here's one for the "you're gonna die because you use autogas" folks:
Today's OAT: 87 deg F.
This morning filled up with three six-gallon jugs of 87 octane gas (not 93, not 91, but 87 octane), pulled the airplane up to the gas pump on our airpark and added 6 gallons of 100LL. 75/25 mix. Flew to a flyin, ate lunch then did a balloon pop contest and a spot landing contest. Had a passenger with me. Flew around the flyin for about an hour, in the pattern mixed in with several spam cans, super cubs, a T-6, PT-19, all in the pattern at 100-120mph (didn't win the spot landing contest but got two out of three balloons for a tie for first place). After we did that climbed out to 6500 and headed home, and had some fun with some cumulus. Hottest CHT hit 400 on the climb to 6500. After leveling off it settled back down to 365. Oil temp was 202. In other words, some ideal conditions for vapor lock.
I'm here to tell you that I survived yet another hot but fun day using autogas, with not even a hint vapor lock and no signs of overheating.
Bob Japundza
RV-6 flying, F1 under const.
Hopperdhh(at)aol.com Guest
Posted: Wed Jul 12, 2006 5:56 am Post subject: The TRUTH about MOGAS (very long) |
Here is something I didn't know until recently. When the engine's bore is increased from 4" to 5", the octane required increases by 10 units. That's from "The Internal Combustion Engine in Theory and Practice -- Volume II." by Charles Taylor. (Thanks Jim Baker for recommending this book.) Most car engine's bores are well under 4" and the Lyc 360 is 5 1/8". From the same reference, our 8.7:1 compression ratio looks like more than 10:1 if the bore were the size of a car engine's.
Those using auto gas should keep this in mind when thinking that the low compression ratios of aircraft engines should allow us to use low octane gas. Your engine may be closer to detonation than you realize.
Dan Hopper
RV-7A
chaztuna(at)adelphia.net Guest
Posted: Wed Jul 12, 2006 6:39 am Post subject: The TRUTH about MOGAS (very long) |
Dan
Thanks for the info. I'm curious however. What is the date of publication of this tome? Also, where might one find a copy?
Charlie Kuss
Dan Hopper
RV-7A
Posted: Wed Jul 12, 2006 8:22 am Post subject: The TRUTH about MOGAS (very long) |
Charlie,
"The Internal Combustion Engine in Theory and Practice -- Volume II." by Charles Taylor was published in 1968 by the Massachusetts Institute of Technology. I found a copy on Ebay.
Dan
In a message dated 7/12/2006 10:41:24 A.M. Eastern Daylight Time, chaztuna(at)adelphia.net writes:
| Quote: | Dan
Charlie Kuss
Dan Hopper
RV-7A
tedd(at)vansairforce.org Guest
Posted: Wed Jul 12, 2006 8:56 am Post subject: The TRUTH about MOGAS (very long) |
| Quote: | Here is something I didn't know until recently. When the engine's bore is
Dan:
This is a rule of thumb that is meant to compare similarly designed engines of
different displacements, such as the O-320 and O-360. It would be a mistake to
apply it to significantly different engine designs without taking into
consideration other factors. For example, combustion chamber shape is equally
significant, so that a smaller-bore combustion chamber can require higher
octane than a larger-bore chamber, at the same CR, if its shape is more
conducive to detonation. One can't simply conclude that one engine requires
higher octane than another simply because its bore is larger.
Tedd McHenry
Surrey, BC
dsvs(at)comcast.net Guest
Posted: Wed Jul 12, 2006 8:58 am Post subject: The TRUTH about MOGAS (very long) |
Also available from amazon.com
-------------- Original message ----------------------
Charlie,
Dan
Dan
Charlie Kuss
were
Dan Hopper
RV-7A
Posted: Wed Jul 12, 2006 3:10 pm Post subject: The TRUTH about MOGAS (very long) |
Ted,
Yes, lots of things determine the octane required. Combustion chamber shape is certainly one which is very significant. In fact the open chamber like our Lycomings, in general, are the least resistant to detonation according to this book.
All other things being equal, it IS fair to say that a larger bore engine requires higher octane fuel. This is not a rule of thumb, but was determined by a lot of testing. There are many graphs in this book which show the data from these tests. The book admits that there was (is?) still much to learn about the causes and cures of detonation. I'm not sure how much we've learned since then, but I think anything written in 1968 still applies to Lycomings!
Dan Hopper
RV-7A
In a message dated 7/12/2006 12:58:46 P.M. Eastern Daylight Time, tedd(at)vansairforce.org writes:
| Quote: | --> RV-List message posted by: Tedd McHenry <tedd(at)vansairforce.org>
Dan:
Tedd McHenry
Surrey, =========================es Day
--> ================================================== - NEW MATRONICS LIST WIKI -
_-= sp; -> =========================p; - List Contribution Web Site ==================================================
flyrv6(at)bryantechnology Guest
Posted: Thu Jul 13, 2006 8:10 am Post subject: The TRUTH about MOGAS (very long) |
"This is a rule of thumb that is meant to compare similarly designed engines of
different displacements,"
Ted, you hit the nail more on the head with the term "displacements". Dan actually said bore size and I am thinking either he meant different or the book was a little skewed based on it's age. Of course bore size, chamber shape, stroke, piston composition, piston shape, and squish all play an active role in this. I don't know much about the lycomings, but even with a relatively high compression ratio, you can achieve pretty good dynamics by optimizing the squish and picking the right piston for the application. Lycomings may not apply since the availability of products is more limited than typical auto engines.
ex Auto Machine Shop Owner but did not stay in a Holiday Inn Express last night
RV-6
[i]----
