Firefly progress
Richard Pike
PostPosted: Wed Mar 15, 2017 2:04 pm    Post subject: Firefly progress Reply with quote
Since things are sort of slow on the list right now I thought I would do an update on the Firefly.
Got the windshield on today, the muffler and prop went on last week, and the wiring is done. David did most of the wiring; should have let him do all of it since he is much neater and better at it than I am.
Was planing to bring the wings home today but it is just too cold. Maybe Monday. Then start to put it all together. (Original Firestar wings, FSII wing struts, and a FF fuselage - what a mongrel!)
Yes, I know I am using blue urethane tubing between the carb and the fuel pump. That is so we can see if we are getting any fuel to the carb. Fortunately it is convenient to change every year. And those are the only conditions under which you should use that junk!
 Filesize:  230.22 KB
 Viewed:  22130 Time(s)
 Filesize:  212.06 KB
 Filesize:  208.24 KB
 Filesize:  234.09 KB
 Filesize:  247.41 KB
 Filesize:  231.48 KB
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
williamtsullivan(at)att.n
PostPosted: Wed Mar 15, 2017 2:21 pm    Post subject: Firefly progress Reply with quote
Looking really good!
Bill Sullivan
Windsor Locks, Ct.
victorbravo(at)sbcglobal.
PostPosted: Wed Mar 15, 2017 2:26 pm    Post subject: Firefly progress Reply with quote
Everyone knows that a mongrel can often be better than a pure-bred ! Excellent progress, keep plugging away... summer is coming soon Smile
Yours is exactly the same Bahama Blue color as my FS2, and I removed a lot of that same blue plastic tubing from my plane when I got it.
Bill Berle
On Wed, 3/15/17, Richard Pike <thegreybaron(at)charter.net> wrote:
Subject: Firefly progress
Date: Wednesday, March 15, 2017, 3:05 PM
"Richard Pike" <thegreybaron(at)charter.net>
Richard Pike
Kingsport, TN 3TN0
Forgiving is tough. Being forgiven is wonderful.
http://forums.matronics.com/viewtopic.php?p=467361#467361
http://forums.matronics.com//files/p1050736_medium_728.jpg
http://forums.matronics.com//files/p1050737_medium_900.jpg
http://forums.matronics.com//files/p1050738_medium_213.jpg
http://forums.matronics.com//files/p1050739_medium_209.jpg
http://forums.matronics.com//files/p1050740_medium_784.jpg
http://forums.matronics.com//files/p1050741_medium_200.jpg
Forum -
   - MATRONICS WEB FORUMS -
MATRONICS LIST WIKI -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
Herbgh(at)nctc.com
PostPosted: Wed Mar 15, 2017 2:27 pm    Post subject: Firefly progress Reply with quote
Bro Pike
Is envy a sin?? Smile Herb
Richard Pike
Kingsport, TN 3TN0
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny."
Aristotle
Richard Pike
PostPosted: Wed Mar 15, 2017 3:06 pm    Post subject: Re: Firefly progress Reply with quote
[quote="Herbgh(at)nctc.com"]Bro Pike - Is envy a sin?? Smile Herb [quote]
Dude - You gave me the front end of the cage and the engine mount tube, and you showed me how to make the bicycle brakes. If envy was the problem you could have just kept them! <Grin>
Richard Pike
Kingsport, TN 3TN0
Herbgh(at)nctc.com
PostPosted: Wed Mar 15, 2017 3:16 pm    Post subject: Firefly progress Reply with quote
Well Richard....very happy to see what you and your bud have
accomplished... so ...yes some envy comes into play...for I viewed the
parts as a mish mush not to ever be turned into a flying device...So
congratulations...I am happy to have been a small part of the process...
Herb
Richard Pike
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=467367#467367
Aristotle
stuart(at)harnerfarm.net
PostPosted: Wed Mar 15, 2017 7:16 pm    Post subject: Firefly progress Reply with quote
Looking REALLY good!
What did you do to assure the screws will not come loose on the terminal
block mounted to the engine? Loctite or something?
You are going to have FUN with that plane!
S
japowell
PostPosted: Thu Mar 16, 2017 1:51 am    Post subject: Re: Firefly progress Reply with quote
Looking good Richard. Can't wait to see it all together.
Jim P
WAR EAGLE
Richard Pike
PostPosted: Thu Mar 16, 2017 4:55 am    Post subject: Re: Firefly progress Reply with quote
S
Hm.. Glad you asked. Since they have been there since Bucky & Carl built it back in 1985, it hadn't occurred to me to wonder what is keeping them in. I'll check it out today. Thanks.
Richard Pike
Kingsport, TN 3TN0
Mcabbage
PostPosted: Thu Mar 16, 2017 9:12 am    Post subject: Re: Firefly progress Reply with quote
Looks great thank you for sharing
2007 Firestar 2 503 N203SD
Moster 185 Flattop PPG/Sky K2 Paraglider
Trike Buggy Soaring Trike & Northwing Stratus XP
Richard Pike
PostPosted: Thu Mar 23, 2017 5:18 pm    Post subject: Re: Firefly progress Reply with quote
Great day to be outside working on an airplane with your bud.
Replaced the one bent wing strut attachment tang yesterday, today we rolled it out and trial fitted the wings. Mostly pretty good, one alignment problem, tomorrow I can call Bryan at the factory and promise to send him money, and he will invent and send me the part I need to fix it.
Drug out the scales, maybe we might just barely be able to make Part 103. Right now it looks too close to call. Anybody got a good Hirth F-33 with redrive and electric start you want to trade for a good 447 with gearbox & prop?
Here is what a Firefly looks like when you build it out of 3 separate airplanes:
 Filesize:  304 KB
 Viewed:  21976 Time(s)
 Filesize:  315.94 KB
 Filesize:  303.51 KB
 Filesize:  270.42 KB
 Filesize:  280.87 KB
Richard Pike
Kingsport, TN 3TN0
japowell
PostPosted: Fri Mar 24, 2017 1:21 am    Post subject: Re: Firefly progress Reply with quote
Looking good Richard. What did it weigh? I'm headed to Kolb this afternoon to pick up the parts for my project. Hopefully I can start assembling and fitting everything together next week.
Question...what is the position of the horizontal stabilizer to the boom tube? Drawing says 3/8" above tube. What is yours?
Jim P
WAR EAGLE
PostPosted: Fri Mar 24, 2017 4:57 am    Post subject: Firefly progress Reply with quote
Looking very good. Looks about like what I ended up with on my original 5 rib Firestar. No photos- I had to let it go. But you are right about weight- everything has to be trimmed and weighed. And mine had a main tube that was one foot shorter than standard. Speaking of which, has anyone heard from Jack Hart? He is the current master of that.
Bill Sullivan
Richard Pike
PostPosted: Fri Mar 24, 2017 7:51 am    Post subject: Re: Firefly progress Reply with quote
It weighs 274 on a very uncooperative and unreliable bathroom scale. Looks like we will be relying on that hand deployed parachute to make weight, even if it is no good for anything else. And the tail is 3/8" of an inch above the boom, because it is a recycled FSII tail and boom.
Richard Pike
Kingsport, TN 3TN0
japowell
PostPosted: Sat Mar 25, 2017 4:54 pm    Post subject: Re: Firefly progress Reply with quote
Thanks Richard. From the pics, it looked more than 3/8". Picked up the new nose cone, tail brackets and fuel tanks today. Bryan and Helen were great to visit with. Saw some nice planes and ask a lot of questions, hopefully I can remember all of the answers.
Jim P
WAR EAGLE
Richard Pike
PostPosted: Sat Apr 01, 2017 2:19 pm    Post subject: Re: Firefly progress Reply with quote
Now it is officially a FireFly. With a Shout Out to Andy who did it!
 Filesize:  177.36 KB
 Viewed:  21750 Time(s)
 Filesize:  188.09 KB
 Filesize:  140.38 KB
 Filesize:  311.12 KB
Richard Pike
Kingsport, TN 3TN0
George Alexander
PostPosted: Sat Apr 01, 2017 3:26 pm    Post subject: Re: Firefly progress Reply with quote
Very creative nose art Bro Pike!
George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net
japowell
PostPosted: Sat Apr 01, 2017 4:42 pm    Post subject: Re: Firefly progress Reply with quote
I like. That really set off the color. Caught a lot of 'lightning bugs' in my day. When will you test fly it? Waiting on flight report eagerly.
Enjoy,
Jim P.
Jim P
WAR EAGLE
lcottrell
PostPosted: Sat Apr 01, 2017 5:22 pm    Post subject: Firefly progress Reply with quote
Did you put VG's on it yet? I will be interested in the number with
that wing and the VG's
Larry
Richard Pike
PostPosted: Sat Apr 01, 2017 6:43 pm    Post subject: Re: Firefly progress Reply with quote
Larry
The plan is to fly it and see how it does. Assuming that all is good, then we pull the wings back off and recover them with Oratex. The wings have been closed up since they were originally built in 1985, and they need to be opened up and examined.
Assuming that all is good and we are planning to keep this bird, they get recovered in Oratex and then the VG's go on. After we have flown it w/o them. Will be interesting to see how it does with fresh covering, and then again with vg's to boot.
Richard Pike
Kingsport, TN 3TN0
