Smoke Switch
BTLYak
PostPosted: Tue Mar 21, 2017 11:17 am    Post subject: Smoke Switch Reply with quote
OK,
We are installing smoke on the Yak 52. Where does everyone have their ON/OFF switch located?
Recommendations?
"Battle Yak"
tigerbabaluba
PostPosted: Tue Mar 21, 2017 12:12 pm    Post subject: Re: Smoke Switch Reply with quote
I use the approach commuter switch located on the glareshield panel Smile but the best solution is to insert a new switch on the upper side of throttle Twisted Evil
Tigerbabaluba from Portugal
hkgibby(at)yahoo.com
PostPosted: Tue Mar 21, 2017 12:31 pm    Post subject: Smoke Switch Reply with quote
Hello- for arming the 24 v pump I used an un-used switch on the main switch panel. Have a radio shack push once for on, push again for off rigged into the old ICS portion of the throttle for a little "HOTAS". Included a relay mounted behind seat to cushion it all electrically and have a green light under the glare shield when activated to give me a visual cue. I like the set up but lots of ways to skin a cat. Thanks to electrical wizard Chris Dilley for his design. See pics below.
Hoot
On Mar 21, 2017, at 3:17 PM, BTLYak <btlyak1(at)gmail.com> wrote:
OK,
Recommendations?
&quot;Battle Yak&quot;
http://forums.matronics.com/viewtopic.php?p=467503#467503
 Filesize:  129.36 KB
 Viewed:  4968 Time(s)
 Filesize:  76.92 KB
 Filesize:  84.79 KB
 Filesize:  91.66 KB
