JL2A
Posted: Wed Mar 15, 2017 2:46 am Post subject: unlocks not always locking... |
Calling the CJ brains trust! Strange problem has just manifested itself, CJ6:
Gear handle in DOWN on the ground. Get airborne, gear handle to UP
Get three red lights, gear handle NEUTRAL.
They all fall down. Sometimes just one, sometimes two.
To fix, I selected handle NEUTRAL while gear is down and locked, then selected DOWN for 3 seconds, then UP. This seemed to give the gear a little more momentum and they get up & locked no problems
Can't replicate it every time, it only sometimes does it... the uplocks don't seem to lock when this happens, even if flying with gear handle in the UP position & three reds, anything over 1.5 G pulls the gear out enough to extinguish the 'gear up' red lights, meaning the locks have rotated enough to press the microswitch, but not far enough to lock.
Needless to say no aerobatics until they are locked...
Have had engineer check uplocks, hook position/angle etc. No audible air leaks.
My only explanation is that when selecting UP, a bit of air is leaking into the DOWN lines at the same time and activating the unlock actuators a little, preventing the uplocks from locking...
Strange one, any other ideas? Would this be possible? I don't have a great grasp of where all the check valves etc are located and for what reason in the gear system.
Anatole
Posted: Wed Mar 15, 2017 3:17 am Post subject: unlocks not always locking... |
Why do you put the gear handle in neutral in the first place?
Do you know what happens when you put the gear selector in neutral?
Dennis
To: yak-list(at)matronics.com
Sent: Wednesday, March 15, 2017 6:46 AM
Subject: unlocks not always locking...
--> Yak-List message posted by: "JL2A" <info(at)flyingwarbirds.com.au (info(at)flyingwarbirds.com.au)>
Can't replicate it every time, it only sometimes does it... the unlocks don't seem to lock when this happens, even if flying with gear handle in the UP position, anything over 1.5 G pulls the gear out enough to extinguish the 'gear up' red lights, meaning they are being held by actuators only.
Have had engineer check unlocks, hook position/angle etc. No audible air leaks.
My only explanation is that when selecting UP, a bit of air is leaking into the DOWN lines at the same time and activating the unlock actuators a little, preventing the unlocks from locking...
Anatole
http://forums.matronics.com/viewtopic.pcs.com/Navigator?Yak-List" target="_blank">http://www.matronics.com/Navigsp; - MATRONICS WEB FORUMS -
= --> http://www.matronic====================
jlpartington(at)reagan.co Guest
Posted: Wed Mar 15, 2017 3:26 am Post subject: unlocks not always locking... |
sounds like all the air is not venting out of the down side
cjpilot710(at)aol.com Guest
Posted: Wed Mar 15, 2017 4:56 am Post subject: unlocks not always locking... |
Some CJ6s have no up locks at all. For 22 years I've operated mine without them because it came from China like that. One simply keeps the gear handle "up" the entire flight.
If you analyze it, it simplifies the system which means less places to leak air. Also if you lose air pressure for whatever reason, you gear will start to fall down - which is what you want to start happening anyway. You then simply lock it place with emergency air.
Leaving the gear handle up all the time does not hurt anything. Some folks think this wears out the seals, but seals only get wear while moving, not holding the pressure. Some think it also causes ware on the compressor but the compressor is always "working" and system pressure is regulated by the regulator anyway.
Your up locks mostly likely need cleaning. Very simple to and they are not complicated at all.
Jim "Pappy" Goolsby
Sent from my iPad from some where on The 3rd rock from the Sun.
On Mar 15, 2017, at 06:24, jlpartington(at)reagan.com (jlpartington(at)reagan.com) wrote:
dougsappllc(at)gmail.com Guest
Posted: Wed Mar 15, 2017 7:40 am Post subject: unlocks not always locking... |
I agree with Dennis, up is gear up-- down is gear down, leave it alone, do not return it to neutral in flight.
Do you have up locks?? A few CJs did not, they relied on air pressure to hold the gear up.Â
Doug
On Wed, Mar 15, 2017 at 4:15 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
| Quote: | Why do you put the gear handle in neutral in the first place?
Dennis
From: JL2A <info(at)flyingwarbirds.com.au (info(at)flyingwarbirds.com.au)>
Anatole
http://forums.matronics.com/viewtopic.pcs.com/Navigator?Yak-List" target="_blank">http://www.matronics.com/Navigsp; Â Â Â Â Â Â - MATRONICS WEB FORUMS -
=Â --> http://www.matronic====================
Posted: Wed Mar 15, 2017 9:22 am Post subject: unlocks not always locking... |
PS. Also the System is not building enough pressure. the pressure needs to be increased. Do this at the regulator.
On Mar 15, 2017, at 07:53, James Goolsby <cjpilot710(at)aol.com (cjpilot710(at)aol.com)> wrote:
[quote]Some CJ6s have no up locks at all. For 22 years I've operated mine without them because it came from China like that. One simply keeps the gear handle "up" the entire flight.
Jim "Pappy" Goolsby
wlannon(at)shaw.ca Guest
Posted: Wed Mar 15, 2017 11:02 am Post subject: unlocks not always locking... |
Oh yes! Gear uplocks; a bit of history here.
Even though the manual does specify the neutral position after gear up I agree with other posters here and always leave it in the up position. There is no logical reason to do otherwise.
All four of the CJ’s I imported in 1993 were, like Pappy’s, without uplocks. They were early production (1965 to 1969) but clearly came from the factory with
uplocks installed and were subsequently removed in squadron service. There had to be a reason for that action even though it did not result in deletion of uplocks in later production.
The CJ uplock design has a built-in Achilles Heel. If any one of the three fails to unlock you will be doing a gear up landing (hopefully you will put the other two back up first!). At gear down selection that action ports air from the Normal (or Emergency) side of each uplock emergency valve to each uplock release valve and to the gear down side of the actuator. If the release valve fails to operate that gear will remain up regardless of the down pressure in the actuator.
Here I digress a bit! The early P51 used the same basic Bendix designed undercarriage as the Harvard (and later T6) aircraft. Wonderful, fool proof, free-fall to down lock gear! The uplock was released mechanically with movement of the gear handle to down.
But with time, wear, spring failure (and vibration?) it was possible for the handle to go to down on it’s own. Just an annoyance for the Harvard/T6 but fatal for at least one Mustang. Very high speed pass and pull up, gear falls and wing fails.
The fix was a simple over-center spring bungee added to the handle linkage. Still (IMHO) the best gear ever!
I installed complete new uplock systems on two of those CJ’s including mine. Two of the new owners were happy without uplocks but I found it annoying to have red lights flashing every time I pulled some G’s.
To those with uplocks installed I highly recommend a periodic removal and inspection of the release valves and emerg. valves.
Walt
Sent: Wednesday, March 15, 2017 8:36 AM
Subject: Re: unlocks not always locking...
Doug
Dennis
Anatole
Virus-free. www.avast.com
JL2A
Posted: Wed Mar 15, 2017 1:09 pm Post subject: Re: unlocks not always locking... |
I thought this might devolve into a handle position thread!
In the OP I did say that with the handle in UP that the aerobatic G forces pull the gear out enough for the uplock microswitch to turn off.
i.e.. I fly with the handle in UP
Which is why it was interesting to find that when reverting to the gear handle neutral when flying method that the uplocks were occasionally not locking, even though microswitches were clicking.
Regarding the presence of uplocks, not being an engineering expert, I figured they put the uplocks were there so there was less stress on the actuator and retraction assembly while pulling up to 6 Gs? Seems to make sense in a mechanical-sympathy sort of way.
Thanks Jim, I will give them a good clean and see what happens, however seeing as it randomly happens to any of the three it seems unlikely.
Any merit in the air on the down-side theory?
PS we also checked the gear doors for contact etc. nothing has shifted
JL2A
Posted: Wed Mar 15, 2017 1:18 pm Post subject: Re: unlocks not always locking... |
Dennis
The air vents out the gear handle, actuators have atmospheric pressure only in them, and the gear rests on the uplocks?
Ernie
Posted: Wed Mar 15, 2017 1:36 pm Post subject: unlocks not always locking... |
If you keep pulling 6 Gs in a CJ, your wings are going to be in the UP position.
On Wed, Mar 15, 2017 at 5:30 PM JL2A <info(at)flyingwarbirds.com.au (info(at)flyingwarbirds.com.au)> wrote:
| Quote: | | --> Yak-List message posted by: "JL2A" <info(at)flyingwarbirds.com.au (info(at)flyingwarbirds.com.au)> > Why do you put the gear handle in neutral in the first place? > Do you know what happens when you put the gear selector in neutral? > > Dennis > > The air vents out the gear handle, actuators have atmospheric pressure only in them, and the gear rests on the uplocks? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=467359#467359 =========== ss="gmail_msg"> _msg"> il_msg"> mail_msg"> List" rel="noreferrer" class="gmail_msg" target="_blank">http://www.matronics.com/Navigator?Yak-List =========== FORUMS - il_msg"> eferrer" class="gmail_msg" target="_blank">http://forums.matronics.com =========== WIKI - "> errer" class="gmail_msg" target="_blank">http://wiki.matronics.com =========== b Site - Â Â Â Â Â -Matt Dralle, List Admin. rel="noreferrer" class="gmail_msg" target="_blank">http://www.matronics.com/contribution =========== |
JL2A
Posted: Wed Mar 15, 2017 6:54 pm Post subject: Re: unlocks not always locking... |
| Quote: | | If you keep pulling 6 Gs in a CJ, your wings are going to be in the UP position. |
I was talking from a design point of view. The airframe was designed and rated to 6Gs, so the gear system must be stress tested to handle this over the design life too.
We have a 4G soft limit for all our aeros. Don't really see the need for more.
Posted: Thu Mar 16, 2017 8:47 am Post subject: unlocks not always locking... |
While I can understand that the gear lights can come on during positive G maneuvers, that has not happened to me - with these exceptions. Low system pressure (at time I had sprung a leak somewhere) and the most Gs I've ever had to pull is 5 gs. (I can get a sloppy loop from cruise with just 2.5 to 3 gs.) While my acro does not go to the extreme end of the envelope, (I do my little routine never pulling more than 4 gs). I never see red lights AS LONG as I have normal system pressure (50 atmos).
Jim (Pappy) Goolsby
In a message dated 3/15/2017 5:11:54 P.M. Eastern Daylight Time, info(at)flyingwarbirds.com.au writes:
| Quote: | --> Yak-List message posted by: "JL2A" <info(at)flyingwarbirds.com.au>
Thanks Jim, I will give them a good clean and see what happens.
http://forums.matronics.com/viewtopic.php?p=467358#467358========================= e ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - NEW MATRONICS LIST WIKI -_-= - List Contribution Web Site sp; ===================================================
Posted: Thu Mar 16, 2017 9:43 am Post subject: unlocks not always locking... |
The actual reason for gear uplocks is to avoid the scenario of the P51 I
described earlier.
The original CJ manual does not specify a gear or flap limit but rather a
maximum circuit speed of 170 Kph (92 Kts).
In the CJ's earliest days in North America a group called Yakkity Yaks
determined that the gear down/flap down military limits for the NA T6 of
130/109 Kts. would sufffice for the CJ as well.
Any CJ owner who purchased my placard set knows that I thought those numbers
too high and always recommended 110/90 Kts. In later years the Civil
Aviation
Authority in the UK came up with a set of numbers which were almost
identical.
Walt
