Door seals
gengrumpy
PostPosted: Wed Mar 08, 2017 5:50 pm    Post subject: Door seals Reply with quote
I have the stock Van’s door seals on my bird, and they are not starting to fail on me after 10 years.
Have any of you on the list found a good door seal for the -10?
Thanks - grumpy
N184JM
rene(at)felker.com
PostPosted: Wed Mar 08, 2017 6:40 pm    Post subject: Door seals Reply with quote
I used what I think was a piper seal. Just a little square piece of memory foam on the edge of the door. I have been flying since 2008, worked good for me.
I will try to find a reference. It would be best if you could find the material elsewhere like mcmaster carr . The ones I got were certified and cost a lot for what they are.
rene(at)felker.com
PostPosted: Wed Mar 08, 2017 7:01 pm    Post subject: Door seals Reply with quote
https://www.aircraftdoorseals.com/products/rv-experimental/
A little pricy. I attached to the door and not the frame. Right on the edge.
Kellym
PostPosted: Wed Mar 08, 2017 7:51 pm    Post subject: Door seals Reply with quote
I will second that recommendation. Does not require special modification
of door sill, can be made to work with uneven surfaces. Durable on the
doors, not so much if put on the frame.
Kelly McMullen
KCHD
amekler
PostPosted: Thu Mar 09, 2017 3:12 am    Post subject: Door seals Reply with quote
How does it seal at the door hinge?
Alan
[quote] On Mar 8, 2017, at 10:50 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
I will second that recommendation. Does not require special modification of door sill, can be made to work with uneven surfaces. Durable on the doors, not so much if put on the frame.
Kellym
PostPosted: Thu Mar 09, 2017 3:24 am    Post subject: Door seals Reply with quote
You have to make a cover for the hinge to provide a flat sealing
surface. Easily done with scrap fiberglass or aluminum.
Alan
Kelly McMullen
KCHD
amekler
PostPosted: Thu Mar 09, 2017 3:36 am    Post subject: Door seals Reply with quote
Can you send me a photo?
Alan
[quote] On Mar 9, 2017, at 6:24 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
You have to make a cover for the hinge to provide a flat sealing surface. Easily done with scrap fiberglass or aluminum.
> Alan
> Sent from my iPhone
Kellym
PostPosted: Thu Mar 09, 2017 4:42 am    Post subject: Door seals Reply with quote
Will do.
You got me to thinking. I have the door seals on the door for my other
aircraft, but on the RV-10 there was not enough lip available, so I do
have the seal on the frame.
Kelly
Alan
>> Alan
>> Sent from my iPhone
Kelly McMullen
KCHD
gengrumpy
PostPosted: Thu Mar 09, 2017 5:04 am    Post subject: Door seals Reply with quote
Thanks to all.
I, too, would like to see a picture for the hinge area.
How does the seal stick to the door? Their website does not say much about installation and their website shows the seal mounted to the frame, not the door.
grumpy
[quote] On Mar 9, 2017, at 6:40 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
Will do.
You got me to thinking. I have the door seals on the door for my other aircraft, but on the RV-10 there was not enough lip available, so I do have the seal on the frame.
Kelly
> Alan
> Sent from my iPhone
>>> Alan
>>> Sent from my iPhone
Kellym
PostPosted: Thu Mar 09, 2017 5:20 am    Post subject: Door seals Reply with quote
See previous reply, my seal is in fact on the frame. picture attached
On 3/9/2017 6:03 AM, John Miller wrote:
Thanks to all.
grumpy
> Will do.
> Kelly
>> Alan
>> Sent from my iPhone
>>>> Alan
>>>> Sent from my iPhone
 Filesize:  62.22 KB
 Viewed:  18510 Time(s)
Kelly McMullen
KCHD
rene(at)felker.com
PostPosted: Thu Mar 09, 2017 5:54 am    Post subject: Door seals Reply with quote
I will be at the airport tonight......will take a picture.
amekler
PostPosted: Thu Mar 09, 2017 6:04 am    Post subject: Door seals Reply with quote
The picture in their web site shows it on the frame
Alan
[quote] On Mar 9, 2017, at 7:40 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
Will do.
Kelly
> Alan
> Sent from my iPhone
>>> Alan
>>> Sent from my iPhone
carl.froehlich(at)verizon
PostPosted: Thu Mar 09, 2017 7:17 am    Post subject: Door seals Reply with quote
Simple to install and works well. Self adhesive seals from McMaster. Five years of service with no issue.
Carl
 Filesize:  701.51 KB
 Viewed:  18508 Time(s)
tomflysalot
PostPosted: Mon Mar 20, 2017 11:58 am    Post subject: Door seals Reply with quote
I use a door seal like yours on my Lancair ES. 10 years since build,
still functioning well (my decible level inside is equal to or less than
many who are using the inflatible seals). Not to mention, mine costs
less than $20.
Tom
____________________________________________________________
How To Remove Eye Bags & Lip Lines Fast (Watch)
Womans Weekly
http://thirdpartyoffers.juno.com/TGL3141/58d034291da9d342951a7st01vuc
amekler
PostPosted: Sun Mar 26, 2017 8:43 am    Post subject: Door seals Reply with quote
Installed the aircraft door seals on the door last sunday. It took two of use to get the door to close. worse part was getting the silicone adhesive off the door frame. Very slow with a razor blade.
Today took test flight. The door seal compressed and door opens and closes nicely without ant trimming. Seal compresses well.
Only problem is cold air comes in at the top at the hinges. Any ideas hoe wo best block this air flow?
Alan
N668G
less than $20.
Tom
Womans Weekly
Kellym
PostPosted: Sun Mar 26, 2017 12:10 pm    Post subject: Door seals Reply with quote
You have to fabricate a cover over the door hinge at where the door
comes down, so the seal has something to compress against. I used scrap
fiberglass from trimming the window openings. Cut to fit, then bonded
with some super fill.
Alan
N668G
> less than $20.
> Tom
> Womans Weekly
Kelly McMullen
KCHD
