Z-17 battery/ alternator switch
jpoint(at)wi.rr.com
PostPosted: Tue Mar 07, 2017 4:53 am    Post subject: Z-17 battery/ alternator switch Reply with quote
All,
I'm building a simple day/ VFR airplane with Z-17 as the basis for my
electric system. I noticed that the battery/ alternator switch is a
two-throw switch wired as "Off-battery-alternator", presumably to be
able to start on battery power and bring the alternator online once the
engine is running. Other drawings (Z-13/8 for example) use a simple
single-throw switch to bring battery and alternator on together. I've
flown with a Z-13-type system in my RV-6 for 13 years so I have faith in it.
Why the different switch design in Z-17? Is there something about the
PM dynamo alternator that requires it to be off during engine start? Is
it because Z-17 doesn't use a master contactor? Would there be any harm
in starting with the PM alternator online?
Jeff Point
Milwaukee WI
rene(at)felker.com
PostPosted: Tue Mar 07, 2017 5:11 am    Post subject: Z-17 battery/ alternator switch Reply with quote
I always thought that the reason for split switches, etc, was so you could turn off the alternator without turning off the battery. I always start with the alternator on.......just my 2 cents.
PostPosted: Tue Mar 07, 2017 5:46 am    Post subject: Re: Z-17 battery/ alternator switch Reply with quote
Would there be any harm in starting with the PM alternator online?
No, in fact that is common practice and is recommended.
Joe Gores
PostPosted: Tue Mar 07, 2017 8:48 am    Post subject: Z-17 battery/ alternator switch Reply with quote
At 07:46 AM 3/7/2017, you wrote:
> Would there be any harm in starting with the PM alternator online? No, in fact that is common practice and is recommended.
Actually, it's six-of-on, half-dozen-of-the-other.
A bit of history:
The first electrical systems to be installed on aircraft
used generators . . . just like the ones on cars, tractors
and trucks. These were simply shunt wound, DC MOTORS being
PUSHED with mechanical energy into the shaft such that they
became GENERATORS.
They required rather sophisticated regulators that not
only maintained the target bus voltage but limited
output current (to prevent commutator and armature
over-heat) and provided reverse current disconnect
so that a NON rotating generator did not revert to
it's roots as a motor and run the battery down after
the engine stopped. These electro-mechanical analogs
to modern electronics are exceedingly clever creations
of the era.
[img]cid:.0[/img]
Generators were self-exciting (meaning that they would come
on line with a simple input of mechanical energy (engine running)
and flipping the field supply switch to ON. Further, they
would run well without a battery on line.
Modern starter-generators on turbine aircraft retain traits
of their ancestors and they too run well without having a
battery on line.
Hence, aircraft with any form of generator will generally
have BOTH battery master and generator control switches.
Interestingly enough, the Beech Bonanza STILL has independent
BATTERY and ALTERNATOR switches . . . which is another
story.
When we started putting alternators on TC aircraft (mid 60s)
it was discovered that (1) the alternators did not self
excite at ramp idle rpm and (2) voltage regulation dynamics
were not as comfortable as the generators being replaced.
Cessna (and others) were 'upgrading' the panel styles to incorporate
rocker switches.
Cessna approached Carling to supply a split-rocker switch that
would (1) provide battery and alternator control in one device,
(2) allow battery only operations and (3) prevent alternator
only operations.
http://tinyurl.com/zbo3yg6
Nowadays, many if not most alternators will self excite at
less than cruise rpms . . . voltage regulation dynamics
are improved too . . . so it is less problematic to consider
alternator-only ops. Given the inherent reliability of
the artfully maintained battery, there is really no demontrable
value in planning to accommodate alternator only ops . . . but
it is not outside the realm of possibility . . . indeed, the
POH for Bonanzas (and I think Barons) speak to this option.
Now, how about the differences between the single-throw and
three-throw options depicted in the Z-figures?
EITHER approach is perfectly satisfactory. The single throw
switch prevents alternator-only ops while a PULLABLE circuit
breaker offers a means for breaking alternator field supply
for battery-only ops on the ground. The three throw switch
emulates the split-rocker switch functionality and design
goals adopted by the TC aircraft guys . . . a philosophy
that persists to this day.
MYTHBUSTING: In some circles it has been believed and taught
that turning an alternator ON/OFF while the engine is running
is a bad thing . . . puts lots of stresses on shafts, shear
couplings, gear trains, etc. etc. It has also been reputed
to induce radio zapping transients into the electrical system.
In a word . . . HOGWASH.
I've spent hundreds of hours evaluating alternator/battery/
airplane symbiosis in both in the lab and on airplanes. I've
conducted, witnessed and instrumented hundreds of switching
combinations of battery, alternators and system loads under
the full constellation of conditions.
There is no foundation in physics or practice for the admonition
to start the engine with the alternator switch ON. Leaving
it OFF does relive the battery of about 3A of parasitic load
during cranking . . . a trivial concern.
The short answer: Use which ever MASTER DC PWR switch
philosophy floats ur boat. Either will perform as advertised.
 Filesize:  142.7 KB
 Viewed:  12858 Time(s)
stuart(at)stuarthutchison
PostPosted: Tue Mar 07, 2017 3:03 pm    Post subject: Z-17 battery/ alternator switch Reply with quote
Why is it recommended Joe?
Kind Regards, Stu
Joe Gores
http://forums.matronics.com/viewtopic.php?p=466963#466963
PostPosted: Tue Mar 07, 2017 6:11 pm    Post subject: Re: Z-17 battery/ alternator switch Reply with quote
Recommended so that the pilot does not forget to turn it on.
Joe Gores
PostPosted: Wed Mar 08, 2017 3:28 am    Post subject: Z-17 battery/ alternator switch Reply with quote
Thanks Joe.
I’d be interested to know yours and Bob's thoughts on the legitimacy of an article I read in the club house a few years back.
The author explained that aeroplane alternators seem have a higher rate of failure compared to motor vehicle alternators that are also more commonly subjected to mud, water and dust ingress. His reasoning was that in a car the alternator field is isolated during the start sequence (as are the lights and most other power hungry devices that add to the battery load) until the key is released to its normal position. By contrast, when cranking an aeroplane engine with the alternator field excited, the voltage regulator senses a substantial sag in bus voltage and attempts to draw max output from the alternator to fix the problem before the alternator has sufficient RPM to provide the required output. I reasoned that this was why some manufacturers have split or separate alternator switches. Any truth to this concept then?
Cheers, Stu
Joe Gores
http://forums.matronics.com/viewtopic.php?p=466988#466988
jpoint(at)wi.rr.com
PostPosted: Wed Mar 08, 2017 4:55 am    Post subject: Z-17 battery/ alternator switch Reply with quote
Thanks for the detailed answer Bob, that makes a lot of sense. One of
my design goals is to keep the switch position and function as similar
as I can to my other airplane, especially the power and ignition
switches. A single throw it will be.
Jeff Point
PostPosted: Wed Mar 08, 2017 7:33 am    Post subject: Re: Z-17 battery/ alternator switch Reply with quote
Thanks Joe. I’d be interested to know yours and Bob's thoughts on the legitimacy of an article I read in the club house a few years back.
I am no expert on alternators. But it would seem to me that maximum field current for several seconds should not cause premature failure.
Joe Gores
PostPosted: Wed Mar 08, 2017 9:15 am    Post subject: Z-17 battery/ alternator switch Reply with quote
"higher rates of failure" is not very descriptive
of cause and effect. While it's true that some
alternators in aircraft have been problematic,
most of my encounters have been grounded in
design or manufacturing defect. We used to break
a lot of brackets on some installations. Piper's
love affair with the Chrysler 'pancake' alternators
led to short service life on attach brackets. An
alternator I conducted failure analysis on a
few months back had press fit diodes pushed into
oversized holes at odd angles using a hand-tool
as opposed to the recommended hydraulic press.
[img]cid:.0[/img]
The diodes were deprived of good heat sinking and in
some cases, good electrical conductivity.
The last task I mounted in TC aviation concerned alternators
that wouldn't stay on line . . . a problem I'd worked at
least two previous times over 30 years. Focus
of the investigation was on alternators that had
demonstrated problems over the years, but in this case
it was the regulator's o.v. sense system that was
overly sensitive to normal brush noise from this
alternator . . . they struggled for weeks to "filter"
the field leads (with limited success) while in fact,
it was the regulator that needed to be changed out.
At the same time, alternators supplied by B&C (and
no doubt others) have an exceedingly low return
rate.
The hypothesis offered in the article is without
foundation in physics or practice. If the author
went to the lab, he would not be able to reproduce
a failure by duplication of conditions cited in the
hypothesis.
It's all physics. For every failure there IS a
combination of conditions leading up to that failure.
Proper operations of switches by crew are exceedingly
unlikely to be in the chorus of conditions. Joe is
correct, a few seconds of full-field operation is
of no particular hardship on an alternator.
 Filesize:  153 KB
 Viewed:  12815 Time(s)
PostPosted: Thu Mar 09, 2017 4:29 am    Post subject: Z-17 battery/ alternator switch Reply with quote
Thanks Joe & Bob.
I’ve bought lots of parts from B&C, but in this case my PlanePower 70A (internally regulated) also seems very well made, with cooling air intake through the windings, hot air extracted by fans at both front and back ends, plus a ram-air cooling duct directly targeting the potted regulator.
The mounting brackets are very solid too, so hopefully the drive belt is the only part I’ll ever have to replace.
V/R, Stu
On 9 Mar 2017, at 04:12, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
"higher rates of failure" is not very descriptive of cause and effect. While it's true that some alternators in aircraft have been problematic, most of my encounters have been grounded in design or manufacturing defect. We used to break a lot of brackets on some installations. Piper's love affair with the Chrysler 'pancake' alternators led to short service life on attach brackets. An alternator I conducted failure analysis on a few months back had press fit diodes pushed into oversized holes at odd angles using a hand-tool as opposed to the recommended hydraulic press. <8e94c69.jpg> The diodes were deprived of good heat sinking and in some cases, good electrical conductivity. The last task I mounted in TC aviation concerned alternators that wouldn't stay on line . . . a problem I'd worked at least two previous times over 30 years. Focus of the investigation was on alternators that had demonstrated problems over the years, but in this case it was the regulator's o.v. sense system that was overly sensitive to normal brush noise from this alternator . . . they struggled for weeks to "filter" the field leads (with limited success) while in fact, it was the regulator that needed to be changed out. At the same time, alternators supplied by B&C (and no doubt others) have an exceedingly low return rate. The hypothesis offered in the article is without foundation in physics or practice. If the author went to the lab, he would not be able to reproduce a failure by duplication of conditions cited in the hypothesis. It's all physics. For every failure there IS a combination of conditions leading up to that failure. Proper operations of switches by crew are exceedingly unlikely to be in the chorus of conditions. Joe is correct, a few seconds of full-field operation is of no particular hardship on an alternator.
