Position and mounting of EDC-D10A remote compass
jglazener
PostPosted: Sat Feb 25, 2017 11:14 am    Post subject: Position and mounting of EDC-D10A remote compass Reply with quote
Looking for advice on how and where to put the remote compass. I understand the roof behind the doors is the best place, but then the flanges are on the wrong side. Also the fixation needs to be non magnetic and adjustable. Anyone thought of an elegant solution to all that?
Jeroen
http://www.europaowners.org/main.php?g2_itemId=44165
dpark748(at)icloud.com
PostPosted: Sat Feb 25, 2017 11:23 am    Post subject: Position and mounting of EDC-D10A remote compass Reply with quote
This works ok on my panel
Dave Park
Jeroen
http://forums.matronics.com/viewtopic.php?p=466633#466633
 Filesize:  534.2 KB
 Viewed:  7633 Time(s)
Roland
PostPosted: Sat Feb 25, 2017 12:38 pm    Post subject: Re: Position and mounting of EDC-D10A remote compass Reply with quote
Hi Jeroen,
I mounted the Dynon remote compass on a small platform behind the D-panel, using brass screws. That worked well, since it is far away from any magnetic objects.
Groetjes
Roland
PH-ZTI
XS TG 914
christoph.both(at)acadiau
PostPosted: Sat Feb 25, 2017 1:06 pm    Post subject: Position and mounting of EDC-D10A remote compass Reply with quote
I used VELCRO to hold the remote compass. Still there after 400 hrs.
Easy to tweak for Annual.
Christoph Both
#223
Wolfville Nova Scotia, Canada.
On 2017-02-25, 15:14, "owner-europa-list-server(at)matronics.com on behalf of jglazener" <owner-europa-list-server(at)matronics.com on behalf of j.glazener(at)planet.nl> wrote:
Jeroen
John Wighton
PostPosted: Mon Feb 27, 2017 1:00 am    Post subject: Re: Position and mounting of EDC-D10A remote compass Reply with quote
Umm, no sure if l or others have got this wrong. The D10A remote compass is a 'black box' not a card compass. Mine is under the baggage area on the RH side on a custom made plinth.
Unfortunately touring with metal in this area tends to give magnetic variation so its not the best place. Fuel cans, folding chairs and such like do have an effect.
Apart from the above issue, the location proves acceptable and is easy to maintain.
JW
John Wighton
Europa XS trigear G-IPOD
John Wighton
PostPosted: Mon Feb 27, 2017 1:07 am    Post subject: Re: Position and mounting of EDC-D10A remote compass Reply with quote
Attached picture of the installation.
 Filesize:  2.37 MB
 Viewed:  7594 Time(s)
John Wighton
