Solder Station
Goto page Previous  1, 2
nuckollsr(at)cox.net
PostPosted: Sat Jan 14, 2006 9:03 am    Post subject: Solder Station Reply with quote
At 08:55 PM 1/12/2006 -0500, you wrote:
<jschroeder(at)perigee.net>
The ones on EBay are most likely from an enterprising set of folks who buy
them from the big electronics mfg's or repair stations and auction/sell
them on eBay.
The METCAL soldering tools are the acme of soldering tools.
They're only capable of delivering about 30 watts to the tip
but the WHOLE 30 watts gets out there. The tips are temperature
controlled. Tips are easy to change . . .just seconds even
when hot . . . the cold one is ready us use in under a minute.
Tip sizes range from about .2" flats to .015" points. I can
solder a terminal on a 2AWG wire with the big guy and install
.025" pitch surface mount chips with the other one.
RAC has used nothing but METCAL for about 20 years. I dumped
all of the solder stations in my shop about 6 years ago and
went to METCAL's purchased off Ebay.
Whole stations with power supply, wand, tips and wand holder
will be more expensive. Wands take the most beating so I try
to buy orphaned power supplies (picked up one last week for
$40). I like to get new wands from a distributor (typically
$60) and tips off Ebay (1 to $10 each).
This is an excellent way to acquire what is arguably one
of the most versatile soldering systems out there for well
under $200. I have two on the bench, one in my grab-it-and-
run toolkit and I've purchased perhaps another half dozen
for family members. I've had a couple of power supplies go
TU over the years but they're so inexpensive to replace, I
don't bother to repair them. It's not worth the time. The
supply I bought last week is a "spare".
stein(at)steinair.com
PostPosted: Sat Jan 14, 2006 3:12 pm    Post subject: Solder Station Reply with quote
Ditton on the Metcals. That's all we use in our shop as well - and we
learned this from the airline days. The R&E shops at the airlines had these
and we liked them, so we procured some for our own use when I set up my own
shop. They are lightning fast to heat up, will work on everything from hair
thin wires to larger gauges and multiples. After you use one you'll never
go back! Ours too mostly come off of Ebay!
Stein.
johnbright
PostPosted: Sat Feb 18, 2017 6:34 pm    Post subject: Re: Solder Station Reply with quote
Metcal... what model number to look for on eBay... cartridge or tip hand piece?
John Bright, RV-6A
Single battery, wound-field alternator on main bus, MZ-30 PM generator on engine/essential bus.
N1921R links
PostPosted: Sun Feb 19, 2017 9:07 am    Post subject: Solder Station Reply with quote
At 08:34 PM 2/18/2017, you wrote:
--> AeroElectric-List message posted by: "johnbright" <john_s_bright(at)yahoo.com>
There's a new kid on the block . . .
http://tinyurl.com/jfmgep8
My electronics bench is still Metcal but
I've got two Hakko stations on the benches
in the beat-n-bash shop. They are excellent
performers and offer a wide selection of tips.
johnbright
PostPosted: Sun Feb 19, 2017 9:47 am    Post subject: Re: Solder Station Reply with quote
Thanks Bob, I went ahead and bought the Hakko FX888D-23BY your link pointed to. Just under $100.
John Bright, RV-6A
N1921R links
alec(at)alecmyers.com
PostPosted: Sun Feb 19, 2017 4:48 pm    Post subject: Solder Station Reply with quote
Very hard to beat the sheer joy of soldering with the Metcal, and the precision of the Curie-point temperature control system. It's the soldering equivalent of driving a Ferrari or Lamborghini. But boy do you pay for it.
John Bright, RV-6A, at Finish Kit
Continental Titan IOX-360, 8.5:1, vertical sump, SDSEFI EM-5, injectors in heads.
Aeroelectric Z-12.
http://forums.matronics.com/viewtopic.php?p=466434#466434
PostPosted: Sun Feb 19, 2017 5:46 pm    Post subject: Solder Station Reply with quote
My bad - it's not the Curie point. anyone know the physical effect that Metcal irons use?
Aeroelectric Z-12.
PostPosted: Mon Feb 20, 2017 11:08 am    Post subject: Solder Station Reply with quote
At 07:42 PM 2/19/2017, you wrote:
--> AeroElectric-List message posted by: Alec Myers <alec(at)alecmyers.com>
Some form of thermo-sensor at the tip.
The cord out to the tip is multiple
conductors. Replacement heaters
have 4 conductors.
[img]cid:.0[/img]
Hakko is quite possibly the Pacific Rim alternative
to Metcal.
I have two Metcal stations left. I've given away
several . . . but depending on my experience over
the next few years with Hakko, I may very well
not replace any Metcal that goes belly up.
I erred earlier, the second Pacific Rim solder
station I have doesn't have Hakko's name on it . . .
although it appears to incorporate similar
technology.
The #2 tool is a combination soldering and hot-
air station.
http://tinyurl.com/j3qosz5
Don't have alot of hours on it yet . . . but I've
got a surface-mount assembly project coming up
where I'll try it out with attaching parts with
solder paste.
The heat wand has proven useful for heat shrinking
and label removal . . . watch this space . . .
 Filesize:  19.16 KB
 Viewed:  17260 Time(s)
yellowduckduo(at)gmail.co
PostPosted: Mon Feb 20, 2017 11:50 am    Post subject: Solder Station Reply with quote
My Weller solder station uses a magnet attached to the back end of the
solder tip. It loses magnetism at the predefined temperature as it
heats. That cycles the power to the heater. It is often referred to as
the Curie temperature of the magnet according to Wiki. You can change
tips for a different temperature.
https://en.wikipedia.org/wiki/Curie_temperature
Ken
have 4 conductors.
Emacs!
to Metcal.
technology.
air station.
<http://tinyurl.com/j3qosz5> Don't have alot of hours on it yet . . .
but I've
solder paste.
PostPosted: Mon Feb 20, 2017 11:56 am    Post subject: Solder Station Reply with quote
We must have different MetCal soldering irons, then. My handset is connected via an RF connector and a length of heat-resistant coax.The station is a 50Watt 1MHz (I think) RF generator, and the tip selectively absorbs more RF energy as the temperature drops, and yes, it was the Curie point effect that's used.
[img]cid:0BCDED1D-CC43-481D-B301-0A4A496B99F3(at)lan[/img]
The base station and handset is about USD$1k - but, it's a complete pleasure to use, from the tiniest SMD component to soldering ring terminals on 6, 4 or 2 gauge wire - all equally easy.
On 20Feb2017, at 2:05 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:At 07:42 PM 2/19/2017, you wrote:
--> AeroElectric-List message posted by: Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)>My bad - it's not the Curie point. anyone know the physical effect that Metcal irons use?
Some form of thermo-sensor at the tip. The cord out to the tip is multiple conductors. Replacement heaters have 4 conductors.<1bd797ce.jpg> Hakko is quite possibly the Pacific Rim alternative to Metcal. I have two Metcal stations left. I've given away several . . . but depending on my experience over the next few years with Hakko, I may very well not replace any Metcal that goes belly up. I erred earlier, the second Pacific Rim solder station I have doesn't have Hakko's name on it . . . although it appears to incorporate similar technology. The #2 tool is a combination soldering and hot- air station.http://tinyurl.com/j3qosz5 Don't have alot of hours on it yet . . . but I've got a surface-mount assembly project coming up where I'll try it out with attaching parts with solder paste. The heat wand has proven useful for heat shrinking and label removal . . . watch this space . . . Bob . . .
 Filesize:  17.34 KB
PostPosted: Mon Feb 20, 2017 1:05 pm    Post subject: Solder Station Reply with quote
Interesting point of comparison: the expensive Metcal station is still only 70% of the list price of the AMP crimp tool Bob has been recommending.
On Feb 20, 2017, at 3:49 PM, Stein Bruch <stein(at)steinair.com (stein(at)steinair.com)> wrote:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
The older Metal’s use the multi conductor cable (we have a number of them) and the newer ones use the connector as shown below. Indeed that brand (OKI/Metcal) is one of the better solder stations out there (in my biased opinion)– Weller also makes some really nice solder stations (as does Hakko). We happen to use Metcal’s in our shop because that’s just what we started with many years ago. That said, none of the higher end units are cheap – and really not something the average consumer really needs at all. There are a pile of sub $200 units out there that will more than work acceptably for the average person not doing production type work.
Stein
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Alec Myers
Sent: Monday, February 20, 2017 1:49 PM
Subject: Re: Re: Solder Station
<image001.jpg>
  have 4 conductors.
<1bd797ce.jpg>
to Metcal.
technology.
air station.
solder paste.
PostPosted: Mon Feb 20, 2017 4:52 pm    Post subject: Solder Station Reply with quote
At 01:47 PM 2/20/2017, you wrote:
--> AeroElectric-List message posted by: C&K <yellowduckduo(at)gmail.com>
My Weller solder station uses a magnet attached to the back end of the solder tip. It loses magnetism at the predefined temperature as it heats. That cycles the power to the heater. It is often referred to as the Curie temperature of the magnet according to Wiki. You can change tips for a different temperature.
The Weller WTCPT solder stations go WAaayyyy back. I took
a hiatus from Electro-Mech to go work in the video industry.
What an education that was! The chief engineer I went to
work for had the WTCPT stations in his lab. I was so
impressed with them that I fitted every assembly station
on the production line with them.
When I went back to Electro-Mech a few years later, I
hit up the boss about fitting our production line with
these leading edge tools. I needed 12 stations and
I think they were about $100 each at the time.
He balked at that big an expenditure. So I asked him
what kind of budget I could have to upgrade the line
from the 25w, non-controlled irons.
He offered me $600.
A few weeks later he came into my office in a bit
of a huff wondering where I got off blowing the
budget on WTCPT stations. I was a bit taken aback,
I in fact spent considerably less than then
funds budgeted.
I discovered that the station base contained
only a 24v, 2A transformer. Replacement
wands for the station were $25 or thereabouts.
So I went down to Elmer Travis' surplus store on
N. Broadway and bought two big honker 24v transformers.
I think they were 15A for $20 each. I wired the
benches for 24VAC distribution and installed
those really cool irons at each work station.
I think I got it all done for under $500 including
my labor to hook 'em up.
I was introduced to Metcal at Beech. But until
I too could afford to acquire them, my own benches
were fitted with WTCPT repair wands and junk box
transformers.
art(at)zemon.name
PostPosted: Mon Feb 20, 2017 8:35 pm    Post subject: Solder Station Reply with quote
Boy I wish I had known this story before I dropped $140 on my own Weller WTCPT station. Smile
    -- Art Z.
On Mon, Feb 20, 2017 at 6:45 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: C&K <yellowduckduo(at)gmail.com (yellowduckduo(at)gmail.com)>
 He offered me $600.
 funds budgeted.
 transformers.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
PostPosted: Tue Feb 21, 2017 10:24 am    Post subject: Solder Station Reply with quote
Sorry 'bout that. BTW, If anyone is considering
a DIY WTCPT project, be sure your power source
is 24 VAC. One of my techs tried running his
iron on a DC power supply. Contacts in the
temperature control switch went south in too
short a time. The switch just didn't demonstrate
circuit breaking dynamics needed for an orderly
control of DC (See switch chapter in 'Connection).
johnbright
PostPosted: Sun Feb 26, 2017 6:42 pm    Post subject: Re: Solder Station Reply with quote
I received the Hakko FX888D-23BY. So far in my life I've had 30w irons you plug in and wait till it melts solder. This one is a joy relative to that, I set the temp, maybe 650F is good... it gets to that in 20s. I suppose it's great for my hobby use.
John Bright, RV-6A
N1921R links
johnbright
PostPosted: Sun Feb 26, 2017 6:45 pm    Post subject: Re: Solder Station Reply with quote
I received the FX888D-23BY. So far in my life I've had 30w irons you plug in and wait till it melts solder. This one is a joy relative to that, I set the temp, maybe 650F is good... it gets to that in 20s. I suppose it's great for my hobby use.
John Bright, RV-6A
N1921R links
PostPosted: Sun Feb 26, 2017 8:56 pm    Post subject: Solder Station Reply with quote
Forgive me, but i had to go and check: the Metcal is at temperature and melting solder five seconds after power on.
Aeroelectric Z-12.
http://forums.matronics.com/viewtopic.php?p=466687#466687
PostPosted: Mon Feb 27, 2017 9:34 am    Post subject: Solder Station Reply with quote
that's about how long it takes my Metcal RFG-30
power supplies to warm up a 'electronics' tip.
The big honker chisel tips a bit longer. BTW,
after 40+ years of sifting through soldering
iron holders, this one is my favorite:
[img]cid:.0[/img]
You can't buy them any more but the stand is from
Radio Shack . . one could probably fabricate or
purchase something similar elsewhere.
Took the base cover off and filled the cavity
with a 'potting compound' consisting of shot
shell pellets mixed with just enough epoxy to
make them really stick together (Plaster of
Paris might work as well). When the
epoxy sets, put the base cover back on. The
wet-sponge-tip-cleaner was replaced with
a wad of stainless steel pot scrubber. It
provides a good mechanical cleaning while
taking little heat out of the tip. It's also
easy to clean as bits of solder and tip-scum
shake right out of it.
I've been using this holder for close to
20 years with no urges to replace it.
 Filesize:  217.88 KB
 Viewed:  17140 Time(s)
Page 2 of 2
