Control surfaces fabric recovering
BTLYak
PostPosted: Mon Feb 13, 2017 4:59 am    Post subject: Control surfaces fabric recovering Reply with quote
What do I need to know about recovering the ailerons, elevators, and rudder on a mid 90's Yak 52?
"Battle Yak"
cjpilot710(at)aol.com
PostPosted: Mon Feb 13, 2017 6:22 am    Post subject: Control surfaces fabric recovering Reply with quote
Any good covering system, will work fine. There really nothing special about their structure. I believe the covering is rib stitched (same as the CJ-6) but using just normal recovering procedures and following instructions of the manufacture is really important. When you're done make sure you check the balance of the surface. A surface way out of balance may end up as a flutter problem.
At OSH last I saw a company hawking a new covering system. It was very very simple. You would apply a glue paste on the structure, put on the cover, and then use an iron to 'activate' glue. Bang! it was done. No stitching, no screws, no re enforcing tapes or streamlining tapes. NOW I am not sure if the system would stand up to the rigueur's of acrobatics in the 52 and that was a question I forgot to ask.
Jim "Pappy" Goolsby
In a message dated 2/13/2017 8:00:01 A.M. Eastern Standard Time, btlyak1(at)gmail.com writes:
--> Yak-List message posted by: "BTLYak" <btlyak1(at)gmail.com>
&quot;Battle Yak&quot;
http://forums.matronics.com/viewtopic.php?p=466115#466115========================= e ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - NEW MATRONICS LIST WIKI -_-= - List Contribution Web Site sp;   ===================================================
BTLYak
PostPosted: Mon Feb 13, 2017 7:34 am    Post subject: Re: Control surfaces fabric recovering Reply with quote
The larger question is estimated cost?
Materials?
How many labor hours?
"Battle Yak"
Viperdoc
PostPosted: Mon Feb 13, 2017 5:46 pm    Post subject: Control surfaces fabric recovering Reply with quote
The covering is called Oratec.
I am recovering mine on the 50 using the Stits System. The Russians use a different way to rib stitch on the elevator and rudder vs the aileron.
Doc
On Feb 13, 2017, at 8:21 AM, cjpilot710(at)aol.com (cjpilot710(at)aol.com) wrote:
Jim "Pappy" Goolsby
In a message dated 2/13/2017 8:00:01 A.M. Eastern Standard Time, btlyak1(at)gmail.com (btlyak1(at)gmail.com) writes:
--> Yak-List message posted by: "BTLYak" <btlyak1(at)gmail.com (btlyak1(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=466115#466115========================= e ties Day ================================================ - MATRONICS WEB FORUMS - List Contribution Web Site sp; ===================================================
Viperdoc
Viperdoc
PostPosted: Mon Feb 13, 2017 6:34 pm    Post subject: Control surfaces fabric recovering Reply with quote
About 300-400 USD for supplies. You will also need a good iron (large and small). Rib stitching needles, flux for the thermometer to standardize the ironing temp and the covering supplies. Time? I'm to many interruptions to be accurate. Left along with no hospital, wife, mother in nursing home issues, can I watch, and I need to talk to you about my medical problem before I do my flight physical questions I would be farther along.
Get the Stits covering manual from Aircraft Spruce. Read it then decide if you want to attach it. The manual will tell you all the supplies you need along with how to use them. Having EAA friends that have covered their experimental S before helps too.
It is not rocket since.
Doc
Materials?
http://forums.matronics.com/viewtopic.php?p=466123#466123
Viperdoc
stephen.hayne
PostPosted: Fri Feb 17, 2017 9:20 pm    Post subject: Re: Control surfaces fabric recovering Reply with quote
I just finished STITS from Aircraft Spruce, and it cost about $750 including the PolyTone "paint" (which was almost the most expensive part). Here is what I initially bought:
Qty Ship B/O Item Unit Price Total Price
2 2 0 09-18400 RIB STITCH NEEDLE 4" STRAIGHT # 504 1.450 2.90
1 1 0 09-02450 STITS PINKED P103 2" TAPE 25YD 23.200 23.20
2 2 0 09-03206 3" CURVED NEEDLE 1.120 2.24
2 2 0 09-03204 2" CURVED NEEDLE 0.950 1.90
2 2 0 09-18300 RIB STITCH NEEDLE 2-1/2" CURVD 1.100 2.20
2 2 0 09-18500 RIB STITCH NEEDLE 10" # 504 3.450 6.90
1 1 0 09-18710 RIB STITCH NEEDLE 6" CURVED 2.650 2.65
1 1 0 09-18705 RIB STITCH NEEDLE 3" CURVED 1.200 1.20
1 1 0 09-02900 POLY-FIBER P-103 3" TAPE 25YD 27.800 27.80
1 1 0 09-03600 STITS REINFORCING TAPE 3/8 56.600 56.60
1 0 1 09-41300-1 CECONITE RIB LACE CORD D693 RD 45.500 0.00
1 1 0 09-00234 POLY-FIBER COLOR CHART # 50 0.000 0.00
5 5 0 09-01600 POLY-FIBER FABRIC MEDIUM 73" 2.97 OZ 11.950 59.575
2 0 2 09-04850 POLY-FIBER REDUCER RR8500 GAL 48.500 0.00
1 1 0 09-04500 POLY-FIBER POLY-SPRAY GALLON 83.600 83.60
1 1 0 09-04100 POLY-BRUSH QT. TINTED 25.750 25.75
1 1 0 09-05000 POLY-FIBER POLY-TAK CEMENT QT 27.500 27.50
I ran out of Poly-Tak and Ply-Spray and had to borrow some from a friend. Didn't use ANY of the needles except the straight one. Lots of tape, thread and reducer left.
I then bought a gallon of the Poly-Tone (clear) and had it tinted locally to match the Chinese Olive Drab - fairly good match. Didn't try to paint the underside different. Still have 1/2 gallon of the clear Polytone left, as I only mixed up a couple quarts of color.
I had never done this before, and it took about 3 weeks of afternoons... I'm fairly satisfied with the job, but I got progressively better. Next time would be almost professional. I'm pretty sure it is safe. Smile
Attached is a pic of them - didn't get the elevators in there very well.
Hope this helps.
Stephen
 Filesize:  202.86 KB
 Viewed:  11351 Time(s)
Stephen Hayne, Cyber Security Consultant, Professor Emeritus (retired)
443LM Nanchang CJA
http://selfsynchronize.com/hayne/plane/cj6.asp
Viperdoc
PostPosted: Sat Feb 18, 2017 3:56 am    Post subject: Control surfaces fabric recovering Reply with quote
They look good Stephen. It is not rocket science. Pretty easy once you get going.
Doc
On Feb 17, 2017, at 11:20 PM, stephen.hayne <stephen.hayne(at)gmail.com> wrote:
Hope this helps.
Stephen
Dr. Stephen C. Hayne, Professor, CIS, Colorado State University
__!__
_____(_)_____ 666CJ
http://forums.matronics.com/viewtopic.php?p=466408#466408
http://forums.matronics.com//files/img_20161230_153029_794.jpg
Viperdoc
stephen.hayne
PostPosted: Sat Feb 18, 2017 8:25 am    Post subject: Re: Control surfaces fabric recovering Reply with quote
Wow - I just watched a video of the Oratex (http://www.betteraircraftfabric.com/oratex.html) and I wish I had known about it earlier. Seems like quite the good system. Easier and cheaper and probably more durable - check out the hammer test...
Oh, and thanks, Doc. It wasn't rocket science, but quite nerve wracking when you really don't know what you are doing, but just following the manual and looking at the old Chinese pattern.
Stephen
443LM Nanchang CJA
Viperdoc
PostPosted: Sat Feb 18, 2017 4:17 pm    Post subject: Control surfaces fabric recovering Reply with quote
The Antonov was impressive. We had a demo at our EAA meeting a couple of years ago. The rep was not sure about it at 200 kts. He was a writer for Kit Planes. It looked good. It went on exactly like the RC aircraft I used to cover.
Being unable to answer the 200kts question pushed me to the tried and true method of Stits covering. I in a holding pattern due to three cracked ribs on my left aileron that had been poorly field engineered by the way the RU had patched them. The trailing edge had also been Afro engineered. It had 8 cracks in it! They placed an aluminum 2 cm wide bar down center of the trailing edge between the two ribs that the trim tab attached to. It cracked again at both attachment points for trim tab.
Finding that answered the question of why a right snap roll would ratchet through the roll more like a 16 point roll. Currently am making hammer molds to rebuild the ribs. Then I have to find the phenolic squares that they use in the trailing edges of the ribs at the attachment points. That has slowed me again!
Doc
On Feb 18, 2017, at 10:25 AM, stephen.hayne <stephen.hayne(at)gmail.com> wrote:
Stephen
__!__
_____(_)_____ 666CJ
http://forums.matronics.com/viewtopic.php?p=466420#466420
Viperdoc
