Tim Olson
Posted: Thu Feb 16, 2017 2:00 pm Post subject: Sky-Tec NL vs LS starter |
Hey all, I'm thinking of replacing my starter on my RV-10
with the NL starter. I think mine is the 149-12PM
right now.
Can anyone who's either swapped for an NL or has an NL
comment on the fit of the starter in relation to all the
other stuff... i.e. is there any realistic chance that if I
swap starters its not going to fit well because of
some interference somewhere else? If not, I'll go ahead
and just order one.
kdb.rv10(at)gmail.com Guest
Posted: Thu Feb 16, 2017 2:15 pm Post subject: Sky-Tec NL vs LS starter |
Tim,
I had the 149-12PM on my RV10 and it would hardly turn it over. I have 2 PC680 batteries, but that's hardly enough power. Your larger battery must help there. I changed to the NL starter and it's great. It fits just fine and has much more torque. I don't have any problems now starting on one PC680. I think it's the best starter for the RV10.
Kevin Belue
On Thu, Feb 16, 2017 at 3:59 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
| Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
right now.
and just order one.
-List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?RV10-List
_blank" rel="noreferrer">http://forums.matronics.com
lank" rel="noreferrer">http://wiki.matronics.com
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
rene(at)felker.com Guest
Posted: Thu Feb 16, 2017 2:29 pm Post subject: Sky-Tec NL vs LS starter |
What is the ~price on the NL? How much weight does it add? I do not have a problem with the starter working with the 925 batter, but I think I am developing a dead (weak) spot and will be replacing my starter this annual……..unless the problem goes away when it gets warmer and I fly more.
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kevin Belue
Sent: Thursday, February 16, 2017 3:15 PM
Subject: Re: Sky-Tec NL vs LS starter
Tim,
Kevin Belue
On Thu, Feb 16, 2017 at 3:59 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote: | Quote: |
--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)>
right now.
and just order one.
Posted: Thu Feb 16, 2017 2:34 pm Post subject: Sky-Tec NL vs LS starter |
I have never seen a fit issue.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
right now.
and just order one.
Tim Olson
Posted: Thu Feb 16, 2017 2:39 pm Post subject: Sky-Tec NL vs LS starter |
Thanks Kevin,
I just hit "place order". Should have one next Wednesday.
I haven't heard any negatives in all my reading so I'm going to
go with it. My PC925 does work for the IO-540, but getting past
that first prop blade sometimes takes a 2nd try. But once
you start it spinning it does an OK job. I'm sure the NL
will be better.
I have an issue with my RV-14 starter not always cranking,b
but when it cranks its great. It's an LS. I was hoping to
pull my RV-10 starter and use it while I send that one in,
but it's a PM and not an LS, and I don't think the cable
lengths will work out. Oh well.
On 2/16/2017 4:14 PM, Kevin Belue wrote:
| Quote: | Tim,
Kevin Belue
right now.
and just order one.
Posted: Thu Feb 16, 2017 2:41 pm Post subject: Sky-Tec NL vs LS starter |
The Skytec NL starter weighs 9.3 lbs and costs $436 at Aircraft Spruce.
On Thu, Feb 16, 2017 at 4:28 PM, Rene <rene(at)felker.com (rene(at)felker.com)> wrote:
Rene'
[url=tel:(801)%20721-6080]801-721-6080[/url]
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Kevin Belue
Subject: Re: RV10-List: Sky-Tec NL vs LS starter
Tim,
Kevin Belue
right now.
and just order one.
Tim Olson
Posted: Thu Feb 16, 2017 2:42 pm Post subject: Sky-Tec NL vs LS starter |
I had 2 choices. One was $499 from Sky-Tec and then trade mine in for
a $154 credit, and the 2nd choice was $436 from ACS. I chose the
latter. It looks like 1lb more than my PM starter. All the better
for my CG when I load it up.
On 2/16/2017 4:28 PM, Rene wrote:
| Quote: | What is the ~price on the NL? How much weight does it add? I do not
Rene'
801-721-6080
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Kevin Belue
*Sent:* Thursday, February 16, 2017 3:15 PM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Sky-Tec NL vs LS starter
Tim,
Kevin Belue
<mailto:Tim(at)MyRV10.com>>
right now.
and just order one.
Posted: Thu Feb 16, 2017 3:00 pm Post subject: Sky-Tec NL vs LS starter |
Thanks Tim, I am the same on the CG. I added a 680 on the firewall, almost 100% for CG reasons. Big battery, O2, and APRS all behind the rear bulkhead or in the tail.
Rene'
801-721-6080
Posted: Thu Feb 16, 2017 3:02 pm Post subject: Sky-Tec NL vs LS starter |
Skytec has an option where you can send your starter to them for "rebuild" and get a different model back. Cheaper than buying a new one. I think the "rebuilt" is just a new unit.
Jesse SaintSaint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On Feb 16, 2017, at 5:28 PM, Rene <rene(at)felker.com (rene(at)felker.com)> wrote:
| Quote: | <![endif]--> <![endif]-->
Rene'
801-721-6080
Tim,
Kevin Belue
right now.
and just order one.
Tim Olson
Posted: Thu Feb 16, 2017 3:26 pm Post subject: Sky-Tec NL vs LS starter |
Maybe I'll try that. If I send them my PM for a rebuild, I can get
it back as an NL, and throw an NL on both airplanes.
That would be nice.
On 2/16/2017 5:02 PM, Jesse Saint wrote:
| Quote: | Skytec has an option where you can send your starter to them for "rebuild" and get a different model back. Cheaper than buying a new one. I think the "rebuilt" is just a new unit.
Jesse Saint Saint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
Rene'
801-721-6080
Tim,
Kevin Belue
right now.
and just order one.
flysrv10(at)gmail.com Guest
Posted: Thu Feb 16, 2017 4:07 pm Post subject: Sky-Tec NL vs LS starter |
Tim,
If the NL is the long version with planetary gear, I have one and have no issues with the standard installation. I have a narrow deck 540.
right now.
and just order one.
Kellym
Posted: Thu Feb 16, 2017 6:15 pm Post subject: Sky-Tec NL vs LS starter |
I chose a Hartzell (orig Kelly) ERZ-8011. I like it a lot. A bit more
torque and slower rpm than the Nline Skytec. However, when I made the
choice it was close to the Skytec in price. Since Hartzell took over, it
now is priced at a $200 premium. No way I would pay that much extra now.
One other advantage it had was a clutch to protect against kick backs. I
understand that Skytec has since adopted that feature, instead of the
shear pins they originally had. I was not a fan of having to remove a
starter just to replace a shear pin. Didn't I read about Hartzell buying
out both Skytec and Plane Power recently? Hard to say what that means in
the long run.
On 2/16/2017 5:02 PM, Rob Kermanj wrote:
Tim,
> right now.
> and just order one.
> Tim
KCHD |
Tim Olson
Posted: Fri Feb 17, 2017 7:25 am Post subject: Sky-Tec NL vs LS starter |
Just following up on this.
Today I bought a 2nd NL starter. So I'm going to just put them on
both planes. I'll have a 149-12LS and 149-12PM on the shelf
as spares I guess.
I asked Sky-Tec about the rebuild option. She said that is
not an option any longer and went away when Hartzell bought
Sky-Tec. They only have one option now. You can buy a
new starter, from them ($499 vs $436 street price), then
after you pull your old one send the receipt and old starter
in, and get your credit. Current credit for the old is
$154 for the LS or PM. So a delta of about $90. But,
you have to pay shipping in both directions...for the new
starter, and the old starter, and I'm assuming for the
replaced starter. With shipping costs where it is, that
$90 will get cut to almost nothing by 3 shipments at $25.
So, by buying 2 from spruce, I got free shipping on the new
ones, and now I'll have 2 that I can either shelf for
spares, or sell, or whatever.
BTW: The NL starter can only be wired (without modification)
by using the single-wire method. I have both planes wired
per Van's where you pull the jumper wire. Just wanted to
note that there is that difference.
I opted for the NL for the 14 primarily for expedience in
getting it fixed, but also to add that 1lb to the engine.
It will assist in keeping my CG forward for aerobatic envelope
purposes.
Jesse Saint
jesse(at)saintaviation.com <mailto:jesse(at)saintaviation.com>
C: 352-427-0285
F: 815-377-3694
philperry9
Posted: Fri Feb 17, 2017 7:30 am Post subject: Sky-Tec NL vs LS starter |
Tim,
I'm not familiar with the 149-12PM, so I can't comment on the differences between the fit. However I have the NL, and can't imagine that you would have any fit issues. It tucks away into the engine nicely. Perhaps you could have a scat tube, cable, or wire in the way, but I doubt it.
Here's some photos with a straight edge to help put things into perspective.
For the record, I have a dual alt/battery setup with dual PC-680's on the backend. I also have 9:1 pistons and a the NL starter doesn't even blink at spinning the MT on a single battery. Plenty of torque off a 680 for the 9:1 pistons. Your PC-925 and 8.5 pistons (IIRC) won't have any issues at all.
Phil
[img]cid:ii_15a4cadb70a02f40[/img]
[img]cid:ii_15a4cae019fc7c07[/img]
[img]cid:ii_15a4cae50f7acba8[/img]
On Thu, Feb 16, 2017 at 8:17 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
| Quote: | --> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
I chose a Hartzell (orig Kelly) ERZ-8011. I like it a lot. A bit more torque and slower rpm than the Nline Skytec. However, when I made the choice it was close to the Skytec in price. Since Hartzell took over, it now is priced at a $200 premium. No way I would pay that much extra now. One other advantage it had was a clutch to protect against kick backs. I understand that Skytec has since adopted that feature, instead of the shear pins they originally had. I was not a fan of having to remove a starter just to replace a shear pin. Didn't I read about Hartzell buying out both Skytec and Plane Power recently? Hard to say what that means in the long run.
| Quote: | --> RV10-List message posted by: Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)>
Tim,
right now.
and just order one.
117.44 KB |
19959 Time(s) |
153.5 KB |
19959 Time(s) |
114.05 KB |
19959 Time(s) |
Kelly McMullen
Posted: Fri Feb 17, 2017 7:49 am Post subject: Sky-Tec NL vs LS starter |
The LS and PM starters are permanent magnet, a little lighter than the NL and have the solenoid either on the right or left side of the motor. It is an issue with baffle fit. They draw a lot more current than the NL and have trouble cranking past the compression stroke if the battery is a little down or there is any resistance in the cable connections between battery and starter. I have one on my Mooney. Took some tracking down to replace an old starter relay that had resistance before it would crank reliably.
-sent from the I-droid implanted in my forearm
On Fri, Feb 17, 2017 at 8:26 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
Tim,
A&P/IA, EAA Tech Counselor
KCHD |
Tim Olson
Posted: Fri Feb 17, 2017 7:52 am Post subject: Sky-Tec NL vs LS starter |
That's kind of what I figured Phil. The photos all make it
look much longer than the LS/PM versions. The LS and PM
seem to be almost identical, with the solenoid on the opposite
side of the main body. I may have some small wires like for
my lightspeed ignition or something that I have to
adjust but I don't expect anything major. It's just that
going from a short/wide starter to a narrow/long one
had me wondering if I was overlooking something. I guess
I'll know in a couple weeks.
I'll report back after I get them installed.
On 2/17/2017 9:26 AM, Phillip Perry wrote:
Tim,
but I doubt it.
any issues at all.
Phil
gengrumpy
Joined: 07 May 2013 Posts: 131 Location: Tullahoma, TN
Posted: Fri Feb 17, 2017 7:59 am Post subject: Sky-Tec NL vs LS starter |
In the FWIW area on starters, I originally had the LS starter on my 10. I had always had difficulty starting with just 1 PC 680 battery. During my 2015 ACI I decided to send it back to SkyTech for refurb. When discussing with them, they told me I had the wrong starter installed since the engine was built by AeroSport Power in 2006! They sent me an overhauled NL starter with my LS as the core. Same fit and function as the LS.
The difference in the initial turning of blades is night and day different (MUCH improved).
grumpy
n184jm
> Tim,
> but I doubt it.
> any issues at all.
> Phil
philperry9
Posted: Fri Feb 17, 2017 8:05 am Post subject: Sky-Tec NL vs LS starter |
I'm at the hangar now, trying to get this thing finished up, so I can give you any measurement you want.
The back of the starter to the front of the sump is exactly 1".
On Fri, Feb 17, 2017 at 9:51 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
Tim,
but I doubt it.
any issues at all.
Phil
Posted: Fri Feb 17, 2017 9:07 am Post subject: Sky-Tec NL vs LS starter |
Okay, that does it. I'm swapping mine as well.
I too have (2) 680s and it 'should' be enough power but it isn't for the LS. That first blade is always in question.
Thanks all!
Rene'
801-721-6080
Tim,
Kevin Belue
right now.
and just order one.
www.avast.com
Tim Olson
Posted: Fri Feb 17, 2017 9:21 am Post subject: Sky-Tec NL vs LS starter |
Ok Bill, I give you permission to put in your order now.
I say that because I'm sure that by now mine have been
packaged for shipping so you won't take one of mine.
You're absolutely right. It's the first blade that's the
problem. On my RV-14 the LS works great, but the NL
should work even better. It will turn the prop
"bigly" to quote a random buffoon I keep seeing on tv.
On 2/17/2017 11:06 AM, Bill Watson wrote:
| Quote: | Okay, that does it. I'm swapping mine as well.
Thanks all!
