dan.beadle(at)inclinesoft Guest
Posted: Tue Jul 11, 2006 7:35 pm Post subject: Aerobatics and gyro's |
I believe that this is a good solution. As long as they are not spinning, there is little stress on the bearings.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Garrett, Randy L Dr HQ INSCOM
Sent: Tuesday, July 11, 2006 8:01 PM
To: rv-list-digest(at)matronics.com
Subject: Aerobatics and gyro's
I am planning to begin aerobatics in my RV-6A (and will go through the proper paperwork process to add aerobatic manuevers to my flight limitations).
I have a vacuum artificial horizon and directional gyro and an electrical turn coordinator.
Unfortunately, there is no simple way to quickly remove any of these instruments.
A potentially clever alternative ...
I could easily adjust the vacuum so that the AH and DG do not run at all (that is, there's zero air flowing though the instruments) and pull the circuit breaker so that the turn coordinator is also off.
But, I don't know if this would be better or worse for the gyros to not be spinning when they have G and centrifical forces applied to them. Also, would there be a problem for the vacuum pump to be running, but presumably not having any air flowing through it?
Thanks!
Randy Garrett
RV-6A
675 hours
mitch(at)skybound.com Guest
Posted: Tue Jul 11, 2006 8:46 pm Post subject: Aerobatics and gyro's |
Incorrect. Our EAA chapter just had a presentation from an avionics and
major gyro rebuilding shop. I asked specifically about aerobatics and
gyros, they said "No problem whatsoever, UNLESS you do something silly
like remove the vacuum". They know the internals of gyros intimately,
and said there are stops for the gimbals and it does them no harm at all
to go to the stops for loops, rolls, etc. I know there are many wives
tales and hunches out there, but these guys have serious experience with
gyros.
Mitch Faatz RV-6A Finish Kit (no, really) Auburn, CA
Dan Beadle wrote:
[mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Garrett,
*Sent:* Tuesday, July 11, 2006 8:01 PM
*To:* rv-list-digest(at)matronics.com
*Subject:* Aerobatics and gyro's
limitations).
instruments.
Thanks!
Randy Garrett
RV-6A
675 hours
dale1rv6(at)comcast.net Guest
jsflyrv(at)verizon.net Guest
Vanremog(at)aol.com Guest
Posted: Wed Jul 12, 2006 7:12 am Post subject: Aerobatics and gyro's |
In a message dated 7/12/2006 4:24:14 A.M. Pacific Daylight Time, dale1rv6(at)comcast.net writes:
| Quote: | Then why did they make gyros that were cageable?
I thought it was so that you could re-erect the gyro once you got straight and level after completing your aerobatic maneuvers.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA)
Posted: Wed Jul 12, 2006 7:17 am Post subject: Aerobatics and gyro's |
They are cageable to get back to proper indications as soon as possible
after aerobatics.
From Sigma-Tek: "The unique cageable attitude provides for quick
erection and display alignment; a high priority for aerobatic aircraft
owners and for aircraft operations that require short stops." The
caging mechanism simple gets the gyro to "close to level" as quickly as
possible, instead of waiting for the righting mechanisms and erecting
vanes to work.
To expand on this, here is more text from Sigma-Tek: "Short stops
(engine off less than 12 minutes) and some aerobatic maneuvers may cause
your attitude gyro to tumble or precess from its vertical reference.
When the rotor is spinning, the gyros normal erection system is slow and
can take several minutes to correct a large erection error. This
non-locking caging feature allows the pilot to quickly align the gyro
display and rotor to gyro case reference. The attitude gyro should only
be caged for quick alignment during straight and level VFR flight using
well defined earth horizon for reference or prior to take off"
As far as you having better luck after removing vacuum, I'm guessing the
new gyros are just better
Mitch Faatz RV-6A Finish Kit Auburn, CA
In my experience; 2 gyros went bad in 150 hours with monthly
aerobatics. Then I installed 2 valves to allow vacuum flow switchable
direct to filter, bypassing gyros. No problem so far 500 hours later
with weekly aerobatics. I do use the gyros monthly for IFR practice
too keep myself and gyros lubricated. I never liked seeing my
instruments banging quite hard on each spill. BTW, hope they don't
rotate boxes during shipping
Dale
RV6A 650hrs
