gilles.thesee(at)free.fr Guest
Posted: Fri Feb 10, 2017 12:55 am Post subject: Flap control suggestions |
Hi all,
What would be your suggestion for a landing flap control box, module etc. ?
My partners would prefer a system with a three or four positions
lever/toggle directly commanding the flap position, like "retracted",
"takeoff", "land" etc.
Any ideas about a supplier, any feedback ?
Thanks in advance,
Best regards,
Gilles
http://contrails.free.fr
http://lapierre.skunkworks.free.fr
Joined: 28 Mar 2008 Posts: 1969 Location: Riley TWP Michigan
Posted: Fri Feb 10, 2017 5:29 pm Post subject: Flap control suggestions |
At 02:51 AM 2/10/2017, you wrote:
| Quote: | --> AeroElectric-List message posted by: GTH <gilles.thesee(at)free.fr>
Hi all,
What would be your suggestion for a landing flap control box, module etc. ? |
How about a spring loaded, (retract)-OFF-(extend) switch?
The only time flap position indicator were required
was on aircraft where the airplane might become
unmanageable if flaps were extended too far for some
flight condition -AND- the flaps could not be directly
observed by the pilot.
I can't ever recall using a flaps position indicator
to drive flaps to a 'precise' position during any
phase a flight. A few dozen approach/landing
cycles would pretty well calibrate the stick-feel
for positioning flaps without bringing your eyes
inside the cockpit -or- visually confirming the
flap position.
Some models of Cessna were fitted with flaps that
could be extended to 40 degrees. There WERE situations
where the airplane would not sustain level flight
with fully extended flaps and we were taught to make a
final approach at 30 and not to go all the way until you were
committed to land.
A A/D against those airplanes restricted flap travel
to 30 degrees after too many pilots got into a bind
with too aggressive application of flaps.
But those are RARE and if your project is at risk for
such a condition, the kit manufacturer and/or owners
of said aircraft will certainly know about it.
Aside from those rare designs, the simple toggle switch
teamed with limit switches and perhaps some robust
SPDT relays is cheap, simple, and very low risk for
un-intended motion of flaps. I'm certain that you'll
discover that a flap position indicator is among the
least useful displays on the panel.
http://tinyurl.com/nhftedq
jonlaury
Posted: Sat Feb 11, 2017 9:32 am Post subject: Re: Flap control suggestions |
I have limited flight time with this http://www.aircraftextras.com/FPS-Plus-nt.htm unit, but I'm pleased with it so far. It's programmable so you can find the flap settings that work best for your plane and loading and set them as a pre-selected positions (3). Go to max/no flap by holding the switch down/up for 1 second. Very intuitive to use and it integrated easily into my AF 4500 panel. The AF panel indicator is pretty small scale but is useful in my scan to just to note when flaps are deployed (like if I forget to raise them). Wired with a back-up overide switch in the event of unit malfunction.
Posted: Sat Feb 11, 2017 12:15 pm Post subject: Flap control suggestions |
I've been using TCW's Intellignet Flap Controller and have been happy with it. I use it with a switch where the up position takes it all the way to reflex and each momentary touch of the downs switch takes it from reflex to zero to first position down to full down.
Regarding flap position; I decided to just look out the window and that has worked well for me.
On 2/10/2017 3:51 AM, GTH wrote:
| Quote: | --> AeroElectric-List message posted by: GTH <gilles.thesee(at)free.fr> (gilles.thesee(at)free.fr)
Hi all,
My partners would prefer a system with a three or four positions lever/toggle directly commanding the flap position, like "retracted", "takeoff", "land" etc.
Thanks in advance,
www.avast.com
alec(at)alecmyers.com Guest
Posted: Sat Feb 11, 2017 12:35 pm Post subject: Flap control suggestions |
For comparison purposes only, you may wish to consider FAR 23.699:
Sec. 23.699 — Wing flap position indicator.
There must be a wing flap position indicator for—
(a) Flap installations with only the retracted and fully extended position, unless—
(1) A direct operating mechanism provides a sense of “feel” and position (such as when a mechanical linkage is employed); or
(2) The flap position is readily determined without seriously detracting from other piloting duties under any flight condition, day or night; and
(b) Flap installation with intermediate flap positions if—
(1) Any flap position other than retracted or fully extended is used to show compliance with the performance requirements of this part; and
(2) The flap installation does not meet the requirements of paragraph (a)(1) of this section.
Both Cessna and Piper single engine aircraft intermediate flap settings so are covered by (b)(1) above, so unless they meet (a)(1) (Piper aircraft and early Cessnas with Johnson bar flap operation) they need position indicators.
http://www.risingup.com/fars/info/part23-699-FAR.shtml
On 11Feb2017, at 2:24 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
Hi all,
flap position.
committed to land.
Posted: Wed Feb 15, 2017 9:12 am Post subject: Flap control suggestions |
Le 11/02/2017 à 21:08, Bill Watson a écrit :
| Quote: | I've been using TCW's Intellignet Flap Controller and have been happy with it. I use it with a switch where the up position takes it all the way to reflex and each momentary touch of the downs switch takes it from reflex to zero to first position down to full down.
Thank you everyone for your suggestions.
I've passed them on to my partners.
Best regards,
Gilles
