haribole
Joined: 21 Feb 2014 Posts: 33 Location: United States
Posted: Thu Jan 19, 2017 9:59 am Post subject: Dual Battery design |
I was originally planning on using the Z19B, but came across a print out of what looks like a much simpler dual batter design. Not sure where I printed this from, but this surely looks like an aeroelectric design and can not find this in the 12th edition book.
could someone please see if they recognize this and enlighten me?
Hari
haribole
Posted: Thu Jan 19, 2017 10:39 am Post subject: Dual Battery design |
Forgot the attachment.
On Thu, Jan 19, 2017 at 9:55 AM, Hariharan Gopalan <rdu.hari(at)gmail.com (rdu.hari(at)gmail.com)> wrote:
| Quote: | I was originally planning on using the Z19B, but came across a print out of what looks like a much simpler dual batter design. Not sure where I printed this from, but this surely looks like an aeroelectric design and can not find this in the 12th edition book.
Hari
 Download |
| Filename: |
Doc_-_Jan_19_2017_-_12-43_PM.pdf |
276.13 KB |
| Downloaded: |
614 Time(s) |
Joined: 28 Mar 2008 Posts: 1969 Location: Riley TWP Michigan
Posted: Thu Jan 19, 2017 7:44 pm Post subject: Re: Dual Battery design |
That is not one of Bob N's schematics. It has some major flaws.
The starter current goes through the ammeter shunt.
The E-bus relay coil appears to be always grounded but is not.
The 4 pole switch is a single failure point.
The 20 amp circuit breaker for the starter contactor and solenoid seems too big.
The 200 amp ANL alternator current limiter seems way too big.
The 200 amp ANL battery current limiters are unnecessary and should not be in series with starter motor.
_________________ Joe Gores |
Posted: Fri Jan 20, 2017 6:03 am Post subject: Dual Battery design |
At 12:36 PM 1/19/2017, you wrote:
| Quote: | Forgot the attachment.
That drawing uses symbols from my library
and suggests a strong influence from
AEC architecture drawings . . . but it
is not my drawing. It also deviates from
recommended practices in several regards.
Posted: Fri Jan 20, 2017 6:05 am Post subject: Dual Battery design |
On Thu, Jan 19, 2017 at 9:55 AM, Hariharan Gopalan <rdu.hari(at)gmail.com (rdu.hari(at)gmail.com)> wrote: I was originally planning on using the Z19B, but came across a print out of what looks like a much simpler dual batter design. Not sure where I printed this from, but this surely looks like an aeroelectric design and can not find this in the 12th edition book.
could someone please see if they recognize this and enlighten me? |
haribole
Posted: Fri Jan 20, 2017 1:42 pm Post subject: Re: Dual Battery design |
Thanks Bob. I remember reading sometime back about a proposed alternative to the Z-19 dual battery design. Is there one that has still not been published in the book?
Hari
Posted: Sat Jan 21, 2017 5:18 am Post subject: Dual Battery design |
At 03:42 PM 1/20/2017, you wrote:
| Quote: | --> AeroElectric-List message posted by: "haribole" <rdu.hari(at)gmail.com>
Thanks Bob. I remember reading sometime back about a proposed alternative to the Z-19 dual battery design. Is there one that has still not been published in the book? |
Let's back up a bit. What is it about Z-19 that
makes it attractive to your project? Keep
in mind that the z-figures are not 'wire books'.
They do not propose to SPECIFY sizes of wires,
size/style of protection, size or type of battery(ies),
size of alternators, style of switches, etc.
They are illustrations that suggest architectures
that strive for the elegant solution to meeting
design goals that FIT your machine/mission profiles.
M/MP. Z-14 MIGHT make sense for a Lancair IVP, but
Z-13/8 could very well accomplish the builder's
M/MP.
The Z-figures do indeed show some SIZED protective
devices and similarly sized wires . . . but EVERY
component you choose to install should be verified
for suitability to task and evaluated for how it
fits into your failure mode effects analysis.
How can it fail? How would I know it failed in
flight? Would failure present an unacceptable
level of risk to comfortable termination of
flight? Is the failure pre-flight detectable?
What is my Plan-B for making such failures
a simple maintenance issue as opposed to an
emergency?
So tell us about your project. How to do plan
to use it? In your cruise down the isles of
simple ideas in the 'Connection, what features
offered seem a best-fit for design goals based
on your M/MP?
The Dual battery concepts were crafted in response
to the rise in interest for using electrically dependent
engines in aircraft. HOWEVER, having an electrically
dependent engine does not necessarily dictate that
two batteries are the best choice.
Let's talk about it . . .
