Recommendations for Map Lights and Dome Lights
art(at)zemon.name
PostPosted: Sun Jan 15, 2017 10:26 am    Post subject: Recommendations for Map Lights and Dome Lights Reply with quote
Folks,
Shopping for map lights and dome lights on the interwebs is hard. How do you select something when all you can see is a small picture? Ugh. Do you have any personal recommendations?
Map lights should have switches at the base.
Dome light should not have a switch (because I will install a remote switch near the door).
    -- Art Z.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
donjohnston
PostPosted: Sun Jan 15, 2017 2:18 pm    Post subject: Re: Recommendations for Map Lights and Dome Lights Reply with quote
For map lighting, I went with one of these.
http://www.aircraftspruce.com/catalog/pspages/754cockpitlights.php
Black with 4 white LED's.
For cabin lighting, I used Perko lights. They are the lights that many Velocity builders use (available at West Marine and other marine supply stores).
http://www.perko.com/catalog/lighting_fixtures/708/incandescent_light_with_snap_on_front_cover/
But since I have a 28v electrical system, I made some changes. I removed the incandescent light and installed a set of blue and white LED's. Then I put in SPDT switches to select between Off, white and blue lights.
 Filesize:  77.19 KB
 Viewed:  4794 Time(s)
 Filesize:  79.42 KB
rlborger(at)mac.com
PostPosted: Sun Jan 15, 2017 3:22 pm    Post subject: Recommendations for Map Lights and Dome Lights Reply with quote
Art,
Check Aircraft Spruce. Search for LED Lighting and look under Cockpit/Cabin Lighting. There’s a lot of different styles from which to choose.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On Jan 15, 2017, at 12:23 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
Folks,
-- Art Z.
-- https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
jonlaury
PostPosted: Mon Jan 16, 2017 12:37 pm    Post subject: Re: Recommendations for Map Lights and Dome Lights Reply with quote
Art,
I used an AVEO EyeBeam-mini in my Glasair. A bit pricy, but the design is beautiful and functional. The eyeball lets you put light wherever you need it and it has capacitive integral switch/dimmer/red light.
I had/have an interference problem with my specific installation that AVEO engineers had never encountered. When I key my mike, the light starts flashing and the capacitive on/off switch becomes in op until power is physically disconnected. After unsuccessful attempts to fix it with ferrite toroids, I installed a small on/off/dimmer switch on the housing and in the power feed to fix it.
 Filesize:  44.73 KB
 Viewed:  4756 Time(s)
