Hot alternator
trigo(at)mail.telepac.pt
PostPosted: Sun Jan 08, 2017 3:13 am    Post subject: Hot alternator Reply with quote
Good morning guys
I am still doing the electrical installation of my bird, and sometimes I turn on the Master Switch to check if everything is working well with the last installed critter.
This time, after finishing the wiring of an electronic Carbon Monoxide detector, I turned On the Master (together with the Main Alt field) to check if the CO alarm 2-colour Led would lit as advertised, first a blinking green and after 2 minutes the steady green.
All went well, except that I forgot to turn Off the Master (and Alt field), and they kept On for perhaps 15 or 20 minutes, while I was working on the Engine baffles...
Then, I noticed that the Main Alternator was really hot to the touch, which reminded me to turn Off the Master switch.
Long story to ask the question: is this normal? If the Master switch (and the Alt field switch) is On for some time, even with the engine Off, the Alt gets that hot?
Why?
Carlos
P.S. - perhaps you'll need some more information about my electric system architecture...
yellowduckduo(at)gmail.co
PostPosted: Sun Jan 08, 2017 4:40 am    Post subject: Hot alternator Reply with quote
It is normal for an older internally regulated 40 amp nippondenso. They
aren't "smart enough" to sense rotation so they draw a couple of amps
into the field coil when stopped and get noticeably warm.
Ken
On 08/01/2017 6:08 AM, Carlos Trigo wrote:
Good morning guys
Why?
Carlos
PostPosted: Sun Jan 08, 2017 6:03 am    Post subject: Hot alternator Reply with quote
Ken
Mine is also internally regulated but is an all new PlanePower 60A
CT
Enviado do meu iPhone
No dia 08/01/2017, às 12:37, C&K <yellowduckduo(at)gmail.com> escreveu:
It is normal for an older internally regulated 40 amp nippondenso. They aren't "smart enough" to sense rotation so they draw a couple of amps into the field coil when stopped and get noticeably warm.
Ken
> Good morning guys
> Why?
> Carlos
Dave Saylor
PostPosted: Sun Jan 08, 2017 6:39 am    Post subject: Hot alternator Reply with quote
My PlanePower has been hot enough to leave a blister.   After some cursing, I got in the habit of pulling the field breaker if I have the battery on for any length of time.
The regulator is trying in vain to raise the output voltage.  I assume it runs as much current as it can through the field, but of course it gets no results.
--Dave
On Sun, Jan 8, 2017 at 5:57 AM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
--> AeroElectric-List message posted by: Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)>
Ken
CT
No dia 08/01/2017, às 12:37, C&K <yellowduckduo(at)gmail.com (yellowduckduo(at)gmail.com)> escreveu:
> --> AeroElectric-List message posted by: C&K <yellowduckduo(at)gmail.com (yellowduckduo(at)gmail.com)>
> Ken
>> Good morning guys
>> Why?
>> Carlos
--Dave
KWVI
alec(at)alecmyers.com
PostPosted: Sun Jan 08, 2017 7:04 am    Post subject: Hot alternator Reply with quote
And there's no cooling airflow (does it have a shaft mounted fan? That's not turning)
On Jan 8, 2017, at 9:36 AM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
--Dave
Ken
CT
> Ken
>> Good morning guys
>> Why?
>> Carlos
PostPosted: Sun Jan 08, 2017 8:30 pm    Post subject: Hot alternator Reply with quote
Yes . . . this is quite normal. while the alternator
is not rotating, battery-only bus voltage is so low
that the regulator is full-fielding the alternator.
Depending on the altenator, this can be as much as 3.5
amps at 12 volts for 42 watts of heat being generated
inside with no place to go.
This is why ALL of my architecture drawings show
either a three position DC power master for
OFF/BATT/ALT+BATT -or- a two-pole OFF/ON with
a PULLABLE breaker associated with the crowbar
ov protection system.
It is a design goal to have independent control
over the alternator during battery only operations.
The non rotating alternator not only gets hot, it
consumes energy from teh battery that would otherwise
be available for ground test operations -or- battery
only operations while airborne.
PostPosted: Sun Jan 08, 2017 8:53 pm    Post subject: Hot alternator Reply with quote
At 07:57 AM 1/8/2017, you wrote:
--> AeroElectric-List message posted by: Carlos Trigo <trigo(at)mail.telepac.pt>
Ken
Many, if not MOST internally regulated alternators
are fitted with a stator phase sense connection to the
regulator chip.
[img]cid:.0[/img]
This signal tells the regulator whether or not
the alternator is rotating so as to prevent
full-fielding of the alternator is a quiescent
state.
No such provisions are available for most
externally regulated alternators. Waaay back when,
automotive alternators had a "AUX" teerminal
that power the field control relay inside the
regulator. This too effected field current shutdown
while not rotating.
Future regulators from our drafting table will be
micro-controller based and will feature a full field
limit timer that will prevent such events during ground
testing or alternator failure while airborne.
In the mean time, a pullable field breaker
[img]cid:.1[/img]
. . . or three position DC PWR MASTER
are recommended.
[img]cid:.2[/img]
 Filesize:  105.33 KB
 Viewed:  7927 Time(s)
 Filesize:  21.91 KB
 Filesize:  15.24 KB
PostPosted: Mon Jan 09, 2017 9:08 am    Post subject: Hot alternator Reply with quote
That means that if I had the Alt field off, i.e only the Master switch On, the Alternator would not have got hot... right?
I do have a split Master switch / Alt Field switch.
Carlos
No dia 09/01/2017, às 04:51, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> escreveu:
Ken
regulator chip.
<323e6d5.jpg>
state.
while not rotating.
<323e723.jpg>
are recommended.
<323e742.jpg>
Dave Saylor
PostPosted: Mon Jan 09, 2017 7:48 pm    Post subject: Hot alternator Reply with quote
Yep, that's right.  I just pull the field breaker.  My alternator comes on with the battery.  I don't have a separate position for alternator + battery.
-Dave
On Mon, Jan 9, 2017 at 9:02 AM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Carlos
Ken
  regulator chip.
<323e6d5.jpg>
  state.
  while not rotating.
<323e723.jpg>
  are recommended.
<323e742.jpg>
--Dave
KWVI
PostPosted: Tue Jan 10, 2017 5:20 am    Post subject: Hot alternator Reply with quote
Is your alternator internally or externally
regulated?
PostPosted: Tue Jan 10, 2017 5:42 am    Post subject: Hot alternator Reply with quote
It is internally regulated 60A Plane Power, which has built-in crowbar OV protection.
CT
No dia 10/01/2017, às 00:21, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> escreveu:
regulated?
PostPosted: Tue Jan 10, 2017 6:43 am    Post subject: Hot alternator Reply with quote
At 07:36 AM 1/10/2017, you wrote:
Okay, it is my understanding that P-P brings field supply
lead out for ABSOLUTE alternator control. Hence, leaving
the alternator side of your split rocker OFF should relieve
the battery of an unnecessary load during ground ops . . .
and leave your alternator cool.
PostPosted: Tue Jan 10, 2017 9:41 am    Post subject: Hot alternator Reply with quote
Works good . . . lasts a long time.
