Battery replacement
yakman285(at)gmail.com
PostPosted: Fri Jan 06, 2017 12:16 pm    Post subject: Battery replacement Reply with quote
After 22 years of buying "Real"aircraft batteries, the ***Tards are wearing me down with their price increases. I'm thinking about the two 12V in series. The gell cell type. Anyone been this route?
Craig Payne
Clouddog
PostPosted: Fri Jan 06, 2017 12:33 pm    Post subject: Battery replacement Reply with quote
Craig, I've been doing it for years. So has 2 others that I know. No spillage, price of about $150 for two 12 volt Gel Cells, Lighter and why has it taken you so long???
On Jan 6, 2017 14:19, "Craig Payne" <yakman285(at)gmail.com (yakman285(at)gmail.com)> wrote:
Craig Payne
Ernie
PostPosted: Fri Jan 06, 2017 12:34 pm    Post subject: Battery replacement Reply with quote
Craig,
I've been using the Oddesey AGM Batteries. Half the weight, half the cost.
I used a pair of the PC545 I believe.
Ernie
On Fri, Jan 6, 2017 at 3:15 PM, Craig Payne <yakman285(at)gmail.com (yakman285(at)gmail.com)> wrote:
Craig Payne
Ernie
PostPosted: Fri Jan 06, 2017 12:35 pm    Post subject: Battery replacement Reply with quote
Forgot to provide link
http://www.odysseybattery.com/extreme_battery_specs.aspx
On Fri, Jan 6, 2017 at 3:34 PM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
Craig,
Ernie
Craig Payne
jonboede(at)hotmail.com
Yes. Odyssey batteries are an excellent replacement. We use a pair of PC925s in most Soviet battery boxes. A couple of things:
1. You can get a nice cable made at most welding supply places to put the two batteries in series.
2. The batteries can be damaged above 14.7v volts. This means that the maximum for a pair is NOT 29.4v but more like 29v since the internal resistance in the two batteries will never be equal. They will last forever if you adjust your voltage regulator to that.
3. Batterymart.com has the best prices and free shipping that we have found. Sealed batteries are shipped charged via UPS ground.
4. There are a lot of different choices of sizes if you are working them into a box. You don't really need much smash in a CJ/Yak because you're not running an electric starter. Even the PC680 will do you fine. The PC925 is enough to run the starter/generator on an L-29 or Mi-2, so its serious overkill for your plane (although it would run the avionics all day if your generator died).
Jon
Craig Payne
pjashura
PostPosted: Fri Jan 06, 2017 12:38 pm    Post subject: Battery replacement Reply with quote
Werker WKA12-18NB
Craig Payne
PJ Ashura
jlpartington(at)reagan.co
PostPosted: Fri Jan 06, 2017 12:42 pm    Post subject: Battery replacement Reply with quote
Works for my CJs. last longer too
dsavarese0812(at)bellsout
PostPosted: Fri Jan 06, 2017 12:56 pm    Post subject: Battery replacement Reply with quote
Yes, most definitely. Lots and lots installed that way.
Dennis
To: yak-list <yak-list(at)matronics.com>
Sent: Friday, January 6, 2017 3:15 PM
Subject: Battery replacement
Craig Payne
hkgibby(at)yahoo.com
PostPosted: Fri Jan 06, 2017 1:48 pm    Post subject: Battery replacement Reply with quote
2 Odysseys' PC545 in series; love them.
Hoot
Craig Payne
 Filesize:  707.87 KB
 Viewed:  18311 Time(s)
PostPosted: Fri Jan 06, 2017 1:56 pm    Post subject: Battery replacement Reply with quote
http://www.4wheelparts.com/stores/Store-Info.aspx?sNo=64
Have a store in Jax; can pick up a couple for you and have at Waycross if you want to save shipping.
Hoot
On Jan 6, 2017, at 3:55 PM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
Dennis
From: Craig Payne <yakman285(at)gmail.com (yakman285(at)gmail.com)>
To: yak-list <yak-list(at)matronics.com (yak-list(at)matronics.com)>
Craig Payne
=================================== //www.matronics.com/Navigator?Yak-List =================================== cs.com =================================== om =================================== matronics.com/contribution ===================================
draftsjust417(at)gmail.co
PostPosted: Fri Jan 06, 2017 2:21 pm    Post subject: Battery replacement Reply with quote
2-cell plan is working great in my CJ... no issues in 5 years
Justin/N280NC
Craig Payne
Viperdoc
PostPosted: Fri Jan 06, 2017 2:47 pm    Post subject: Battery replacement Reply with quote
Yep. Buy mine from Battery Source for about $132 for the pair. Chunk them after two-three years.
Doc
Craig Payne
Viperdoc
wlannon(at)shaw.ca
PostPosted: Fri Jan 06, 2017 8:51 pm    Post subject: Battery replacement Reply with quote
Craig;
I have settled on the Panasonic LCX1228P, 12V Valve regulated lead acid. 28 Amp/Hrs. Whole lot of overkill but will out last typical Gill or Concord at least 3 lo 1.
Fits nicely in the CJ battery box – see pics.
In customers CJ (NO battery minder and at least twice inadvertently discharged –switch on) Still strong at sale of A/C after 9 years.
On my CJ. going on 6 years, with a battery minder (type recommended by Mark Bitterlich) I have not seen a no-load voltage less than 26.5. With almost constant de-sulphiding and trickle charge I would not be surprised if they lasted 20 years.
Walt
Sent: Friday, January 06, 2017 12:15 PM
To: yak-list (yak-list(at)matronics.com)
Craig Payne
www.avast.com
 Filesize:  324.15 KB
 Viewed:  18302 Time(s)
 Filesize:  325.94 KB
dougsappllc(at)gmail.com
PostPosted: Fri Jan 06, 2017 9:16 pm    Post subject: Battery replacement Reply with quote
Craig,This may interest you considering your past penchant for po-boy mods.
http://www.instructables.com/id/How-to-Turn-Spare-Pocket-Change-into-DIY-Batteries/
Keep us in the loop as to your success. Surprised)
Doug
On Fri, Jan 6, 2017 at 8:50 PM, Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
Craig;
Walt
Craig Payne
www.avast.com
