gilles.thesee(at)free.fr Guest
Posted: Wed Jan 04, 2017 11:22 am Post subject: Rotax 912iS questions |
Hi all,
Presently considering the wiring of a Rotax 912iS in a friend's composite project.
The engine features a digital fuel injection with high pressure fuel pumps, digital control "lanes", backup power circuit, dual alternator with control box etc.
The Rotax Installation manual calls for a certain number of panel switches : | Quote: |
Pump A and B switches (permanent) : 10 A each
Lane A & B switches (permanent) : 7.5 A each
Engine Control Unit start power switch (momentary) : 20 A
Backup battery switch (permanent) : 20 A |
QUESTION : is it advisable to bring such heavy current carrying wires to the panel, or would it be preferable to use relays to control the system ?
Any input appreciated,
Thanks in advance,
Best regards,
Gilles
http://contrails.free.fr
http://lapierre.skunkworks.free.fr
ceengland7(at)gmail.com Guest
Posted: Wed Jan 04, 2017 11:49 am Post subject: Rotax 912iS questions |
On 1/4/2017 1:21 PM, GTH wrote:
Hi all,
Thanks in advance,
Best regards,
Gilles
| For me, the decisions were based both on overall weight, and complexity/reliability (yes, I know they aren't necessarily the same thing, but can be related).
How much weight (length has a big influence) will using the heavier gauge wire add, vs the added weight of the relay? How much reliability will you sacrifice by adding a relay and all the extra terminations required?
Even 20 A is not that big a deal for the proper switch. Going bigger than that, a relay starts to look more attractive, especially since the automotive world now makes fairly light weight, high current relays available for very reasonable prices.
Posted: Thu Jan 05, 2017 2:26 am Post subject: Rotax 912iS questions |
Le 04/01/2017 à 20:49, Charlie England a écrit :
Charlie and all,
Thank you to everyone who responded, on the list and in PM !
Actually my concern is the high amperage in the fuel pumps and the digital lanes wires. All those electrons flowing to and from the panel just to keep the engine running, considering the avionics in the vicinity...
Maybe relays or contactors for the 20 amp circuits...
Those injection engines are a bit complicated to manage : 5 switches to fumble with in addition to the regular master and starter switches just to start the engine.
Lots of thinking to simplify the task of the pilot and avoid forgetting something or manoeuvring the switches in the wrong sequence...
Thank you for your attention, and please keep giving advices, this is a great help !
Best regards,
Gilles
Posted: Thu Jan 05, 2017 10:13 am Post subject: Rotax 912iS questions |
At 04:25 AM 1/5/2017, you wrote:
| Quote: | Le 04/01/2017 à 20:49, Charlie England a écrit :
Charlie and all,
Is there a down-loadable copy of the installation manual
for your system? The REAL concerns have little to do
with switch ratings, wire sizes or breakers/fuses.
The elegant solution considers failure modes (including
risk of pilot error) . . . this is a system integration
issue . . . a skill seldom demonstrated by folks who
manufacture and market airplane parts.
After FMEA is done, you NEED to know the ENERGY
requirements for each accessory and anticipate the
combinations in which those accessories are needed
after loss of a single accessory for any reason.
This is called LOAD ANALYSIS and it sets the sizes
of alternators, batteries, circuit protection, wires,
and yes . . . switches. Switches are last on the list
of concerns. Many individuals in the OBAM aviation
community get wrapped around the axles of AC vs. DC
ratings, slow vs. fast break mechanisms, etc. etc.
The underlying motivation being "nothing is too
good for my airplane . . . and after all . . .
it IS an airplane . . . everybody knows that
things breaking on airplanes comes with risks
for spiraling out of the sky trailing smoke."
The realities are not nearly so exciting. See
http://tinyurl.com/jfr8zzu
The bottom line demonstrates that IF your
FMEA is artfully conducted and IF your energy
budgets are KNOWN and MAINTAINED, likelihood of
an electrically induced bad day in the cockpit
is vanishingly low.
Let's pray over the manufacture's data a bit
to see if there's enough data to move your
deliberations forward with confidence.
www.avast.com
rlborger(at)mac.com Guest
Posted: Thu Jan 05, 2017 10:42 am Post subject: Rotax 912iS questions |
The 912iS installation manual (along with all other manuals for all Rotax engines) is available at:
http://www.rotax-owner.com/en/support-topmenu/engine-manuals
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On Jan 5, 2017, at 12:11 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
At 04:25 AM 1/5/2017, you wrote: | Quote: | Le 04/01/2017 à 20:49, Charlie England a écrit : | Quote: | | Even 20 A is not that big a deal for the proper switch. Going bigger than that, a relay starts to look more attractive, especially since the automotive world now makes fairly light weight, high current relays available for very reasonable prices. | Charlie and all, Thank you to everyone who responded, on the list and in PM ! Actually my concern is the high amperage in the fuel pumps and the digital lanes wires. All those electrons flowing to and from the panel just to keep the engine running, considering the avionics in the vicinity... Maybe relays or contactors for the 20 amp circuits... Those injection engines are a bit complicated to manage : 5 switches to fumble with in addition to the regular master and starter switches just to start the engine. Lots of thinking to simplify the task of the pilot and avoid forgetting something or manoeuvring the switches in the wrong sequence... | Is there a down-loadable copy of the installation manual for your system? The REAL concerns have little to do with switch ratings, wire sizes or breakers/fuses. The elegant solution considers failure modes (including risk of pilot error) . . . this is a system integration issue . . . a skill seldom demonstrated by folks who manufacture and market airplane parts. After FMEA is done, you NEED to know the ENERGY requirements for each accessory and anticipate the combinations in which those accessories are needed after loss of a single accessory for any reason. This is called LOAD ANALYSIS and it sets the sizes of alternators, batteries, circuit protection, wires, and yes . . . switches. Switches are last on the list of concerns. Many individuals in the OBAM aviation community get wrapped around the axles of AC vs. DC ratings, slow vs. fast break mechanisms, etc. etc. The underlying motivation being "nothing is too good for my airplane . . . and after all . . . it IS an airplane . . . everybody knows that things breaking on airplanes comes with risks for spiraling out of the sky trailing smoke." The realities are not nearly so exciting. See http://tinyurl.com/jfr8zzu The bottom line demonstrates that IF your FMEA is artfully conducted and IF your energy budgets are KNOWN and MAINTAINED, likelihood of an electrically induced bad day in the cockpit is vanishingly low. Let's pray over the manufacture's data a bit to see if there's enough data to move your deliberations forward with confidence.
This email has been checked for viruses by Avast antivirus software. www.avast.com
Posted: Thu Jan 05, 2017 1:06 pm Post subject: Rotax 912iS questions |
Le 05/01/2017 à 19:11, Robert L. Nuckolls, III a écrit :
of concerns. | Hi Bob,
Thank you for responding.
I tried to follow this approach of system integration, and after some hard thinking we had a 2-day meeting with my partners playing the "what if" game and establishing the corresponding load analysis.
Thanks Bob B for the link. I would also suggest downloading the Operator's Manual to have a look at the starting and holding point sequences. Seems akin to rigging a nuclear sub for dive...
Many opportunities to forget something or doing the wrong manoeuver.
I have some ideas for combining some functions and rendering pilot error less likely, though it implies more complexity than the rudimentary circuit proposed by Rotax (with some errors in their schematics).
I would add that the Aeroelectric community is a tremendous help. Peer review and critique of ideas or architectures are invaluable.
Please Bob and everyone, keep up the good job !
And BTW our two battery, Rotax 914 four-seater is still going strong after 12 years !
Thank you,
Best regards,
Gilles
Posted: Fri Jan 06, 2017 8:21 am Post subject: Rotax 912iS questions |
At 02:22 PM 1/5/2017, you wrote:
| Quote: | At 12:38 PM 1/5/2017, you wrote:
Thanks! |
Oh . . . fooey. For all the skills, time and
effort Rotax put into the rest of this product,
the wiring diagrams are . . . well . . .
My teachers held that a schematic should be
all revealing. The architecture, functionality
of each conductor, pin connection and component
should just 'jump off the page' at you. This
philosophy was practiced in every job I've
ever held.
I'm disappointed to find that the published
drawings in the installation manual do not
lend themselves well in this regard.
It would take too much time and perhaps
consultation for me to achieve a functional
understanding of the Rotax system at the
engineer/integrator level.
So, getting back to the original questions
on switches . . . ANYTHING B&C sells in the
way of switches is entirely adequate to
the task. Some of the 12AWG wire called out
is 'overkill' but not harmful.
I wish I could be more helpful but getting
conversant with the designer's intent
using only these drawings is like
looking for a black cat in a coal mine with
a candle.
www.avast.com
Posted: Fri Jan 06, 2017 3:11 pm Post subject: Rotax 912iS questions |
Le 06/01/2017 à 17:19, Robert L. Nuckolls, III a écrit
| Quote: | Oh . . . fooey. For all the skills, time and
They were not good at making diagrams back in the 914 days, but it seems they didn't improve since then...
I'll try to re-draw a simplified version of their proposed architecture to help clarify some of my future questions.
the task.
So can we consider there is no problem bringing the two permanent 10 amp pump wires and the two 7.5 amp "lane" wires to the panel ?
Thank you for your help, no doubt I'll have many more wiring questions about this very peculiar engine.
Best regards,
Gilles
Joined: 28 Mar 2008 Posts: 1969 Location: Riley TWP Michigan
Posted: Fri Jan 06, 2017 8:45 pm Post subject: Re: Rotax 912iS questions |
| Quote: | So can we consider there is no problem bringing the two permanent 10 amp pump wires and the two 7.5 amp "lane" wires to the panel ?
| Designing an aircraft is full of compromises. Running always hot wires to the instrument panel makes the engine circuits more reliable and simpler. On the other hand, if one of those wires starts smoking or if a forced landing is imminent, they can not be disconnect from the battery.
_________________ Joe Gores |
Posted: Sat Jan 07, 2017 11:31 am Post subject: Rotax 912iS questions |
Le 07/01/2017 à 14:49, Robert L. Nuckolls, III a écrit :
| Quote: | | Quote: |
Sure . . . I wouldn't add relays to the
system to keep panel currents low. This
just drives up parts count and offers
little if any benefit. |
Bob and all,
Thank you.
Attached is a drawing of how I understand the Rotax schematics. Hope it'll get through.
At least it helps me better understand the starting sequence (5 switches in addition to the master switches and start button).
Please feel free to comment and point me to errors.
Thanks for everything,
Best regards,
Gilles
 Download |
| Filename: |
Rotax_wiring_redraw_01.pdf |
18.38 KB |
| Downloaded: |
393 Time(s) |
Posted: Sat Jan 07, 2017 5:18 pm Post subject: Rotax 912iS questions |
Le 07/01/2017 à 20:29, GTH a écrit :
Please feel free to comment and point me to errors. |
Hi all,
Sorry, I just found a mistake : the starter contactor was misplaced ;-(
Here is a more correct version.
Best regards,
Gilles
 Download |
| Filename: |
Rotax_wiring_redraw_02.pdf |
18.65 KB |
| Downloaded: |
444 Time(s) |
