art(at)zemon.name Guest
Posted: Mon Dec 26, 2016 7:06 pm Post subject: Securing Split PVC Conduit |
Folks,
I am using some split PVC conduit in my plane and two of the runs are pretty close to vertical, about 4 feet long. Sitting in my garage, with the wires not yet secured at the bottom, the conduit keeps trying to slide downward in the 2 inch square channels through which it runs. I think that I ought to secure it somehow and wonder if you have any ideas that will keep it in place.
Maybe I can wrap a thin cable tie around it and get it to slip into a groove?
Or maybe wrap it with silicone self-sealing tape and the put an AN742 clamp around it?
-- Art Z.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
Joined: 28 Mar 2008 Posts: 1972 Location: Riley TWP Michigan
Posted: Tue Dec 27, 2016 6:18 am Post subject: Re: Securing Split PVC Conduit |
Is conduit necessary inside of a channel?
_________________ Joe Gores |
Posted: Tue Dec 27, 2016 6:44 am Post subject: Securing Split PVC Conduit |
When there are sharp things sticking into the channel, yes
On Tue, Dec 27, 2016 at 8:18 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Is conduit necessary inside of a channel? |
neal.george(at)gmail.com Guest
Posted: Tue Dec 27, 2016 9:13 am Post subject: Securing Split PVC Conduit |
A dab of RTV?
Neal George
[quote] On Dec 26, 2016, at 10:05 PM, Art Zemon <art(at)zemon.name> wrote:
Folks,
halbenjamin101(at)gmail.c Guest
Posted: Tue Dec 27, 2016 11:31 am Post subject: Securing Split PVC Conduit |
Hi Art,
You could probably use safety wire wrapped around the split loom and hang it using tape to hold the safety wire.
Hal Benjamin RV4
Folks,
holger-d(at)shadowbrush.c Guest
Posted: Tue Dec 27, 2016 3:07 pm Post subject: Securing Split PVC Conduit |
I’ve used lacing tape for that purpose in the past. So friendly to do-overs.
Holger
| Quote: | On Dec 26, 2016, at 7:05 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
Folks,
ashleysc(at)broadstripe.n Guest
Posted: Fri Dec 30, 2016 8:26 am Post subject: Securing Split PVC Conduit |
Hi Neal and Art;
Google "wire ties with mounting holes."
Morris Products makes several types.
Cheers! Stu.
Sent: Tuesday, December 27, 2016 9:11:53 AM
Subject: Re: Securing Split PVC Conduit
A dab of RTV?
Neal GeorgeSent from my iPhone
On Dec 26, 2016, at 10:05 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
| Quote: | Folks,
-- Art Z.
Posted: Sun Jan 01, 2017 11:36 am Post subject: Securing Split PVC Conduit |
Holger,
I think this will work perfectly. Thank you! The lacing will slip into the grooves on the conduit. I can attach nylon cable tie anchors to the airplane and lace the conduit to the anchors.
-- Art Z.
On Tue, Dec 27, 2016 at 5:04 PM, Holger Selover-Stephan <holger-d(at)shadowbrush.com (holger-d(at)shadowbrush.com)> wrote:
| Quote: | I’ve used lacing tape for that purpose in the past. So friendly to do-overs.
Holger
Folks,
Posted: Sun Jan 01, 2017 3:32 pm Post subject: Re: Securing Split PVC Conduit |
Clean the aluminum with solvent prior to sticking on the cable tie mounts or else they will eventually fall off.
