Deems Davis
acs(at)acspropeller.com.a Guest
Posted: Thu Jul 06, 2006 9:55 pm Post subject: Here I go again - console finished |
Hey Deems,
That is one mighty console effort. Well Done!
Did you choose the Lancair panel specifically to install the OP gear?
John #315 do not archive
wayne.e(at)grandecom.net Guest
Posted: Fri Jul 07, 2006 2:35 am Post subject: Here I go again - console finished |
Hi Deems,
Your console and your panel look fantastic!! I wish I had your talent for fabricating things.
Wayne Edgerton 40336
bcondrey
Posted: Fri Jul 07, 2006 5:23 am Post subject: Here I go again - console finished |
Very nice!
Bob #40105
Firewall fwd and paint prep
Deems Davis
Posted: Fri Jul 07, 2006 9:00 am Post subject: Here I go again - console finished |
Sort of, I saw a pic of the panel on Henkejen's kitlog site, e-mailed
him to find out where he got it, then called Aerotronics, where I talked
to Gary Wirrell, who offered to do a graphic layout to see if it would
fit, (I think he was aiming at selling me more than just the panel),
when he e-mailed back the layout that sort of sealed the deal.
Deems Davis # 406
Fuse
http://deemsrv10.com/
John Dunne wrote:
Hey Deems,
Robin Marks
Joined: 10 Jan 2006 Posts: 24 Location: San Luis Obispo, CA
Posted: Tue Jul 11, 2006 9:47 am Post subject: Here I go again - console finished |
Deems,
Can you give us the rough pricing on the panel and center
console from Aerotronics? Less electronics... It helps me to start
choking early on the panel, motor & prop so that when it's time to write
the check I am already resigned to coughing up the $. Oh and BTY your
panel looks sharp.
Robin Marks
RV-4 Sold
RV-6A 300 Hours
RV-10 Full QB to be delivered this week.
_________________ RV-4 Sold
RV-6A 0-360 - C/S Flying |
Tdawson(at)avidyne.com Guest
Posted: Tue Jul 11, 2006 9:53 am Post subject: Here I go again - console finished |
Robin:
Our kit came with a perfectly serviceable panel made of aluminum, God's
favorite material, included in the price! : )
TDT
40025
Painfully slowly working on wiring and firewall forward
Deems Davis
Posted: Tue Jul 11, 2006 10:10 am Post subject: Here I go again - console finished |
The Aerotronics panel is $600 (just the fiberglass portion), the Center
console is something that I made myself, I have about $200-250 + into
it for materials. Labor = priceless
Deems Davis # 406
Fuse/Finishing
Robin Marks wrote:
Deems,
panel looks sharp.
Robin Marks
RV-4 Sold
RV-6A 300 Hours
Rick S.
Posted: Tue Jul 11, 2006 10:23 am Post subject: Here I go again - console finished |
Deems,
Are you going with the throttle quadrant? And is there room to place switches and or maybe the trransponder in your console?
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
Posted: Tue Jul 11, 2006 10:31 am Post subject: Here I go again - console finished |
We made an AL center console from the panel down to the tunnel and it's
got room for an SL15, SL30, GX60, and a GTX330 transponder, so there
should be room for such things . . .
TDT
40025
Rick S.
Posted: Tue Jul 11, 2006 10:49 am Post subject: Here I go again - console finished |
Tim,
I've been thinking about doing something similar. The aluminum may be easier to finish off with the materials Abby supplys as well. Do you have any dimensions or pic's?
Rick S.
40185
RV-10
40185 |
Deems Davis
Posted: Tue Jul 11, 2006 11:00 am Post subject: Here I go again - console finished |
I'm going w/ the vernier controls, I had the 'big plane feel' on 2
Barons with the quadrants and while it made me feel more like an airline
jockey, I always missed the precision of the vernier controls
(especially on landings) that I had w/ the Bonanza, so I'm swallowing my
ego and going back to the vernier controls. There's plenty of room for
transponder,autopilot/switches or ? in the console, in fact the past
couple of day's I've been noodling around the center stack arrangement,
the radios and transponder are over 11" deep and not withstanding the
mod that I already made to the fwd fuse ribs, will require a cutout in
the sub-panel to allow for their depth. This has some influence over
where the various components get placed in the stack, so I've been doing
the 'cut-n-paste' routine with the various components to see which works
best. I'm also reconsidering the 3 steam gages. John Cox pointed out
that since they are 'back-up' instruments that they should not occupy
such expensive panel real estate (ie. they are high and prominent). so
I've been experimenting there also, additionally, I'm thinking about
scraping the steam gages and putting in a Dynon -10A for back-up, for
slightly more $'s I get 7 more instruments. Decisions, decisions,
decisions.....
btw Rick, Thanks for the info re th CH sticks Kevin sent me a sample for
a test fit, and it turns out that they do indeed interfere with the
panel in the most fwd position, BUT, I like them sooooooo... much I'm
looking for a welder that can cut and reweld the sticks so that the
upright portion is about 20 degrees back, which should give me the
clearance I need.
Deems Davis # 406
Fuse
Rick wrote:
Deems,
Rick S.
40185
LloydDR(at)wernerco.com Guest
Posted: Tue Jul 11, 2006 11:48 am Post subject: Here I go again - console finished |
Can't you just get a muffler shop that has a bender to flex the curve
for you? I too bought the Ch sticks, so I am waiting to see how you fix
it....
Dan
40269
Posted: Tue Jul 11, 2006 11:52 am Post subject: Here I go again - console finished |
Saw an inch or two off the top of the stick? Or is then too short?
TDT
40025
Rick S.
Posted: Tue Jul 11, 2006 12:00 pm Post subject: Here I go again - console finished |
Deems,
Make sure when you redo those sticks that you get enough aft stick if your going to move the grip back. If I recall on my flight, darn near full aft stick was needed on the flare so make sure "you" meaning your body doesn't stop that from happening. How much forward motion have you lost with the stick hitting the panel? Does it hit the elevator stops? Like you, my HS is not mounted yet to check but someone may be able to tell you how far forward from plumb the stick moves before hitting the stop.
Besides you will only need full down for the outside loop.
Rick S.
40185
RV-10
40185 |
Deems Davis
Posted: Tue Jul 11, 2006 12:34 pm Post subject: Here I go again - console finished |
That's a good suggestion, I wonder if bending the curved portion of the
stick might shorten the 'throw' on the aft end, because it would bump
into the seat structure sooner? I'll have to do some eyeballing of that
possibility.
THANKS
Deems Davis # 406
Fuse
it....
Dan
40269
Deems Davis
Posted: Tue Jul 11, 2006 12:37 pm Post subject: Here I go again - console finished |
Another good suggestion, I think I'll remount the HS and an elevator to
find out if this is a real or perceived problem. (The size of my gut is
real, the amount of elevator throw is perceived.
THANKS
Deems
Rick wrote:
Deems,
Rick S.
40185
Tim(at)MyRV10.com Guest
Posted: Tue Jul 11, 2006 1:08 pm Post subject: Here I go again - console finished |
I'm sure this decision is too late for you Deems, as you made your
beautiful console, but, for the other list people....
I am finding that the quadrant control is very smooth and precise
and I can pinpoint my RPM and MP much closer using the quadrant
than I did with N220RV with the vernier for my transition training.
I know vernier is normally the way to go for precise control,
but I can definitely tell you that I had a much-less-than-perfect
experience with the vernier in that RV-10, but from day one
I've had great precision with mine. So don't let the lack
of smooth and precise power/mix/prop control steer you away
from a quadrant....I found it to be the opposite. I'm sure that
things such as where the linkage attaches to the lever, and
the quality of the control can have a huge factor in this, but
this quadrant is great....far better than the one that
was in my Beech.
If anyone has any doubts, just come on over to KLUM on the
weekend before OSH and I'll let you do a little flying
to see for yourself. You just have to help me get the bugs
off it before I leave for the show.
Deems Davis wrote:
decisions.....
clearance I need.
Deems Davis # 406
Fuse
Rick wrote:
> Deems,
> Rick S.
> 40185
Posted: Tue Jul 11, 2006 1:17 pm Post subject: Here I go again - console finished |
Hey, shouldn't that thing be called a "trident", not a "quadrant"?
Oops, maybe not:
2. A machine part or other mechanical device that is shaped like a quarter circle.
TDT
johnwcox(at)pacificnw.com Guest
Posted: Tue Jul 11, 2006 3:27 pm Post subject: Here I go again - console finished |
Waiting for a specific time slot and I will pay for the AVGAS. You have
my schedule.
John - N49CX
Do not Archive
