CJ panel blank
jonboede(at)hotmail.com
PostPosted: Wed Nov 30, 2016 5:55 pm    Post subject: CJ panel blank Reply with quote
Looking for a panel blank for the CJ front panel. Also, if anybody has CAD files for the panel or any of the stock instruments, please contact me.
Jon
jblake207(at)comcast.net
PostPosted: Thu Dec 01, 2016 6:47 am    Post subject: CJ panel blank Reply with quote
While we're on the subject of panels... I'm planning to pull my front panel for repaint over the Holidays. Anyone got any advice? JB
To: yak-list(at)matronics.com
Sent: Wednesday, November 30, 2016 7:54:21 PM
Subject: CJ panel blank
--> Yak-List message posted by: Jon Boede <jonboede(at)hotmail.com>
= & -Matt Dralle, List ==========
kelmonroe(at)comcast.net
PostPosted: Thu Dec 01, 2016 6:55 am    Post subject: CJ panel blank Reply with quote
Replace the rubber mounts at the same time.
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of JON
Sent: Thursday, December 01, 2016 8:47 AM
To: Yak-List <yak-list(at)matronics.com>
Subject: Re: CJ panel blank
From: "Jon Boede" <jonboede(at)hotmail.com (jonboede(at)hotmail.com)>
--> Yak-List message posted by: Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)>
cjpilot710(at)aol.com
PostPosted: Thu Dec 01, 2016 11:29 am    Post subject: CJ panel blank Reply with quote
Think about power coating you color on.
Pappy
In a message dated 12/1/2016 9:48:17 A.M. Eastern Standard Time, jblake207(at)comcast.net writes:
Yakjumper
PostPosted: Fri Dec 02, 2016 12:55 am    Post subject: Re: CJ panel blank Reply with quote
Hi,
just made a new instrument panel for my Yak52 to cover all the unused holes. My scanner was too small, so I took a picture of the panel and used it as a backdrop to draw the new panel in vector format. The original instruments are very easy to measure and draw, you can find templates for western instruments on the web. Draw one and copy/paste most of them.
I installed a GRT Mini, since the original horizont was missing.
Had the panel cut on a waterjet including all screw holes.
Using ie. Illustrator or a CAD programm, whatever you like. The waterjet needs a DXF. Just a few hours of work if you start from scratch.
Picture shows work in progress, center main panel is new. I am considering moving to new torx screws, the original russian ones are hard to find, esp. new.
Used std spray paint. A more durable paint would be nice, anybody out there with powder coating ? How does it look after some time ?
 Filesize:  233.66 KB
 Viewed:  7527 Time(s)
PostPosted: Fri Dec 02, 2016 5:35 am    Post subject: CJ panel blank Reply with quote
WRT painting... Several years ago, I used a spray can of pick up truck bed liner (black) on my C172 panel. I liked the textured look and durability. Saw the old airplane a couple years ago and the panel still looks great after 20 years. Planning to remove the panel in my CJ this winter and anticipate doing the same unless someone here presents a better idea. JB
Sent: Friday, December 2, 2016 2:55:13 AM
--> Yak-List message posted by: "Yakjumper" <tobias(at)macnews.de>
Hi,
http://forums.matronics.com/viewtopic.php?p=463618#463618
http://forums.matronics.com//files/panel_116.jpg
&nbsbsp; -Matt Dralle, List Adm=========
PostPosted: Fri Dec 02, 2016 9:12 am    Post subject: CJ panel blank Reply with quote
Ordinary spray 1 step is the cheapest way but will scratch easily. You could use a 2 part epoxy system spray on product. I had mine powder coated. It make for a very hard and beautiful surface. One draw back. Many panels are part of the grounding for the electrical system and items that may need a ground on the panel. I had a problem where my gear lights were not working. The grounding turned out to be though the mounting screws of the gear light assembly. After I ran a drill bit though the mounting holes, to break the powder coating (it was acting as an insulator) they started working fine. You may find that with a 2 part epoxy system also.
Jim "Pappy" Goolsby
In a message dated 12/2/2016 3:56:04 A.M. Eastern Standard Time, tobias(at)macnews.de writes:
Hi,
========================nbsp; (And Get Some AWESOME FREE to find Gifts ilder's ELP k you for p; -Matt Dralle, List ======================== e ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - NEW MATRONICS LIST WIKI -_-= - List Contribution Web Site sp;   ===================================================
PostPosted: Fri Dec 02, 2016 10:11 am    Post subject: CJ panel blank Reply with quote
I covered the step sheet along the left wing of my old CJ with truck bed liner and it worked great and lasted forever.
Jon
On Dec 2, 2016, at 7:40 AM, JON <jblake207(at)comcast.net (jblake207(at)comcast.net)> wrote:
From: "Yakjumper" <tobias(at)macnews.de (tobias(at)macnews.de)>
--> Yak-List message posted by: "Yakjumper" <tobias(at)macnews.de (tobias(at)macnews.de)>
Hi,
