CH-701 Fiberglass Wing Tip Fitting Problem
dplozay(at)cox.net
PostPosted: Mon Jul 10, 2006 10:05 am    Post subject: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
Do any of the 701 builders have advise on getting the fiberglass wing tip to fit? I'm having difficulty getting both the bottom and top aft edges of the tip to fit flush with the wing (see photo). I'm beginning to think I was shipped a defective part. All comments are welcome and appreciated.
David
 Filesize:  1.98 MB
 Viewed:  879 Time(s)
naumuk(at)alltel.net
PostPosted: Mon Jul 10, 2006 10:52 am    Post subject: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
Dave-
    Wow- I thought I had problems with my HDS tips! It looks like you either trimmed them too far, or that you got tips for something other than a 701. Check the plans and pictures.
    Also, there's a ton of stuff in the archives from a year or two ago under "Fiberglass Tip Ribs" on how to deal with the miserable SOBs. Rots a ruck!
planejim(at)bellsouth.net
PostPosted: Mon Jul 10, 2006 11:09 am    Post subject: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
David,
I'm helping a friend build a 701. He did the first wing basic structure. I came into the picture to do the wing tip and the wigh root. Fitting the fiberglass tip was a real pain in the #*&%(at) neck. I've done this airplane building a bunch and the tips on my 601HD were much easier than this 701. From what I see in your picture, you will have to really push the fiberglass tip forward a bunch. I found it hard to mark an index point that I could use on the leading edge wing skin and the fiberglass tip for repeatability when fitting. Drilling the rivet holes so that they fell in the center of the radius all the way around took a lot of time.  If I remember correctly ( it's been a couple of months since we built that first wing - haven't done the other one yet ) we had to cut some off the edges, near the top aft end of the Fiberglass tip. It took us more than a half day just to fit and drill up the tip. It looked O.K. when we got done.
When we started, I was sure it would never fit! But we did it. Don't give up.
p.mulwitz(at)worldnet.att
PostPosted: Mon Jul 10, 2006 1:55 pm    Post subject: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
That wing tip looks pretty hopeless to me.  Have you considered laying up a new one?
In one case on my plane (a 601XL) I wound up cutting a slit in the rear half of the fiberglass so I could make it stretch to fit the metal and then laid some new glass and epoxy in the opening.  I only had about a 1/4 inch to fill, but it looks like you have a lot more than that to deal with.
Paul
XL fuselage
David
John Bolding
PostPosted: Mon Jul 10, 2006 2:06 pm    Post subject: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
Nice pic!   Doubt that any parts from the mold that produced this tip will be any different than this one, there is a way to fix it and it will look perfect but is not something I can describe by typing, if you will call me i'll be happy to walk you thru it.
Have done LOTS of FRP work . this isn't a big deal to fix properly.  Kinda gets your juices flowing however when parts you pay good money for don't fit any better than this. email me off list and I'll send you my #   LOW&SLOW   John
jnbolding1"at"teleshare.net (jnbolding1(at)teleshare.net)   replace the "at" with (at)
aircraft(at)czaw.cz
PostPosted: Tue Jul 11, 2006 1:26 am    Post subject: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
Please learn some internet protocol. I am sure some listers have slow dial-up or roaming e-mail and would not appreciate a 2mb photo.
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of David Plozay
Sent: Monday, July 10, 2006 8:03 PM
Subject: CH-701 Fiberglass Wing Tip Fitting Problem
David
TH-SR
PostPosted: Tue Jul 11, 2006 2:10 am    Post subject: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
I agree.
Dave, your problem is real, your picture was great in showing it, and this list is the place to pose the question. However, that size attachment is a killer for those with dial up, and for the list administrator considering space required on his server for archive purposes.
There are several ways to shrink the size of your photos for future posts.  To prove my point, I took the liberty of making a few adjustments to your photo, and have reduced its file size dramatically (2560 KB down to 12 KB) without losing much impact. Feel free to email me off list if you'd like to know how I made the adjustments.
Todd Henning
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Chip W Erwin
Sent: Tuesday, July 11, 2006 4:17 AM
Subject: RE: CH-701 Fiberglass Wing Tip Fitting Problem
David
 Filesize:  11.82 KB
 Viewed:  749 Time(s)
Todd
CH701
Jari Kaija
PostPosted: Tue Jul 11, 2006 2:36 am    Post subject: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
Surely looks like, that you have tip from some other zenair's plane!
http://www.project-ch701.net/ch701_wings/DSC03804.JPG
http://www.project-ch701.net/ch701_wings/DSC03805.JPG
http://www.project-ch701.net/ch701_wings/DSC03806.JPG
http://www.project-ch701.net/ch701_wings/DSC03807.JPG
http://www.project-ch701.net/ch701_wings/DSC03808.JPG
http://www.project-ch701.net/ch701_wings/DSC03809.JPG
http://www.project-ch701.net/ch701_wings/DSC03810.JPG
http://www.project-ch701.net/ch701_wings/DSC03811.JPG
I ordered mine from "Czech Aircraft Works, s.r.o. (CZAW)"
and they fit perfectly.
rjscep(at)yahoo.com
PostPosted: Tue Jul 11, 2006 4:50 am    Post subject: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
Those photos are perfect, nice closeups and detail.
I will check out that outfit and order mine.Thanx
Bob S.....Do not archive
the fiberglass
both the bottom and
wing (see photo).
part.
zenair's plane!
(CZAW)"
Kemter
PostPosted: Tue Jul 11, 2006 5:04 am    Post subject: Re: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
David,
Out of curiosity was that a factory wing kit or scratch built? Surely those wingtips can't be the correct ones.?.? Thought about sending them back and asking for some new ones?
Jim
Jim Kemter
Cibolo, TX
rstone4(at)hot.rr.com
PostPosted: Tue Jul 11, 2006 7:07 am    Post subject: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
Todd,
     Weather or not David wants to know how to shrink a picture I am sure some of the rest of do so please post this information on the Zenith-List by all means.  Pictures are worth a thousand words and should be used to explain anything compliated however a very large picture takes forever to down load unless one has a high speed server like I do.  I have Road Runner and web sites, attached pictures, etc come up on screen at once, but all members do not have a high speed system.
Bob Stone
admin(at)arachnidrobotics
PostPosted: Tue Jul 11, 2006 7:41 am    Post subject: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
    I'd like to suggest that internet protocol is evolving as quickly as the internet itself.  The Matronics lists are losing people as much for a LACK of visual content (ie-Good Pics) as they would if everyone posted a daily pic.
    I really like the Matronics lists for the advice and camaraderie present, but it's nearly the ONLY aviation list out here that exists almost 100% in text only form.  Hey, radio was good, but TV conveys the message MUCH quicker and with MUCH more clarity.  Even a slow DSL line will download a 2MB image in seconds.
    For those that insist on crawling through the phone lines (or those in technologically challenged countries), a simple adjustment of their email application will maintain this thoroughly frustrating text only experience.
Tom Henderson
McMinnville, Oregon
971-241-5035
Carving out my 601XL from scratch,
Fuselage nearly complete
Chip W Erwin <aircraft(at)czaw.cz> wrote:
<![endif]--> <![endif]--> Please learn some internet protocol. I am sure some listers have slow dial-up or roaming e-mail and would not appreciate a 2mb photo.
David
randy(at)shadycreekoutlaw
PostPosted: Tue Jul 11, 2006 8:31 am    Post subject: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
Speaking of a daily pic:  Here's one I took yesterday that I'm proud of...  Finally, I've completed my spars...  After the attachment holes get drilled through the mains and center spar, I can start assembly!
Randy
XL Wings - Plans Only
http://www.n344rb.com
 Filesize:  58.2 KB
 Viewed:  756 Time(s)
ch601xl(at)gmail.com
I will post how to do this on my site in the next hour or two using a free program with step by step pictures. You will be able to download the program as well.  http://ch-601xl.com
On 7/11/06, Robert L. Stone <rstone4(at)hot.rr.com (rstone4(at)hot.rr.com)> wrote:[quote] Todd,
Bob Stone
PostPosted: Tue Jul 11, 2006 10:02 am    Post subject: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
OK it's up now.
On 7/11/06, Christopher Smith <ch601xl(at)gmail.com (ch601xl(at)gmail.com)> wrote:[quote] I will post how to do this on my site in the next hour or two using a free program with step by step pictures. You will be able to download the program as well.  http://ch-601xl.com
Bob Stone
jf701(at)sbcglobal.net
PostPosted: Tue Jul 11, 2006 7:55 pm    Post subject: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
" Do any of the 701 builders have advise on getting the fiberglass wing
edges of the tip to fit flush with the wing..."
David:
Haven't seen the photo you mentioned, but just about everybody runs into
problems with these wingtips. I decided the main thing is to
make sure you have the tip rotated back far enough so the bottom of the
airfoil remains flat; i.e, the leading edge doesn't sag a little bit at the
end.
On the first tip I did, I got everything cocked around so the skin followed
the fiberglass leading edge perfectly, but I ended up with the wingtip
pointing down just a bit from the rest of the wing. On the next wing, I
made sure the bottom edge was flat and accepted the 1/4" gap
between the skin and the fiberglass that resulted at the nose. Filled it in
with fiberglass filler from West Marine, which works real good for such
things.
As one of the other posters mentioned, a carefully applied heat gun works
great on the fiberglass tip to flex it a little where needed.
John Flavin
Overland Park, KS
CH701 kitbuild--all airfoils and control surfaces done and project in
storage while looking for a new shop.
Rick Roberts
PostPosted: Wed Jul 12, 2006 2:18 am    Post subject: CH-701 Fiberglass Wing Tip Fitting Problem Reply with quote
David,
John and I used the same approach.  My wing tips actually fit pretty well.  I hit a major snag on the slat tips...same approach though....
Low and slow...
DO NOT ARCHIVE
jf701(at)sbcglobal.net wrote:
--> Zenith-List message posted by:
David:
end.
Rick
Sharpsburg, GA. USA
http://www.n701rr.com
Low & Slow,
Rick
Orlando, FL. USA
www.n701rr.com
