Posted: Sun Oct 23, 2016 8:28 am Post subject: NEED HELP... Setting wing incidence on a Mk3 Xtra |
The book says 1.4 degrees, and you say you set it at 3.4 degrees and it won't fit. Why the difference?
On Sun, 10/23/16, dirtracin <igetthebug(at)gmail.com> wrote:
Subject: Re: NEED HELP... Setting wing incidence on a Mk3 Xtra
Date: Sunday, October 23, 2016, 8:40 AM
"dirtracin" <igetthebug(at)gmail.com>
I got that info straight from my manual... I do have
the 11th Mk3 Xtra.. So there maybe some differences from the
newer models... I did set the wings at 3.4 last night which
put me inline with the tab on the wing root but now the wing
root is in contact with the flap tangs that stick out
through the fuselage... And when I moved the wing outward to
clear the flap tangs now the wing root tab that mounts to
the fuselage is to far out to be pinned to the fuselage...
Something is not right!..
http://forums.matronics.com/viewtopic.php?p=461530#461530
http://forums.matronics.com//files/img008_162.jpg
Forum -
- MATRONICS WEB FORUMS -
MATRONICS LIST WIKI -
List Contribution Web Site -
-Matt
Dralle, List Admin.
