Fwd: Re: More HKS Engine Interference Questions
lcottrell
PostPosted: Tue Oct 11, 2016 5:04 pm    Post subject: Fwd: Re: More HKS Engine Interference Questions Reply with quote
---------- Forwarded message ----------
From: Larry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)>
Date: Tue, Oct 11, 2016 at 6:51 PM
Subject: Re: Re: More HKS Engine Interference Questions
To: "kolb-list(at)matronics.com (kolb-list(at)matronics.com)" <kolb-list(at)matronics.com (kolb-list(at)matronics.com)>
Richard and Bill: here is the engine from all sides. Also included are some measurements from the cage to the Prop. It looks to me that a y'ed pipe coming out the back and down most of the way to the boom tube would be quite do'able. Bill If you try it out, keep me posted, I may want to take advantage of who ever does it for you for a pair of my own. I looked around a bit but could not find any pipe set ups that would trail the pipes down the back.Larry
On Tue, Oct 11, 2016 at 6:02 PM, Richard Pike <thegreybaron(at)charter.net (thegreybaron(at)charter.net)> wrote:
--> Kolb-List message posted by: "Richard Pike" <thegreybaron(at)charter.net (thegreybaron(at)charter.net)>
This particular thread has me really interested, even though I don't own an HKS. Larry; can you post a picture or two of your HKS on the airplane? Would like to see it.
The older I get, the less tolerant I am of those who are intolerant of others.
 Filesize:  1.41 MB
 Viewed:  2030 Time(s)
 Filesize:  1.4 MB
 Filesize:  1.43 MB
lcottrell
PostPosted: Tue Oct 11, 2016 5:07 pm    Post subject: Fwd: Re: More HKS Engine Interference Questions Reply with quote
The placement of the muffler causes more problems than it solves. It screws up the wind needed to cool the engine, and slows the plane. I do not know if this engine needs a muffler? ( back pressure etc) If it didn't I would be thinking about collecting the two pipes in the middle between the cage and the prop having it come out below the boom tube. I would still put the oil cooler on the back of the cage however.
> You still may need to cover and funnel the wind over the cylinder heads, if so let me know because I have drawings of the cover needed for that.
> Larry
 Filesize:  1.27 MB
 Filesize:  1.5 MB
