MJKTuck(at)cs.com Guest
Posted: Mon Oct 03, 2016 2:26 pm Post subject: Fuel sight ball |
Does anyone know where I can find a red float ball I can install in the sight gauge fuel line?
Martin Tuck
Europa N152MT
| Quote: | On Oct 3, 2016, at 4:55 PM, Wladimir Kummer <wladimirkummer(at)gmail.com> wrote:
Thanks for all whom replied. I’ll route the fuel lines inside the tunnel from the fuel valve between the seats. I’ll assemble the rudder and connect the cables to check for rubbing before closing the fuse.
Best
Wladimir
spcialeffects
Posted: Mon Oct 03, 2016 10:53 pm Post subject: Re: Fuel sight ball |
Hi Martin. I bought two orange ones from either steinair or wicks if I remember rightly.
Regards Frank kit#165
johnwigney(at)windstream. Guest
Posted: Tue Oct 04, 2016 10:46 am Post subject: Fuel sight ball |
Hi Martin,
Might I suggest another solution. The standard sight gauges for the water level in boilers use a background with angled black and white stripes. Due to refraction, where there is liquid the stripes are reversed which makes it very easy to see the level.
I poked around on Google Images and found one example on a steam locomotive. Simple, effective, cheap and it will work with gasoline. See below.
[img]cid:part1.46B7B59B.83F08B46(at)windstream.net[/img]
Cheers, John
N262WF, XS mono, 912S
Mooresville, North Carolina
ORIGINAL MESSAGE
| Quote: | From: Martin Tuck <MJKTuck(at)cs.com> (MJKTuck(at)cs.com)
Subject: Fuel sight ball
fuel line?
Martin Tuck
Europa N152MT
191.49 KB |
7336 Time(s) |
houlihan(at)blueyonder.co Guest
Posted: Tue Oct 04, 2016 11:42 am Post subject: Fuel sight ball |
Hi John, Martin.
This idea can be found on page 3-4 of the build manual.
No need to reinvent it
Tim | Quote: | On 04 October 2016 at 19:44 John Wigney <johnwigney(at)windstream.net> wrote:
Hi Martin,
Cheers, John
ORIGINAL MESSAGE
fuel line?
Martin Tuck
Europa N152MT
191.49 KB |
7334 Time(s) |
AirEupora
Posted: Tue Oct 04, 2016 3:08 pm Post subject: Re: Fuel sight ball |
I just ordered one from Univair Aircraft Corporation.
Univair.com
U10853-000 Piper Fuel Gauge Float Ball $5.48USD
AirEupora
