Try gear brake pads
riddon(at)sent.com
PostPosted: Fri Sep 02, 2016 2:04 am    Post subject: Try gear brake pads Reply with quote
Can anyone give me the lowdown on replacing the brake pads on my tri gear? I see that there is reference in my owners manual to replacing the friction pads by removing the old ones and riveting on new to the old metal plates. Is it not possible just to buy complete new pads?
Richard Iddon
G-RIXS
fireflier
PostPosted: Fri Sep 02, 2016 3:03 am    Post subject: Try gear brake pads Reply with quote
Hi Richard
Replacing the brake pads is a simple process, each pad held onto the metal back plates with 3 rivets.
When purchasing the brake pad kit from europa you might be asked if it is long rivets or short rivets.
On my tri gear it is the long rivets.
Another worthwhile purchase which makes things a lot easier is to get the brake pad rivet punch and die set. It makes things a lot easier when squeezing the new rivets.
I'm not sure if europa supply new pads already riveted onto the metal back plates. Worth asking if that would be easier for you?
Hope the above info helps.
Donald
G-PUPY
Richard Iddon
G-RIXS
Fireflier
Burrilla
PostPosted: Fri Sep 02, 2016 6:00 am    Post subject: Try gear brake pads Reply with quote
You can get the pads and rivets, mine are the long rivers, from LAS online.
Don't have the part No to hand but they are easy to replace the pads and rivet on the new ones especially with the rivet tool
Alan
G-OBJT
Richard Iddon
G-RIXS
christoph.both(at)acadiau
PostPosted: Fri Sep 02, 2016 7:47 am    Post subject: Try gear brake pads Reply with quote
Can you provide a link to LAS online?
Christoph
Alan
G-OBJT
> Richard Iddon
> G-RIXS
pete(at)lawless.info
PostPosted: Fri Sep 02, 2016 8:02 am    Post subject: Try gear brake pads Reply with quote
https://www.lasaero.com/
Christoph
> Alan
> G-OBJT
> Sent from my iPhone
>> Richard Iddon
>> G-RIXS
davidjoyce(at)doctors.org
PostPosted: Fri Sep 02, 2016 9:56 am    Post subject: Try gear brake pads Reply with quote
Have you compared with Europa supplied pads. Last time I needed some they came within 48hrs and were not expensive, and it is in our general interest to support Europa.
Regards, David Joyce, GXSDJ
On 2016-09-02 16:46, Christoph Both wrote:
--> Europa-List message posted by: Christoph Both <christoph.both(at)acadiau.ca (christoph.both(at)acadiau.ca)>
Christoph
Sent from my iPhoneOn Sep 2, 2016, at 11:00, Alan Burrill <alanb(at)dpy01.co.uk (alanb(at)dpy01.co.uk)> wrote: --> Europa-List message posted by: Alan Burrill <alanb(at)dpy01.co.uk (alanb(at)dpy01.co.uk)> You can get the pads and rivets, mine are the long rivers, from LAS online. Don't have the part No to hand but they are easy to replace the pads and rivet on the new ones especially with the rivet tool Alan G-OBJT Sent from my iPhone
On 2 Sep 2016, at 11:03, Richard Iddon <riddon(at)sent.com (riddon(at)sent.com)> wrote: --> Europa-List message posted by: Richard Iddon <riddon(at)sent.com (riddon(at)sent.com)> Can anyone give me the lowdown on replacing the brake pads on my tri gear? I see that there is reference in my owners manual to replacing the friction pads by removing the old ones and riveting on new to the old metal plates. Is it not possible just to buy complete new pads? Richard Iddon G-RIXS
ttp://www.matronics.com/Navigator?Europa-List
ics.com
.com
.matronics.com/contribution
