rnjcurtis(at)charter.net Guest
Posted: Wed Aug 03, 2016 2:21 pm Post subject: ADS-B Antenna |
I am in the process of gathering information for the installation of an ADS-B in my all wood airplane. The Transponder that I am considering uses 2 antennas for the UAT 978 MHz portion. I am considering using the small rod antenna which is similar to that used for the transponder. Since it is a different frequency than the xponder I will purchase the one specifically for the UAT. I am assuming that it is OK to mount this antenna inside the wood fuselage. Is this correct? Also I believe that it will need a ground plane. Is there a recommended configuration for the ground of this antenna? Would the 2 antennas be set up identically?
Roger
Sent from Mail for Windows 10
Joined: 28 Mar 2008 Posts: 1968 Location: Riley TWP Michigan
Posted: Thu Aug 04, 2016 7:08 am Post subject: ADS-B Antenna |
There was a recent thread about transponder antennas that might help:
http://forums.matronics.com/viewtopic.php?t=16762861&sid=0fdc43cf144daf15623736558e046890
I have read that a transponder antenna may also be used for 978 MHZ.
At the iFly booth in OSH, I was impressed by the pinBuddy dual band ADS-B receiver that is a fraction of the size and uses a fraction of the power of the Stratux.
http://www.uavionix.com/
Joe Gores
             Thanks Joe! I was also at OSH and I am seriously looking at the SkyguardTWX ADS-B unit. It is 2020 compliant, seems to have all the ADS-B features, can be used with your old style mode C transponder, and is reasonable priced.Â
Xmit and receive antennas are not included. They recommend using the 978MHz antenna for the UAT rather than the standard transponder antenna. I believe I will fabricate my antennas since they are simple, using a BNC connector, piece of brazing rod 77mm, and a copper ground plane.
Does anyone have any experience with this device? All comments welcomed.
Roger
Posted: Thu Aug 04, 2016 7:54 am Post subject: ADS-B Antenna |
Xmit and receive antennas are not included. They recommend using the 978MHz antenna for the UAT rather than the standard transponder antenna. I believe I will fabricate my antennas since they are simple, using a BNC connector, piece of brazing rod 77mm, and a copper ground plane. |
Keep in mind that the BNC connector's solder
pot was never intended to be a structural feature.
The moment arm of that antenna mast being buffeted
in the wind imposes a serious stress to the
non-ferrous material . . . which HAS a finite
service life under vibratory stress.
These antennas are not expensive . . .
http://tinyurl.com/zeqau4d
Notice that TED (and others) have
incorporated extra support at the base
of the antenna rod which is, if I recall
correctly, one piece of metal all the way
through. A piece of wire soldered into
the tail-end of a BNC connector will need
some similar attention.
Further, there is little value added for tweaking
the length for 978 Mhz vs. 1050. Recall that
your VHF comm antenna works fine over a range of
118 to 135 Mhz . . . a bandwidth of 7 percent
either side of center. The spread of frequencies
of interest at ADS-B/Xpndr is only 3.5 percent.
Posted: Thu Aug 04, 2016 8:26 am Post subject: ADS-B Antenna |
          You convinced me. I will buy the antennas. In looking
          further on Ebay, the 978MHz antenna is only $½ more
          so I think I will spring for the difference.Â
          I plan to mount these inside an all wood fuselage. Do you
          see any problem with that?
          Roger
Posted: Thu Aug 04, 2016 11:00 am Post subject: ADS-B Antenna |
| Quote: | You convinced me. I will buy the antennas. In looking
Nope. Mount them on circles of aluminum
with a diameter of 6". Mount them pointing
down . . .
