Roland
Posted: Sun Jul 31, 2016 12:46 pm Post subject: Fwd: Re: Cooling issues XS 914 on the ground |
Different David Joyce, there are two
Graham
On Sunday, 31 July 2016, 19:31, Roland <schmidtroland(at)web.de> wrote:
--> Europa-List message posted by: "Roland" <schmidtroland(at)web.de (schmidtroland(at)web.de)>
David, why are you testing the Whirlwind blades? You wrote, that you are satisfied with the Woodcomp. Anyway I would be very interested in the results, especially how/if they improve cooling, since you have a similar setup (I guess there's not such a big difference between Mono and Trigear).
Roland
PH-ZTI
XS TG 914
http://forums.matronics.com/viewtopic.php?p=458979#458979http://www.matronics.com/Navigator?Europa-List> http://foru - NEW MATRONICS LIST WIKI --> http://wiki  tronics.com/contribution" target="_blank">http://www.matronics.com/contri================
kingsnjan(at)westnet.com. Guest
Posted: Mon Aug 01, 2016 2:20 am Post subject: Fwd: Re: Cooling issues XS 914 on the ground |
Hello Frans
Regarding thinner radiators working better than thick ones ....... Does this hold true for radiators of the same area?
Cheers
Kingsley in Oz
Posted: Mon Aug 01, 2016 11:21 am Post subject: Fwd: Re: Cooling issues XS 914 on the ground |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hello Kingsley,
| Quote: | Regarding thinner radiators working better than thick ones .......
The radiator I use has a slightly larger area but it also indirectly
cools the oil. So yes I would say that even with the same area you
would be better of with a thinner radiator. You need air going through
the radiator but the original radiator is simply too thick for the
airspeeds we are using and it almost blocks the air. I don't know
where this design came from, but I have not seen any other airplane in
our speed range which has a radiator that thick. The certified
arplanes which use a Rotax engine all have a thin radiator and almost
no air cooling of the cylinders and none of them have the cooling
problems we have with our Europa's.
To have the radiator in front of the engine also enables you to
"recycle" the air coming out of the radiator to air cool the engine
and to draw away the heat from the exhaust stack for free. Less air
"consumption" means less drag, and you don't need the unsightly and
draggy doghouse anymore because a very small air exit is all you need.
Greetings,
Frans
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.22 (GNU/Linux)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=UxuI
-----END PGP SIGNATURE-----
Posted: Mon Aug 01, 2016 12:43 pm Post subject: Fwd: Re: Cooling issues XS 914 on the ground |
So do you think that, keeping the original cowling and the oil coller you could have a larger thinner rad with the oil coller behind as per the original stock design?
Will
William Daniell
LONGPORT
+57 310 295 0744
On Mon, Aug 1, 2016 at 2:19 PM, Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)> wrote:
| Quote: | --> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)>
Hash: SHA1
Hello Kingsley,
Greetings,
Frans
=UxuI
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
Posted: Mon Aug 01, 2016 7:43 pm Post subject: Fwd: Re: Cooling issues XS 914 on the ground |
Thank you Frans. I wish I was a bit closer to you so I could have a look at your set-up.
Personally I would be hesitant to block off airflow over the engine because in the event of loss of coolant, the fins on the cylinders would be rendered inoperable. I was most grateful for this secondary cooling provided on the Rotax engine when I blew a coolant hose some time ago. The Europa supplied hoses were crap and I have much more confidence in Stefan's silicone hoses.
Thanks again for your much valued wisdom.
Kingsley
Posted: Mon Aug 01, 2016 8:37 pm Post subject: Fwd: Re: Cooling issues XS 914 on the ground |
Hash: SHA1
On 08/02/2016 05:27 AM, Kingsley Hurst wrote:
| Quote: | Personally I would be hesitant to block off airflow over the
The fins on the cylinders will cool only that: the cylinder walls.
They won't cool the cylinder heads. I'm not sure what gain you would
expect from improved cooling of the cylinder walls.
Frans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=RIqi
Hash: SHA1
On 08/01/2016 10:37 PM, William Daniell wrote:
| Quote: | So do you think that, keeping the original cowling and the oil
Might well be possible but I can't guarantee that of course.
Frans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=spMz
ploucandco
Posted: Tue Aug 02, 2016 12:17 am Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground |
| wdaniell.longport(at)gmai wrote: | So do you think that, keeping the original cowling and the oil coller you could have a larger thinner rad with the oil coller behind as per the original stock design?
Karel Vrancken did that on F-PKRL with good results on a 912 powered mono. His cowling intake was also slightly modified.
http://www.jetphotos.net/photo/6024281
Posted: Tue Aug 02, 2016 1:07 am Post subject: Fwd: Re: Cooling issues XS 914 on the ground |
I agree Frans, there will be some heat transfer from the head to thins but not much. Pistons are cooled by the oil.
Graham
Sent from my iPad
| Quote: | On 2 Aug 2016, at 05:34, Frans Veldman <frans(at)privatepilots.nl> wrote:
Hash: SHA1
Frans
=RIqi
Richard Lamprey
Posted: Wed Aug 03, 2016 12:35 am Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground |
Roland, for my Europa Classic monowheel in Kenya, with 912UL, some years back I had a radiator leak on the factory standard radiators (one side). These had never been very good anyway, in Kenya's hot temperatures. The factory did not at that time have replacements, so I made up a template for slightly larger and slimmer radiators, for fabrication by Docking Engineering, located at Silverstone UK... they supply to the racing car industry. The radiators are so efficient that I ended up blanking off large areas just so the engine would operate at minimum 90 degrees, even idling on the ground in Kenya's hot temperatures. Docking still exist, their website is active, although they did not reply when I emailed them last year about making up some spares on the original design...
An alternative solution to your cooling problem?
Best, Richard, Kenya,,
Monowheel Classic, reg 5Y-LRY, 912UL
Roland
Posted: Wed Aug 03, 2016 1:08 am Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground |
Hi Richard,
indeed there are strong hints, that thin radiators cool better than their thick counterparts (as Frans also found out).
But then I might end up with temperatures too low in the cruise and descend, where my current setup is almost perfect. Even on the ground it only went to but not beyond the limits in five years, so a little flap under the tunnel, improvement of the sealing of the tunnel and radiator and removing of the thermostat will hopefully bring the critical few °C and some more margin to get it >99% sufficient even on the ground. And then there is still the Whirlwind-option.....
Thanks anyway!
Roland
PH-ZTI
XS TG 914
h&jeuropa
Posted: Wed Aug 03, 2016 3:20 am Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground |
Roland,
We have noted that the Whirlwind blades cause the door in the center of the cowl to lift slightly in flight which didn't occur with the Warp Drive blades. We attribute this to more air entering the engine compartment.
Our 914 cools properly using the factory supplied firewall forward kit. It is very important to seal all gaps in the cooling duct so that all air must pass through a radiator. We even seal between the bottom of the coolant radiator and the top of the oil radiator with tape.
Jim & Heather
N241BW
rogersheridan(at)mac.com Guest
Posted: Wed Aug 03, 2016 4:12 am Post subject: Fwd: Re: Cooling issues XS 914 on the ground |
Hi Jim,
Do you see any performance difference between the Warp Drive & Whirlwind?
I believe that the Whirlwind blades are not from the same manufacturer as the Whirlwind prop that Kim Prout uses - is that correct?
Cheers,
Roger
| Quote: | On 3 Aug 2016, at 13:20, h&jeuropa <butcher43(at)att.net> wrote:
Roland,
Jim & Heather
N241BW
http://forums.matronics.com/viewtopic.php?p=459147#459147
Roland
Roland
Posted: Wed Aug 03, 2016 5:32 am Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground |
Heather and Jim,
good point to seal all gaps thoroughly - I'll first focus on this. I've already installed an aluminum sheet to press more air through the radiator. Only a very low amount of air goes through a gap below the radiator to the 7-row (!) oil cooler, which won't cause a lot of additional resistance. I've also noticed, that I have a gap between the upper edge of the cooling duct and the lower cowling just below the spinner, which I also have to close....
I have some hope, that the Whirlwinds would also contribute to additional cooling. I think I'll let the Airmaster-dealer make a Quote for me, although I highly appreciate the robustness of the Warp Drive blades.
I'll see if I can add some photos later.
budyerly(at)msn.com Guest
Posted: Wed Aug 03, 2016 12:21 pm Post subject: Fwd: Re: Cooling issues XS 914 on the ground |
To all.
I'm trying to catch up with the list and am a bit distraught.
Cooling of the Woodcomp/Airmaster/Whirlwind/Sensenich/ or a carved baseball
bat propellers, is an interesting argument. In my opinion backed up by
testing of now some 6 different propellers and ten blades, I have found the
following based on the assumptions below:
Assumptions:
The exterior cowl is standard. The round inlet holes are clean and at least
open to the 3 inches. The exit duct is unmodified.
The engine cold air duct installs are stock for both the 912S and 914.
No plenum over the cylinders.
The installation of the coolers is stock to include the 1.5 to 2 inch drop
of the oil cooler.
The duct and radiator and oil cooler sides are sealed to the extent no light
can be seen around the radiators, and only through the fins of the radiator.
(I use a lot of red RTV silicone.)
To the best of ones ability, on visual inspection, air can only go through
the cooling fins.
The sides are sealed very well with cowl seal to the lower cowl.
The gap between the oil cooler and glycol cooler is no more than 1/8 inch.
The forward end of the duct is sealed to prevent airflow blowing up into the
spinner/front of the engine area bleeding off duct pressure.
The cowl inlet has been smoothed to allow a smooth flow inlet.
The metal duct has not been significantly modified in shape or form.
The engine has a 1.2 bar radiator cap is installed, and glycol ratio is a
minimum of 50/50 with Dexcool or similar orange coolant. (Not Evans as the
BTU transfer rate is lower and requires a larger radiator and or higher
volume water pump in the hot Florida climate.)
The #3 exhaust pipe is wrapped with exhaust wrap fiber or a heat shield is
fabricated to reduce radiated heat on the temp probe giving erroneous
results.
The propeller has a twist ratio of about 16 degrees (i.e. root at 16
degrees and tip at zero) which is pretty much common for props suitable for
the Rotax 9 series.
Idle speed on a Rotax is at least 1800 RPM.
Note: Full Synthetic oil (Mobile 1 MX4T) runs a bit cooler than the
Aeroshell Sport +4. It also warms up slower. CHT's are a bit lower with
full synthetic in certain conditions. Could most likely be because the oil
is cooler and running here in The States on Ethanol laced fuel and lower
octane makes less heat. I have insufficient data to confirm.
With the above assumptions satisfied the Europa XS will be able to idle
(1800 RPM) on the ground on a standard day into a light breeze for a
minimum of 20 minutes before glycol temps hit 245F .
With the engine run up to 2500 RPM the time is extended to 25 minutes.
Note: At 245F, at idle, if a shut down is initiated, one rarely hears
boiling on the ground, however, after high power run ups where cylinders and
heads are hot, it is not common if a quick shutdown is made, some boiling
may be heard. This is normal as the boiling point is about 266 F. Read the
ROAN website for more detail.
Technique: With a constant speed propeller, increase the RPM to 2500 and
manually position the prop to a courser setting to drop the RPM back to
about 2000. This really increases the draw.
Note: The propeller pushing air down the inlet does not cool the engine, it
is the prop blast creating a draw around/behind the cowl exit. This is an
undeniable fact. It was proved in the 30's.
Climb out cylinder temperatures will hold at 245F to at least 10,000 feet at
90 knot climb. 245F is my personal max to prevent boiling.
Climb out at 75 knots will eventually creep to above 245 by about 5000 feet
and will continue to climb. I do not recommend climbing below 90 knots
indicated especially at OATs above standard.
Typical problems of the Europa XS:
The glycol cooler is designed for cruise conditions at high power settings.
Not ground operations.
The mono on the ground prevents the XS cowl exit to operate with efficiency.
It negates the draw from the rear of the cowl. See Cooling 101 for cowl
modifications.
The XS cowl overcools at cruise due to its fixed exit.
On the ground, the oil heats so slowly, the CHT is nearly at your max for
takeoff. A flap is a simple fix to block the oil cooler for a faster warm
up and the oil flow stays high.
Note: I'm not a fan of oil thermostats, but they have been used effectively
by some. I have not had good luck with the Aeroshell Sport+4 with
thermostat, but it was OK for the Mobile 1 MX4T.
The 914 turbo and oil tank exacerbates the hot corner formed near the #3
probe. Reflected heat in this corner is relieved by the scoop on the duct,
but that scoop also decreases the delta P on the radiators.
So a quick and dirty to cool better.
Follow Cooling 101 techniques and seal the duct.
Pitch the prop more on the ground to increase airflow.
Mono's can use a wider exit or a mechanically actuated lip on the exit (cowl
flap) to improve ground draw.
Use both the CHT supplied and the pain in the A__ , notoriously inaccurate,
liquid coolant temp probe, to monitor the cooling health of your engine. (I
do not practice this, I just keep head temp below 245.)
Feel free to use tape and formed blocks of foam to make a draggy ramp to
increase the draw out of the rear of the cowl for you mono owners to
experiment.
If you can't help spending money:
A larger radiator is nice, but then you need a thermostat for cruise, or:
Rebuild the cowl and spend many hours to install new ducting, a slightly
larger radiator (about 50% larger is about right), install a movable cowl
flap, on the mono widen the cowl exit to compensate for the blockage with
the gear down...
Thinner radiators are slightly better, but don't confuse thinner with
passage size. Many thinner radiators have smaller cooling tubes requiring
much more surface area. A two inch deep radiator with 1/8 inch by 3 inch
wide tubes and 1/4 inch finned area between with a surface area of about 60
square inches works very well in vehicles as our South African partner found
out. I believe the BTU transfer rates at MoCal. Our motorcycle engine
could use a radiator that is 3+" deep, 5" high and 10" inches wide rather
than our 3" x 3.5" x 10" 8 bar block. Rotax's new radiator is 1.3"x 13" x
5.5" 13 tube which has the same cooling area as our poor old block.
Lockwood Rotax Service prefers the larger version on their aircraft which is
about 2 x 6 x 16 inch 10 tube which cools about any plane, but it runs a
bit cool if ducted in a tight cowl. So the current Rotax Guru's are looking
for a radiator with about 50% more coolant tube volume. So I'm thinking we
need a radiator closer to 6 inches tall with 12 bars and a cowl flap or
thermostat to make an all season no compromises aircraft.
Remember, an airplane is 20,000+ compromises flying in close formation. The
choices on these compromises is yours.
Just my thoughts.
Bud Yerly
Custom Flight Creations.
Absolutely Stock 914 install with various propellers tested.
Roland
Posted: Wed Aug 03, 2016 8:55 pm Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground |
Good morning Bud,
thanks a lot for your detailed answer - very interesting read!
Strange (and good) thing is, that I don't have ANY problems when airborne. I don't come even near 245/118 CHT when climbing 100% 85KIAS in ISA+15 MTOM.
I'm sure now after all those valuable answers (indeed much appreciated!), that I have to further improve the sealing of my cooling duct first and remove the water thermostat. I can do that myself with my limited skills, without spending a lot of money or alter the whole setup and plumbing and then see what happens. I might be one of your best customers, if I lived in Florida
I'll also try to increase the RPM on the ground and set a course pitch if need be.
BTW: I currently - as Remi - don't seem to be able to attach photos to my posts.
Roland
PH-ZTI
XS TG 914
Roland
Posted: Mon Aug 08, 2016 11:53 am Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground |
A little "progress" report:
I closed and sealed the gap between the upper edge of the air inlet and the top of the cooling tunnel and made two 2-hours flights (one low at 2500 ft and the other one high at FL 110). It was - of no avail. Actually I achieved the opposite, namely CHTs of 100°C in the cruise instead of 95°C (decreasing veeery reluctant in the descent) and also higher oil temperatures, reaching almost 130°C in the climb at MTOM 90 KIAS.
I was at the Fly in at Wyk/Föhr EDXY and met two other Europa owners, of which one had a Trigear. I thoroughly inspected his cowling and cooling tunnel, which was a whole lot different to mine. He had a separate opening in the lower cowling under the radiator for the oil cooler and three additional openings with gills (similar style as the ones on the sides of the upper cowling) on top of the cowling just in front of the windscreen. If we meet again I'll make a ground run with his upper cowling that is easily exchangeable.
Every Europa is different indeed - and I'll go on experimenting - maybe I should make the inspection doors on the upper cowling controllable from inside the cockpit for ground operations (a lot of hot air exits them after shut down, when I open them) - I guess I would be the first with that one
Roland
PH-ZTI
XS TG 914
Posted: Mon Aug 08, 2016 12:42 pm Post subject: Fwd: Re: Cooling issues XS 914 on the ground |
Roland,
Send me pictures of your cowl and install when you can.
Normally when folks have problems they have missed something obvious to me
but not to them and I fail to mention it. Again, I fly with a stock set of
parts by the book, in a hotter environment and overcool normally with the
914 with no intercooler. We are missing something that works for me and my
clients but not for you. We do not want that to happen.
Check your exhaust for leaks. If #3 is leaking a small amount the CHT is
off the charts on the ground and is blown away inflight unless it is a
narrow jet that impacts a 912 carb float bowl which makes things really
exciting.
Best Regards,
Bud Yerly
US Europa Dealer.
