Jay Herron
Posted: Fri Jul 29, 2016 4:25 am Post subject: Need recommendation for Lycoming rebuilder near Ohio |
My 801 has a Lycoming O-360 that needs a new oil seal installed behind the prop. It looks like I would need to completely disassemble it to install. It has 1500 hours since overhaul and 3700 hours TT. Anyhow, can someone recommend a mechanic/rebuilder in Ohio? I don't need it certified.
usnret(at)3riversdbs.net Guest
Posted: Fri Jul 29, 2016 7:44 pm Post subject: Need recommendation for Lycoming rebuilder near Ohio |
Crank seal is replaced by removing the prop,,, pull the old seal,,
remove the spring from the new seal, using the seal install tool, it is
stretched over the prop flange ,,,,,,,,, and A&P can do it in about
Thirty minutes after the prop is pulled.
Tom
