Transponder antenna
Steve Kelly
PostPosted: Fri Jul 15, 2016 8:09 am    Post subject: Transponder antenna Reply with quote
I'm at that point where I need to install a transponder antenna on the bottom of my fiberglass fuselage. Research shows differing opinions on several issues.
-Location, For a number of reasons I am limited to the area below the pilot/ copilot seats. Some say thats too close to your body. Some say it doesn't matter. I have read that the radiation pattern from the antenna is horizontal and in the shape of a donut. If this is true then under seat would seem to be a good location. Also, since I need to add a ground plane, would this serve to reflect any radiation?
-Ground plane, I have room for up to a 16" square ground plane. I am unsure as to the size and shape. I have read that if it's round it has to be a certain size, But don't know what that size is. It seems that size doesn't matter as much if its square or octagonal. Also, should I make ground plane as large as I have room for?
The antenna is just the standard post and ball from B&C.
Would appreciate any feedback, Steve
Steve
PostPosted: Fri Jul 15, 2016 8:40 am    Post subject: Transponder antenna Reply with quote
At 11:09 AM 7/15/2016, you wrote:
--> AeroElectric-List message posted by: "Steve Kelly" <amsk22(at)gmail.com>
It doesn't . . . there are no biological hazards associated
with proximity to the transponder antenna.
Sort of . . . it's 'half a donut' . . .
[img]cid:.0[/img]
The ground plane is essential to antenna performance.
It it isn't provided by 'very large' surface areas
like the skin of a metal aircraft, . . .
The RADIUS of a minimal ground plane is equal to the
seated height of the associated antenna. For a transpoder,
this is 5.3" in diameter.
That would be my choice. See chapter 13 of
http://tinyurl.com/pt97pha
 Filesize:  29.75 KB
 Viewed:  23236 Time(s)
Peter(at)sportingaero.com
PostPosted: Fri Jul 15, 2016 12:46 pm    Post subject: Transponder antenna Reply with quote
The maths to figure the size of the ground plane are quite straight forward
when you know that speed of light = frequency x wavelength.
For a transponder 3 x 10^8 m/s = 1090 x 10^6 x wavelength
Wavelength = 3/10.9 = 0.275m (or 10.84")
Most antennas we use are 1/4 wave dipoles, the ground plane should be tuned
to the antenna, so the radius should 69mm, diameter 138mm (5.42").
Peter
Steve Kelly
PostPosted: Fri Jul 15, 2016 5:56 pm    Post subject: Re: Transponder antenna Reply with quote
Thank you. Those are the answers I was looking for.
Steve
Steve
donjohnston
PostPosted: Sat Jul 16, 2016 7:15 am    Post subject: Re: Transponder antenna Reply with quote
Take this with a grain of salt...
I was told that because there are two frequencies involved with the transponder that a ground plane of two different sizes is best. So following that logic, I created an octagon shaped ground plane. I may have misinterpreted the RST document, but it works fine.
http://www.velocity-xl.com/blog/2013/11/07/13-99-transponder-antenna-ground-plane/
PostPosted: Sat Jul 16, 2016 8:49 am    Post subject: Transponder antenna Reply with quote
At 10:15 AM 7/16/2016, you wrote:
--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com>
This is REALLY fine hair-splitting. The signals using
the transponder antenna are not that far apart. Even
if you had access to a %million$ antenna test range
and equipment, you would be hard pressed to detect
and quantify any improvement in performance for having
crafted an 'optimized' ground plane . . . after all,
the real magic in broader bandwidth performance
has more to do with the shape of the antenna as opposed
to its ground plane.
There are much more expensive transponder antennas
out there that do offer wider band width . . . but
if you bought one and installed it, you wouldn't
observe any difference in system performance. I've
offered similar arguments about going with $higher$
batteries to save weight by asking just how much
the expense will shorten your take-off run, increase
your rate of climb, increase your service ceiling?
One might calculate the differences . . . John Q.
OBAM airplane pilot would be hard pressed to fly
two otherwise identical airplanes and tell us
which one has the super-cool battery installed.
Tony Levere was once known to run stripes of Scotch
Tape over the lines of rivet heads on the skins of
his p-38 race plane . . . with a notion of getting
a few more knots out of the machine . . . intuitively
one can 'see' how this might be useful but the
difference would be hard to go measure. Tony did wins lots
of races with his pride and joy . . . but was Scotch Tape
really the tipping force . . . or did more powerful
influences make the difference? We'll nver know.
ashleysc(at)broadstripe.n
PostPosted: Sat Jul 16, 2016 9:06 am    Post subject: Transponder antenna Reply with quote
Hi All;
I'll pose this as a philosophical point, as I am no expert: It would seem, considering no ground plane is required on a metal aircraft, that the only consideration is how small can they be made and still function adequately. In other words, there is no "too big," only "too small." If this is correct so far, it would behoove us to err to the large side.
Cheers! Stu.
Sent: Saturday, July 16, 2016 9:47:11 AM
Subject: Re: Re: Transponder antenna
PostPosted: Sat Jul 16, 2016 9:21 am    Post subject: Transponder antenna Reply with quote
At 12:05 PM 7/16/2016, you wrote:
Hi All;
A ground plane IS required . . . but the airplane IS the ground plane.
The resonant ground plane on a composite aircraft
is the electrical equivalent of an infinite number
of 'antennas' surrounding the base of the radiating
element. Hence, the minimal ground plane is 'tuned'
to the operating frequency.
Either fabricate a tuned ground plane or go with
metal many times larger than the tuned ground plane.
Erring to the 'large' side by smaller factors
is counter productive.
billhuntersemail(at)gmail
PostPosted: Sat Jul 16, 2016 9:36 am    Post subject: Transponder antenna Reply with quote
The belly of a Boeing id a rather large ground plane.
The Dynon Installation Manual was extremely specific about the size of the ground plane being a minimum size and then increments above that... but the increments above the minimum were not defined
Bill Hunter
On Jul 16, 2016 10:11 AM, <ashleysc(at)broadstripe.net (ashleysc(at)broadstripe.net)> wrote:
Hi All;
Cheers!   Stu.
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com (don(at)velocity-xl.com)>
PostPosted: Sat Jul 16, 2016 10:53 am    Post subject: Transponder antenna Reply with quote
Hi Bob;
Possibly I should have said no additional ground plane is required. I expect most understood what I meant. For those who didn't, I offer my apologies.
Concerning the second portion of your comment, I appreciate the distinction you have made. Either use a tuned ground plane, or one much larger.
Cheers! Stu.
PS: I have your manual, and it is invaluable.
Sent: Saturday, July 16, 2016 10:20:22 AM
Hi All;
donjohnston
PostPosted: Sat Jul 16, 2016 2:56 pm    Post subject: Re: Transponder antenna Reply with quote
It cost exactly zero pennies more to create that octagon shaped antenna as opposed to a round one. And it was significantly easier to cut eight straight lines as opposed to a single circle. And it works just fine.
So in this particular case, splitting hairs turned out easier, cheaper (time is money, right?) and maybe a half a hair better.
--> AeroElectric-List message posted by: "donjohnston" <don>
wrmaxwell(at)bigpond.com
PostPosted: Sat Jul 16, 2016 4:01 pm    Post subject: Transponder antenna Reply with quote
While it probably only a matter of academic interest, unlikely to produce any meaningful differences in daily operation, the 2-different size argument should also apply to the vertical radiating element too.
On 17/07/2016 1:15 AM, donjohnston wrote:
--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com> (don(at)velocity-xl.com)
http://forums.matronics.com/viewtopic.php?p=458238#458238
PostPosted: Sat Jul 16, 2016 4:12 pm    Post subject: Transponder antenna Reply with quote
A brilliant deduction. Thank you. Let's go
8-sided per the article's suggestion . . . even
if it does not produce the supposed performance
gain. Reduce cost of ownership is a demonstrable
benefit.
