Curing of Flying Surfaces
tonyvaccarella
PostPosted: Fri Jul 08, 2016 2:08 am    Post subject: Curing of Flying Surfaces Reply with quote
Hello all,
I'm the owner of a conventional tailwheel aircraft I purchased from the USA. This project was started in 1999 and still being built Smile
Not that Im near the finished stage yet but while reading the Builders Manual about finishing the aircraft it states
" The first thing that you need to do with your flying surfaces is port cure them at a temperature between 40-50 deg C. This will improve their strength and cook off any remaining volatiles and moisture withing the epoxy system. "
Just wondering how builders have managed to do this. What equipment that have used and how they have controlled the temperature. What is our opinion about doing this on "old" wings that were completed in about year 2000.
I look forward to your comments
Tony Vaccarella
Sydney
Australia
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
wdaniell.longport(at)gmai
PostPosted: Fri Jul 08, 2016 5:35 am    Post subject: Curing of Flying Surfaces Reply with quote
Tony
I was originally daunted by this but it's actually easy.  I bought some 1mx1m expanded polystyrene and built box/oven 1 x 1 x 2.    this was enough for my foam  flying surfaces flaps, horizontal stab, ailerons.
I used ordinary fan heaters inside the oven and removed the standard thermostat and replaced it with a thermostat from Aircraft spruce calibrated to 40C i think.
I but a baffle in front of the of the fan to ensure that there was no local concentration of heat.
I used a couple of meat thermomenters punched through the polystyrene to monitor the temperature.
Once i worked it out it was a couple of hours to do the job.
Will
William Daniell
LONGPORT
+57 310 295 0744
On Fri, Jul 8, 2016 at 5:08 AM, tonyvaccarella <tony(at)weimagine.com.au (tony(at)weimagine.com.au)> wrote:
--> Europa-List message posted by: "tonyvaccarella" <tony(at)weimagine.com.au (tony(at)weimagine.com.au)>
Hello all,
Tony Vaccarella
Sydney
Australia
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
http://forums.matronics.com/viewtopic.php?p=457901#457901
pete(at)lawless.info
PostPosted: Fri Jul 08, 2016 6:05 am    Post subject: Curing of Flying Surfaces Reply with quote
Hi Tony
I used the exact same method as William.  We happened to have a couple of domestic extractor fans left over from a job and I added those in the oven to make sure the air got well swirled about and there were no local hot spots.
Pete
G-RMAC Classic #109
On 08/07/16 14:33, William Daniell wrote:
Tony
Will
William Daniell
LONGPORT
+57 310 295 0744
--> Europa-List message posted by: "tonyvaccarella" <[url=mailto:tony(at)weimagine.com.au]tony(at)weimagine.com.au (tony(at)weimagine.com.au)[/url]>
Hello all,
Tony Vaccarella
Sydney
Australia
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
tonyvaccarella
PostPosted: Fri Jul 08, 2016 6:45 am    Post subject: Re: Curing of Flying Surfaces Reply with quote
Thanks for the reply.
My problem is (my challenge is) that I have the old classic wing and need to put the entire wing in the hot box. Despite the size, do you consider the principle the same?
Many thanks once again.
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
PostPosted: Fri Jul 08, 2016 7:15 am    Post subject: Curing of Flying Surfaces Reply with quote
When I ask the question a while back some guys who lived in hot countries mentioned that they had built a tent out of black plastic if that helps
William Daniell
LONGPORT
+57 310 295 0744
On Fri, Jul 8, 2016 at 9:45 AM, tonyvaccarella <tony(at)weimagine.com.au (tony(at)weimagine.com.au)> wrote:
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
http://forums.matronics.com/viewtopic.php?p=457918#457918
ptag.dev(at)talktalk.net
PostPosted: Fri Jul 08, 2016 7:47 am    Post subject: Curing of Flying Surfaces Reply with quote
Hi! Will and Tony,
Concerning curing of the Europa.
I notice that it is being suggested that a cure time of possibly two hours was likely.
May I respectfully advise that if you have an aircraft that is glass fibre reinforced with resins laid over polystyrene you need to very slowly increase the heat soak or you will have the polystyrene expand faster than the glass and burst through the construction making you a very unhappy bunny ! Likewise the cooling down cycle needs similar treatment.
Bob Harrison G-PTAG .
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of William Daniell
Sent: 08 July 2016 14:34
Subject: Re: Curing of Flying Surfaces
Tony
Will
William Daniell
LONGPORT
+57 310 295 0744
Hello all,
Tony Vaccarella
Sydney
Australia
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
tonyvaccarella
PostPosted: Fri Jul 08, 2016 7:59 am    Post subject: Re: Curing of Flying Surfaces Reply with quote
Hi William,
That would certainly do it here in Sydney Australia. Thanks for the food for thought.
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
PostPosted: Fri Jul 08, 2016 8:10 am    Post subject: Curing of Flying Surfaces Reply with quote
Tony my hot box was big enough to take the complete classic wing. I did
three sessions, one for each wing and one for all the other bits.
Pete
PS Can't you just wait for the summer and turn the aircon off in the
workshop?
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
PostPosted: Fri Jul 08, 2016 11:14 am    Post subject: Curing of Flying Surfaces Reply with quote
well i didn't know that and all went well so I guess I got lucky either that or the ambient temp here is sufficient.
Tony you can find a pic of my oven in the photos on my website under phots "the Oven"
https://sites.google.com/site/europaconstructionwd/
Will
William Daniell
LONGPORT
+57 310 295 0744
On Fri, Jul 8, 2016 at 10:45 AM, Bob Harrison <ptag.dev(at)talktalk.net (ptag.dev(at)talktalk.net)> wrote:
Hi! Will and Tony,
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of William Daniell
Tony
Will
William Daniell
LONGPORT
+57 310 295 0744
Hello all,
Tony Vaccarella
Sydney
Australia
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
spcialeffects
PostPosted: Fri Jul 08, 2016 1:11 pm    Post subject: Re: Curing of Flying Surfaces Reply with quote
Hi Tony. I did what Bob said and slowly increased the temperature kept it at 50 degrees for about 16 hours then turned off the heaters and left it covered up for about another 10 hours. I too have classic wing and baked everything at once.
 Filesize:  175.85 KB
 Viewed:  12168 Time(s)
 Filesize:  172.39 KB
Richard Lamprey
PostPosted: Sat Jul 09, 2016 5:42 am    Post subject: Re: Curing of Flying Surfaces Reply with quote
Hi Tony,
My Classic (no 168), which I built in Kenya, was the first complete kit (Stages 1,2,3,4) sold by Europe, and as such was airfreighted to Kenya in a long 18' wooden box. For the curing, I reconstructed the box, covered the inner surfaces with thin expanded foam, put in the wings (later fuselage), and left it out in the Kenya sun for 5 days and nights. Temp outside daytime was 28 C, 18 C night-time, inside the box during day up to 43 C. Cured fine. Best, Richard
Classic Kenya, monowheel, 912 ULS, reg 5Y-LRY, 650 hours
rlborger(at)mac.com
PostPosted: Sun Jul 10, 2016 8:40 am    Post subject: Curing of Flying Surfaces Reply with quote
Tony,
Been away on a short vacation via my Europa. You need to finish to enjoy the flying!
Anyway, go to http://www.europaowners.org/main.php?g2_itemId=60876 to see what I did to cure my surfaces. I used two fairly small electric space heaters, one placed low on one end and one placed high on the other. I used an electronic thermometer with two inputs so I could monitor the heat in two locations to confirm proper thermal environment. Darn thing worked great.
Just another idea for you.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Jul 8, 2016, at 5:08 AM, tonyvaccarella <tony(at)weimagine.com.au> wrote:
Hello all,
Tony Vaccarella
Sydney
Australia
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
