Cheap-n-Dirty In-Line ATC
PostPosted: Thu Jul 07, 2016 10:11 am    Post subject: Cheap-n-Dirty In-Line ATC Reply with quote
Needed to add a fuse to a device with limited
space and very low current requirements. Wound
up adding this ATC3 fuse to the gizmo using fast-ons
and heat shrink. While not as robust as a legacy
fuse-holder, the manner in which terminals are
retained in the ATC fuse doesn't raise much concern
for over stressing them with direct support
of 22AWG wire.
[img]cid:7.1.0.9.0.20160707130542.04967e10(at)aeroelectric.com.0[/img]
 Filesize:  127.15 KB
 Viewed:  2870 Time(s)
bob.verwey(at)gmail.com
PostPosted: Fri Jul 08, 2016 1:06 am    Post subject: Cheap-n-Dirty In-Line ATC Reply with quote
That is a really frugal solution, fraught with simplicity and lightness!
On 7 July 2016 at 20:09, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
of 22AWG wire.
Best...Bob Verwey
 Filesize:  127.15 KB
 Viewed:  2861 Time(s)
