Exhaust Springs
dpark748(at)icloud.com
PostPosted: Fri Jul 01, 2016 1:32 pm    Post subject: Exhaust Springs Reply with quote
I recently purchased new Exhaust Springs from CKT out of the 10 supplied I have had three fail within 20 hours. The force needed to install them seems excessive, possibly leading to their failure.
Is anyone else having failures with exhaust springs?
They must be commercially available in 'similar' design ?
Dave Park
pete(at)lawless.info
PostPosted: Fri Jul 01, 2016 1:43 pm    Post subject: Exhaust Springs Reply with quote
Yes. Though the last couple I have replaced have now done 50 hours +.
I wish I could find the original style "double" springs as supplied by
Europa.
Pete
G-RMAC
Dave Park
PostPosted: Fri Jul 01, 2016 1:54 pm    Post subject: Exhaust Springs Reply with quote
Can you expand on the double springs, I am not familiar with them. It's worth chasing up?
Dave
Dave Park
On 1 Jul 2016, at 22:41, Pete Lawless <pete(at)lawless.info> wrote:
Yes. Though the last couple I have replaced have now done 50 hours +. I wish I could find the original style "double" springs as supplied by Europa.
Pete
G-RMAC
> Dave Park
> Sent from my iPad
kheindl(at)msn.com
PostPosted: Fri Jul 01, 2016 5:20 pm    Post subject: Exhaust Springs Reply with quote
Look at Demon Tweeks, part no.SC62
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of david park <dpark748(at)icloud.com>
Sent: 01 July 2016 22:53:23
Subject: Re: Exhaust Springs
--> Europa-List message posted by: david park <dpark748(at)icloud.com>
Dave
Dave Park
> --> Europa-List message posted by: Pete Lawless <pete(at)lawless.info>
> Pete
> G-RMAC
>> Dave Park
>> Sent from my iPad
st Email Forum -
pa-List">http://www.matronics.com/Navigator?Europa-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
p; - NEW MATRONICS LIST WIKI -
matronics.com
p; - List Contribution Web Site -
p;   -Matt Dralle, List Admin.
aspenbuild(at)me.com
PostPosted: Fri Jul 01, 2016 11:27 pm    Post subject: Exhaust Springs Reply with quote
David,
Give Martin at CKT a ring. I had the same issue with springs supplied from them, excessive pull required to fit them indicates wrong ones.
Richard
Dave Park
PostPosted: Fri Jul 01, 2016 11:54 pm    Post subject: Exhaust Springs Reply with quote
Hi Dave
They are a similar design to those used in the tail wheel steering, only
much smaller. They were shipped with the original exhaust back in about 99.
Pete
Dave
Dave Park
> Pete
> G-RMAC
>> Dave Park
>> Sent from my iPad
PostPosted: Sat Jul 02, 2016 12:30 am    Post subject: Exhaust Springs Reply with quote
Roger
Dave Park
On 2 Jul 2016, at 08:26, Richard Scanlan <aspenbuild(at)me.com> wrote:
David,
Richard
> Dave Park
> Sent from my iPad
grahamsingleton(at)btinte
PostPosted: Sat Jul 02, 2016 1:02 am    Post subject: Exhaust Springs Reply with quote
Dave
Check the holes in the exhaust headers, they probably need deburring? Have a look at the failure point on the  spring, is it fatigue or does it look as though it has been eroded?
Graham
On Saturday, 2 July 2016, 9:30, david park <dpark748(at)icloud.com> wrote:
--> Europa-List message posted by: david park <dpark748(at)icloud.com (dpark748(at)icloud.com)>
Roger
Dave Park
On 2 Jul 2016, at 08:26, Richard Scanlan <aspenbuild(at)me.com (aspenbuild(at)me.com)> wrote:
--> Europa-List message posted by: Richard Scanlan <aspenbuild(at)me.com (aspenbuild(at)me.com)>
David,
Richard
> On 1 Jul 2016, at 22:31, david park <dpark748(at)icloud.com (dpark748(at)icloud.com)> wrote:
> Dave Park
> Sent from my iPad
&gics.com/Navigator?Europa-List" target="_blank">http://www.matronics.com/N= - MATRONICS WEB FORUMS========================http://www.ma======================
PostPosted: Sat Jul 02, 2016 1:35 am    Post subject: Exhaust Springs Reply with quote
Karl the very things!  Thanks
Pete
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) <owner-europa-list-server(at)matronics.com> (owner-europa-list-server(at)matronics.com) on behalf of david park <dpark748(at)icloud.com> (dpark748(at)icloud.com)
--> Europa-List message posted by: david park <dpark748(at)icloud.com> (dpark748(at)icloud.com)
Dave
Dave Park
> On 1 Jul 2016, at 22:41, Pete Lawless <pete(at)lawless.info> (pete(at)lawless.info) wrote:
> --> Europa-List message posted by: Pete Lawless <pete(at)lawless.info> (pete(at)lawless.info)
> Pete
> G-RMAC
>> Dave Park
>> Sent from my iPad
st Email Forum -
ums.matronics.com
matronics.com
PostPosted: Sat Jul 02, 2016 1:48 am    Post subject: Exhaust Springs Reply with quote
Thanks, ordered.
Dave Park
Dave Park
On 2 Jul 2016, at 10:34, Pete Lawless <pete(at)lawless.info (pete(at)lawless.info)> wrote:
Pete
Dave
Dave Park
> Pete
> G-RMAC
>> Dave Park
>> Sent from my iPad
st Email Forum -
ums.matronics.com
matronics.com
BobD
PostPosted: Sun Jul 03, 2016 11:00 am    Post subject: Re: Exhaust Springs Reply with quote
Just a tip for fitting the springs.
I refitted my silencer last week, after removing it to replace all the hoses. It was a real struggle to get the spring back on over the hook, by using long nose vice grips to pull it up and over the hook. I found it much easier to compress the springs by inserting a screwdriver in the bottom of the spring, and pushing upwards to compress the spring, and then slip the top loop over the hook, rather than using the vice grips to pull the spring upwards and over the hook.
Unfortunately, I only discovered this on the last spring ! Rolling Eyes
Bob Dawson
Europa XS TG || 912 ULS || G-NHRJ || Dynon Skyview || PilotAware || SmartAss3
PostPosted: Sun Jul 03, 2016 11:48 am    Post subject: Exhaust Springs Reply with quote
Bob and All
An easier way; make a loop of locking wire about 3" long, hang it over the hook
at one end of the spring with the other end of the spring installed on the exhaust. Now its easy to grab the loose end of the loop with a mole grip or your locking wire pliers and pull the hook up to the loop on the exhaust.
Actually I think I hooked it to the top loop then pulled it down.
Graham
On Sunday, 3 July 2016, 20:18, BobD <rjd(at)bobdawson.plus.com> wrote:
--> Europa-List message posted by: "BobD" <rjd(at)bobdawson.plus.com (rjd(at)bobdawson.plus.com)>
Unfortunately, I only discovered this on the last spring ! [Rolling Eyes]
Bob Dawson
http://forums.matronics.com/viewtopic.pmatronics.com/Navigator?Europa-List" target="_blank">http://www.matronicsp; &nhttp://========================
carlp101
PostPosted: Sun Jul 03, 2016 1:07 pm    Post subject: Re: Exhaust Springs Reply with quote
Guys,
Try this method I thought of whilst struggling to remove and re-fit my exhaust one night in the hangar. You can position the exhaust exactly where you need it with all the springs located, then just snip the tie-wraps. It save on skin and bad language.
All the best.
Carl
 Filesize:  344.55 KB
 Viewed:  8804 Time(s)
ward.t(at)xtra.co.nz
PostPosted: Sun Jul 03, 2016 1:47 pm    Post subject: Exhaust Springs Reply with quote
To stop the disintegration of springs I was told to rub heat resistant sealant (red stuff forgot name)on the springs once sprung. Mine have lasted 13 years.
TIM
On 4/07/2016, at 9:07 AM, carlp101 <cparkinson(at)cisc-uk.com> wrote:
Guys,
All the best.
Carl
http://forums.matronics.com/viewtopic.php?p=457695#457695
http://forums.matronics.com//files/compressed_spring_168.jpg
