Oil temps
civengpe
PostPosted: Tue Jun 14, 2016 6:02 am    Post subject: Oil temps Reply with quote
The other thread talking about cowl flaps got me rethinking another kind of cooling issue that I am having. I can't get my oil temps to climb above 140. It doesn't matter how hot it is outside or how long I climb, they top out right at 140. Could this be caused by me having a plenum and having too much air flow through the oil cooler?  The probe registers ambient temperature correctly when not running, so it seems to be accurate in that regard. Can a faulty vernatherm cause this?
Any ideas?
Shannon
partner14
PostPosted: Tue Jun 14, 2016 6:27 am    Post subject: Oil temps Reply with quote
I wouldn't believe the 140.
Sent via the Samsung Galaxy S® 6, an AT&T 4G LTE smartphone
-------- Original message --------
Date: 6/14/16 7:02 AM (GMT-07:00)
Subject: RV10-List: Oil temps
Any ideas?
Shannon
Don A. McDonald
40636
jesse(at)saintaviation.co
PostPosted: Tue Jun 14, 2016 6:32 am    Post subject: Oil temps Reply with quote
Run it into a pot of boiling water and see what it reads. First thing is to verify the probe is working correctly.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
Any ideas?
Shannon
Mauledriver(at)nc.rr.com
PostPosted: Tue Jun 14, 2016 7:41 am    Post subject: Oil temps Reply with quote
In non-summer conditions I had the same problem - just couldn't get the
oil temp up to the minimum.
It seems that the combination of running less oil (6-7 quarts) and
blocking some of the airflow to the cooler with a plate installed in the
engine shroud fixed it. I don't recall ever changing the oil temp probe.
No change is required for NC/FL summers but I do reduce the size of the
blocking if I remember and run another quart of oil in summer.
Bill "found the stock setup to run very cool except for the tunnel" Watson
Any ideas?
Shannon
Albert Gardner
PostPosted: Tue Jun 14, 2016 12:39 pm    Post subject: Oil temps Reply with quote
I added another opening on each side to improve oil cooling. I also have an additional oil cooler. Seems to be good enough now for Yuma's hot, hot weather.
Albert Gardner
RV-10 N991RV
Yuma, AZ
 Filesize:  23.15 KB
 Viewed:  4732 Time(s)
RV-9A N872RV
RV-10 N991RV
