jeff(at)westcottpress.com Guest
Posted: Wed Jun 08, 2016 6:05 am Post subject: Tools for Oil Change |
What tools and things should I have on hand for an oil change? I've just hit the 10 hour mark and really don't want to make a mess of things in my nice clean engine compartment.
Jeff Carpenter
40304
Westcott Press
1121 Isabel Street
Burbank, CA 91506
jeff(at)westcottpress.com (jeff(at)westcottpress.com)
818-861-7300
rene(at)felker.com Guest
Posted: Wed Jun 08, 2016 6:44 am Post subject: Tools for Oil Change |
Good luck with that. I have used the plastic bag technique with some success…..and some failures. Place a plastic bag around the filter and hold it up against the engine. Spin off the filter and let it drop in the bag. Wipe off the little bit that drips off onto the engine.
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jeff Carpenter
Sent: Wednesday, June 08, 2016 8:05 AM
Subject: Tools for Oil Change
Jeff Carpenter
40304
Westcott Press
1121 Isabel Street
Burbank, CA 91506
818-861-7300
schmoboy
Posted: Wed Jun 08, 2016 7:14 am Post subject: Tools for Oil Change |
I use a Form-A-Funnel under the filter when spinning it off. Awesome
product.
http://www.formafunnel.com/
Can't remember where I actually bought it.
Sean
#40303
| Quote: | Jeff Carpenter <mailto:jeff(at)westcottpress.com>
June 8, 2016 at 9:04 AM
Jeff Carpenter
40304
cooprv7(at)yahoo.com Guest
Posted: Wed Jun 08, 2016 7:17 am Post subject: Tools for Oil Change |
I second Rene’s technique with the bag, and the fact it doesn’t always work as things can go bad quickly if the bag moves away. I’ve had better luck using ziplock bags as there is more rigidity where I hold it up against the engine side of the flange. Putting a number of paper towels under the oil filter helps save the day if oils seeps out. Poking a hole in the filter and rotating the hole to the bottom side helps empty a lot of the oil that would otherwise want to run all over your firewall/nosegear before you remove the filter.
Marcus
On Jun 8, 2016, at 10:44 AM, Rene <rene(at)felker.com (rene(at)felker.com)> wrote:
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Jeff CarpenterSent: Wednesday, June 08, 2016 8:05 AMTo: rv10-list(at)matronics.com (rv10-list(at)matronics.com)Subject: Tools for Oil Change
Jeff Carpenter
40304
Westcott Press
1121 Isabel Street
Burbank, CA 91506
818-861-7300
Posted: Wed Jun 08, 2016 7:20 am Post subject: Tools for Oil Change |
You can also punch a small hole on the 'top' side of the filter to let air in so it'll drain some of the oil trapped in the filter. Put a piece of tape over the hole when you remove the filter .... and use the bag. You'll have the cowling off to get to the sump drain so that leaves the floor to catch the drips ...
Linn
On 6/8/2016 10:44 AM, Rene wrote:
| Quote: | <![endif]--> <![endif]-->
Rene'
801-721-6080
Jeff Carpenter
40304
Westcott Press
1121 Isabel Street
Burbank, CA 91506
[url=mailto:jeff(at)westcottpress.com]jeff(at)westcottpress.com (jeff(at)westcottpress.com)[/url]
818-861-7300
deej(at)deej.net Guest
Posted: Wed Jun 08, 2016 7:50 am Post subject: Tools for Oil Change |
On 06/08/2016 11:10 AM, Sean Stephens wrote:
product.
Sean
#40303
Highly second this recommendation. I bought mine through Amazon and it
does wonders for keeping things clean. They have various sizes. This
is the one I bought:
https://www.amazon.com/gp/product/B003V9L16Y/
I put it under the oil filter to direct the runoff.
-Dj
Dj Merrill - N1JOV - EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
jchang10
Posted: Wed Jun 08, 2016 7:52 am Post subject: Tools for Oil Change |
Interesting at the various methods used. I found that a simple plastic
container, like an old butter container, fit perfectly to catch the oil
from the oil filter. It fits nicely on top of the fuel pump and is
captured by a couple of hoses in the area. I have never had a drop of
oil spill out.
Of course, do NOT forget to remove the butter container. I actually did
this once. 25 or 50 hours later, I discovered the butter container
sitting there. Oooops! However, amazingly, no oil spilled out. Someone
was looking out for me and no aerobatics.
http://2.bp.blogspot.com/-DR9062f8seI/TteXJ9cAIvI/AAAAAAAAANM/cJNp08E4Ijk/s1600/reskem-crazy-sample-contain.jpg
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
_________________ #40533 RV-10
Phase 1 Done 11/26/2011 |
jchang10
Posted: Wed Jun 08, 2016 7:56 am Post subject: Tools for Oil Change |
Forgot to mention, that i never had much luck with the quick drains.
Personally, i would not bother. I had one of the quick drains break. I
dont like them. The hose you have to use, creates more of an oily mess
than anything. The less *stuff* you get oil on, the better, i think.
I let the oil drain into a 5 gallon bucket raised up closer to the
engine. Do the butter catcher thing. Replace the filter. Replace drain
plug. Then add new oil. Done.
flysrv10(at)gmail.com Guest
Posted: Wed Jun 08, 2016 8:53 am Post subject: Tools for Oil Change |
A quick drain plug and a hose is also helpful in keeping things clean.
| Quote: | On Jun 8, 2016, at 11:51 AM, Jae Chang <jc-matronics_rv10(at)jline.com> wrote:
Interesting at the various methods used. I found that a simple plastic container, like an old butter container, fit perfectly to catch the oil from the oil filter. It fits nicely on top of the fuel pump and is captured by a couple of hoses in the area. I have never had a drop of oil spill out.
Of course, do NOT forget to remove the butter container. I actually did this once. 25 or 50 hours later, I discovered the butter container sitting there. Oooops! However, amazingly, no oil spilled out. Someone was looking out for me and no aerobatics.
#40533 RV-10
gengrumpy
Joined: 07 May 2013 Posts: 131 Location: Tullahoma, TN
Posted: Wed Jun 08, 2016 5:39 pm Post subject: Tools for Oil Change |
Don’t forget to check the sump screen!!!
grumpy
| Quote: | On Jun 8, 2016, at 10:54 AM, Jae Chang <jc-matronics_rv10(at)jline.com> wrote:
Forgot to mention, that i never had much luck with the quick drains. Personally, i would not bother. I had one of the quick drains break. I dont like them. The hose you have to use, creates more of an oily mess than anything. The less *stuff* you get oil on, the better, i think.
I let the oil drain into a 5 gallon bucket raised up closer to the engine. Do the butter catcher thing. Replace the filter. Replace drain plug. Then add new oil. Done.
glastar(at)gmx.net Guest
Posted: Thu Jun 09, 2016 1:06 am Post subject: Tools for Oil Change |
I did my own funnel from a 2" plastic tube a bit of cutting and heating.
Works as expected and a clean engine compartment!
Cheers
On 08.06.2016 17:49, Dj Merrill wrote:
52.94 KB |
14468 Time(s) |
Jim Berry
Posted: Thu Jun 09, 2016 8:30 am Post subject: Re: Tools for Oil Change |
I poke a hole in the top of the filter as mentioned by others, then place a disposable baby diaper under the filter before removing it. It catches any spill. I haven't spilled a drop in several years of using this method.
