Kolb FSll cage dimensions
clanon
PostPosted: Sat Jun 04, 2016 5:22 am    Post subject: Kolb FSll cage dimensions Reply with quote
HI , trying to get the stock dimensions for the Kolb FSll cage ...(length , height ,width)
Any help would be greatly appreciated
Thankz
PS: a drawing would be great too!
Richard Pike
PostPosted: Sun Jun 05, 2016 4:59 pm    Post subject: Re: Kolb FSll cage dimensions Reply with quote
Don't have a drawing, but the length is approximately 94" from just behind the boom through bolt to the bottom front, the width at the cross member directly behind the seat is 25 1/4" outside to outside, and measuring on sort of an angle from the bottom of the fuselage directly below that cross member to the top of the front spar carry through is 45".
Not guaranteed to be exact, only approximate.
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
victorbravo(at)sbcglobal.
PostPosted: Sun Jun 05, 2016 5:52 pm    Post subject: Kolb FSll cage dimensions Reply with quote
If there are specific measurements you want I will be able to go to the hangar Tuesday night and get those measurements.
Bill Berle
On Sun, 6/5/16, Richard Pike <thegreybaron(at)charter.net> wrote:
Subject: Re: Kolb FSll cage dimensions
Date: Sunday, June 5, 2016, 5:59 PM
"Richard Pike" <thegreybaron(at)charter.net>
the width at the upper cross member directly behind the seat
45".
Richard Pike
Kingsport, TN 3TN0
Would you consider yourself to be a good person?
https://www.youtube.com/watch?v=VWcDXT6pH7A
http://forums.matronics.com/viewtopic.php?p=456893#456893
Forum -
   - MATRONICS WEB FORUMS -
MATRONICS LIST WIKI -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
clanon
PostPosted: Mon Jun 06, 2016 1:39 pm    Post subject: Re: Kolb FSll cage dimensions Reply with quote
Thankz , for taking time...guys
As i 've said mostly CAGE 3 views dimensions.
 Filesize:  148.03 KB
 Viewed:  6326 Time(s)
PostPosted: Mon Jun 06, 2016 2:39 pm    Post subject: Kolb FSll cage dimensions Reply with quote
Once again, I will gladly take time to measure anything you need, I will be in my hangar Tuesday night, tell me which measurements you need. I have FireStar kit s/n 636 and cage number F1203
Bill Berle
Date: Monday, June 6, 2016, 2:39 PM
"clanon" <clanon(at)hotmail.com>
http://forums.matronics.com/viewtopic.php?p=456922#456922
Forum -
              -Matt
Dralle, List Admin.
