New panel
groups(at)thegoddards.com
PostPosted: Sat Jun 04, 2016 2:50 pm    Post subject: New panel Reply with quote
I'm planning on changing my panel to get rid of the steam gauges and fit Dynon D180 and D10A units along with tidying up the layout to make it a little more logical. I have tried searching for a drawing of the sub panels but can not find one that has the dimensions. Does anyone have a usable drawing? I also tried the demo of xpanel but the Europa template seems to be way too big (or the instruments are too small) and wondered what software people have used to lay out the panel?
Vince Goddard
G-BWUP ULPower'ed Europa
stranfaer(at)btinternet.c
PostPosted: Sat Jun 04, 2016 3:01 pm    Post subject: New panel Reply with quote
Vince
Buy the aluminium panel blanks from Europa, then use the blanks to lay cardboard actual size mock ups on!
Pic of mine attached
rgds
David
Sent to you by David Joyce
On Saturday, 4 June 2016, 23:51, Groups <groups(at)thegoddards.com> wrote:
--> Europa-List message posted by: Groups <groups(at)thegoddards.com (groups(at)thegoddards.com)>
Vince Goddard"http://www.matronics.com/Navigator?Europa-List" target="_blank">http://wsp; --> <a href="http://www.matronics.com/contribution" target="_bl===
rowlandcarson(at)gmail.co
PostPosted: Sat Jun 04, 2016 11:37 pm    Post subject: New panel Reply with quote
Vince - I laid out my panels using CADintosh. That only runs on Mac, but it can do DXF exports which should be readable by most other CAD applications. Let me know if you would like me to send you the DXF files for the main & radio panels.
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
ploucandco
PostPosted: Sun Jun 05, 2016 12:03 am    Post subject: Re: New panel Reply with quote
Vince, here you are.
Width 27.807"
Height 12.905"
Blue skies, Jacques.
 Filesize:  82.55 KB
 Viewed:  13267 Time(s)
davidjoyce(at)doctors.org
PostPosted: Sun Jun 05, 2016 12:05 am    Post subject: New panel Reply with quote
Vince, You can always do it the pre CAD way - cut your existing panel out where you want the new removable section (with a thin saw), and use the cut out as yourpattern for the new panel. Make paper shapes of dimensions of instruments to go in and play around for best fit. It has worked well for me for three panel designs.
Regards, David Joyce, GXSDJ
On 2016-06-05 08:36, Rowland Carson wrote:
--> Europa-List message posted by: Rowland Carson <rowlandcarson(at)gmail.com (rowlandcarson(at)gmail.com)>
On 2016-06-04, at 23:49, Groups <Groups(at)thegoddards.com (Groups(at)thegoddards.com)> wrote:I have tried searching for a drawing of the sub panels but can not find one that has the dimensions. Does anyone have a usable drawing?Vince - I laid out my panels using CADintosh. That only runs on Mac, but it can do DXF exports which should be readable by most other CAD applications. Let me know if you would like me to send you the DXF files for the main & radio panels.
in friendship
Rowland
| <rowlandcarson(at)gmail.com (rowlandcarson(at)gmail.com)> http://www.rowlandcarson.org.uk
ics.com
.com
PostPosted: Sun Jun 05, 2016 12:11 am    Post subject: New panel Reply with quote
Vince
I have a complete scuttle that was removed from my aircraft if you arrange collection you can have it to play around with and make templates as per the mail from my names sake
Rgds
David Joyce
The other one
On 5 Jun 2016, at 09:05, davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk) wrote:
in friendship
Rowland
ics.com
.com
PostPosted: Sun Jun 05, 2016 1:43 am    Post subject: New panel Reply with quote
Hi Rowland,
The DXF files would be most welcome and also the CADintosh files as I do have a Mac I can use.
Vince Goddard
PostPosted: Sun Jun 05, 2016 1:45 am    Post subject: New panel Reply with quote
Thanks for the kind offer David (the other one) but dumb question what’s a scuttle?
Vince Goddard
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of David private
Sent: 05 June 2016 09:11
Subject: Re: New panel
Vince
Rgds
David Joyce
The other one
--> Europa-List message posted by: Rowland Carson <rowlandcarson(at)gmail.com (rowlandcarson(at)gmail.com)> On 2016-06-04, at 23:49, Groups <Groups(at)thegoddards.com (Groups(at)thegoddards.com)> wrote:
I have tried searching for a drawing of the sub panels but can not find one that has the dimensions. Does anyone have a usable drawing?Vince - I laid out my panels using CADintosh. That only runs on Mac, but it can do DXF exports which should be readable by most other CAD applications. Let me know if you would like me to send you the DXF files for the main & radio panels. in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ...
PostPosted: Sun Jun 05, 2016 1:51 am    Post subject: New panel Reply with quote
Hi David,
I was hoping to design and make the removable sections before taking the panel back out of the aircraft for the rework. If I can printout the sub panels full size then I will try the lick and stick method as it can be a quicker method initially when playing about. Will keep you all update on the progress.
Vince Goddard
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of davidjoyce(at)doctors.org.uk
Sent: 05 June 2016 09:05
PostPosted: Sun Jun 05, 2016 2:21 am    Post subject: New panel Reply with quote
It's the whole unit I removed mine and replaced with a new one as it needed changing pic enclosed for you
[img]cid:3C6D1341-59F5-4D7B-BDFC-6AEF485201A5[/img]Rgds
David
On 5 Jun 2016, at 10:44, Vince (Groups Email) <groups(at)thegoddards.com (groups(at)thegoddards.com)> wrote:
<![endif]--> <![endif]-->
Vince Goddard
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of David private
Subject: Re: Europa-List: New panel
Vince
Rgds
David Joyce
The other one
 Filesize:  126.4 KB
 Viewed:  13258 Time(s)
PostPosted: Sun Jun 05, 2016 9:28 am    Post subject: New panel Reply with quote
Hi David,
When you’ve changed your panel layouts what was involved re the LAA?
Vince Goddard
PostPosted: Sun Jun 05, 2016 11:40 pm    Post subject: New panel Reply with quote
Vince, I believe I got away without calling it a mod, just updating my list of flight instruments and saying no change in weight, but I would ask them or your inspector if in doubt. If you are introducing a removable subpanel for first time I guess they may call that a mod. Regards, David
On 2016-06-05 18:26, Vince (Groups Email) wrote:
Hi David,
When you&rsquo;ve changed your panel layouts what was involved re the LAA?
Vince Goddard
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of davidjoyce(at)doctors.org.ukSent: 05 June 2016 09:05To: europa-list(at)matronics.comSubject: Re: New panel
I have tried searching for a drawing of the sub panels but can not find one that has the dimensions. Does anyone have a usable drawing? Vince - I laid out my panels using CADintosh. That only runs on Mac, but it can do DXF exports which should be readable by most other CAD applications. Let me know if you would like me to send you the DXF files for the main & radio panels. in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ...
pete(at)lawless.info
PostPosted: Mon Jun 06, 2016 11:23 pm    Post subject: New panel Reply with quote
There is a standard mod for replacing the main instrument panel with a removable.
Pete
G-RMAC
On 06/06/16 08:39, davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk) wrote:
Hi David,
Vince Goddard
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)
titouauvray(at)neuf.fr
PostPosted: Wed Jun 08, 2016 12:04 pm    Post subject: New panel Reply with quote
Hello gays, I'm pierre from france,
My english is ready soon perfect😂👌.
I looking to buy a speed kit for my europa xs a second end but clean or new at a good price.
If someboby have a way please to contact me.
Pierre tel: 0033781117272
Email: titouauvray(at)neuf.fr
Ciao la compagnie
Envoyé de mon iPhone
Vince Goddard
