billhuntersemail(at)gmail Guest
Posted: Sun May 22, 2016 11:10 am Post subject: Transponder ADSB Transponder Antenna |
Is it ok to install the ADS-B and transponder antenna in the same location?
I have a composite aircraft and there is a ground plane installed on the floorboard of the real plane and it already has the transponder antenna located there…I would like to install the ADS-B antenna there.
Cheers!!!
Bill Hunter
Posted: Sun May 22, 2016 11:53 am Post subject: Transponder ADSB Transponder Antenna |
Found the answer…the Dynon SkyView manual did not have any reference in the transponder section however in the ADS-B section it has the following:
The SV-ADSB-470 antenna should not be installed within 2 feet (24 inches) of the SVXPNDR-261/262 antenna.
Cheers!!!
Bill Hunter
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of William Hunter
Sent: Sunday, May 22, 2016 12:09 PM
Subject: Transponder ADSB Transponder Antenna
Cheers!!!
Bill Hunter
matronics(at)rtist.nl Guest
Posted: Sun May 22, 2016 12:04 pm Post subject: Transponder ADSB Transponder Antenna |
Those antennas work on the same frequency. Having them right next to eachother will at best overwhelm your ADS-B receiver, and worst case damage it. Most ADS-B receivers have guidelines for minimum distance between those antennas. I would take those guidelines at heart.
Rob
On 5/22/2016 9:08 PM, William Hunter wrote:
| Quote: | <![endif]--> <![endif]-->
Cheers!!!
Bill Hunter
Tim Olson
Posted: Sun May 22, 2016 12:14 pm Post subject: Transponder ADSB Transponder Antenna |
They need to be 5' apart in most cases.
On May 22, 2016, at 2:08 PM, William Hunter <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote:
Cheers!!!
Bill Hunter
peter(at)sportingaero.com Guest
Posted: Sun May 22, 2016 12:22 pm Post subject: Transponder ADSB Transponder Antenna |
Which frequency band will you be using?
Cheers!!!
Bill Hunter
Kellym
Posted: Sun May 22, 2016 6:04 pm Post subject: Transponder ADSB Transponder Antenna |
The Dynon ADS-B transponder is 1090-ES. The receiver is 978.
On 5/22/2016 1:21 PM, Peter Pengilly wrote:
| Quote: | Which frequency band will you be using?
> location?
> Cheers!!!
> Bill Hunter
KCHD |
