Heater vent inlet up vs down
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
recapen(at)earthlink.net
PostPosted: Thu Jul 06, 2006 6:44 am    Post subject: Heater vent inlet up vs down Reply with quote
Fellow listers,
I'm getting ready to install my heater vents on the firewall.
The way I read it, the instructions say 'inlet down'. This means that when you're not using the heater, the hot air is being blown up behind the engine instead of down towards the cowl exit area.
Did I miss something? Does it matter? I would think inlet up.......Did they instruct it the other way for a reason?
Pictures of how folks have already done it would be appreciated. Also, If you did it one way and didn't like it......why?
Ralph Capen
- The Matronics RV6-List Email Forum -
http://www.matronics.com/Navigator?RV6-List
kbob(at)cox.net
PostPosted: Thu Jul 06, 2006 7:26 am    Post subject: Heater vent inlet up vs down Reply with quote
Ralph,
I used the -7 upgrades on the -6A and it has the heater vavle waste exit on the left side. Not sure I'd want to spill oil from the filter into the heater valve...which would happen if it was exit up.
Kelly Patterson
---- "Ralph E. Capen" <recapen(at)earthlink.net> wrote:
Fellow listers,
Ralph Capen
ghfrost(at)earthlink.net
PostPosted: Thu Jul 06, 2006 7:38 am    Post subject: Heater vent inlet up vs down Reply with quote
Ralph,
I put them in with the inlet (actual cockpit outlet) down and have no
problem. I think it might be more of a problem, reversed, with the heat
being trapped up into avionics and instruments. I think it also would
impede the flow away from your possibly cold feet and the cockpit. I
also installed small tributary tubes that work as defrost, which
contrary to some advice, I find necessary in NE Ohio.
George
Fellow listers,
Ralph Capen
HCRV6(at)comcast.net
PostPosted: Fri Jul 07, 2006 9:29 pm    Post subject: Heater vent inlet up vs down Reply with quote
I installed mine with the inlet up so that unused hot air would exit down at the cowl outlet and it works fine.  we have relatively mild temps here in Norcal but I can only crack my heater vent open before it begins to overheat the cabin.
Harry Crosby
RV-6 N16CX, 237 hours
[quote]-------------- Original message --------------
--> RV6-List message posted by: "Ralph E. Capen"
Fellow listers,
Ralph Capen
&g t; >
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
