B and C SD-8 dynamo problem
thomas.n.gautier(at)jpl.n
PostPosted: Mon May 16, 2016 11:12 am    Post subject: B and C SD-8 dynamo problem Reply with quote
I am getting to the final stages of my RV-10 project for which I
selected Z-13/8 as the electrical system model. My system design is
essential identical to Z-13/8 rev Q from Appendix Z Rev.12A change 4,
except that I am using ordinary mags for ignition.
Itıs time to install the SD-8 dynamo on the engine so I finally, some
years after wiring it, got around to testing the control circuit for the
dynamo. I mounted the dynamo in a drill press to operate at about 2400 rpm
and arranged to load the dynamo/control circuit up to a maximum of 8A
using some modified electric toaster heating elements. I started with no
load.
My test set produces no output voltage. When I turn on the drill press
the voltage at the positive terminal of the capacitor rises to 3.1v over a
period of 10 or 15 seconds and stays there. The dynamo is producing over
20vac and the voltage at the negative terminal of the bridge rectifier is
about -13v.
I am in the process of wringing out my circuit construction to find the
problem but I would like your advice on a couple of issues. 1) Can you
suggest a definitive test of the voltage regulator module isolated from
the rest of the circuit? And 2) Can I test the control circuit without the
dynamo, perhaps with a DC supply for input power? If I can test it with DC
what voltage should I use? I imagine 16 or 17 volts would be right for
full 8A load. Would higher voltage be useful for lighter loads? I would
like to stress test my heat sinking arrangement for an hour or two but I
donıt really like the idea of running the dynamo with the drill press for
that long. Also Iıd like to get the dynamo mounted on the engine.
Thanks for any advice you can give me.
Nick Gautier
PostPosted: Mon May 16, 2016 3:45 pm    Post subject: Re: B and C SD-8 dynamo problem Reply with quote
When the dynamo is rotating, both it and the regulator should be outputting voltage, regardless of whether the relay is energized or not.
What regulator are you using? It should be mounted using heat-conductive paste. Is the regulator grounded to the airframe during these tests?
We need to know exactly where both voltmeter leads are connected for each measurement.
The dynamo does not have to be rotating to test the relay. An easy test is to put a 12 volt battery in the aircraft wired according to Z-13/8. Connect a high wattage automotive lamp across the capacitor, then turn the AUX/ALT switch on and off. If the lamp turns on and off, then the relay circuit is working. The relay should always be energized with 12 volts nominal (14 is OK), never with 16 or 17 volts.
The problem might be the test setup and not a component problem. The best test is to install everything and go fly the plane. Stick-on temperature strips can be affixed to the regulator to see how hot it gets.
Joe Gores
PostPosted: Tue May 17, 2016 9:06 am    Post subject: B and C SD-8 dynamo problem Reply with quote
Not all rectifier/regulators will come alive without
having voltage at "both ends" . . . i.e. both
input and output. They need a battery on line
to wake up.
The stock SD-8 R/R is thermally marginal. It will
be replaced with a more robust device shortly.
I'm assembling a drive stand to do detailed
energy studies on a range of R/R options for
all of the B&C PM alternators. Kind of swamped
right now with EMT classes but the drive stand
is about ready to run.
[img]cid:.0[/img]
Please don't take this as any discouragement
for gathering your own data. I'd be pleased
to know your findings. 2400 RPM is a bit slow,
the SD-8 doesn't reach full rated output
below 3900 or so. Getting a grip on those
critters to spin them is a bit of a hassle.
Neal George fixed me up with some OEM mating
parts for the spline. I did find that a 12-point,
socket (11/16?) fits the male spline pretty
well. I have an adapter fabricated from a
socket that I elected not to use for permanent
tooling. You're welcome to it if it's useful
to you.
In any case, I suggest you mock up a complete
alternator-battery-load system. It should
come alive and work for you then.
 Filesize:  76.49 KB
 Viewed:  3669 Time(s)
PostPosted: Wed May 18, 2016 10:27 am    Post subject: B and C SD-8 dynamo problem Reply with quote
Bob and everyone,
Thanks for the replies.
I was aware that the dynamo regulator might not come alive without
power on its output, but I thought that was what the
bridge-rectifier/3K-resistor come-alive circuit in Z-13/8 Rev Q was for. I
canıt say that I understand just how that circuit works with the regulator
module but it reminds me of an old vacuum tube grid leak bias circuit.
Thatıs why I thought the voltage (about -13vdc) at the junction of the
resistor and rectifier would be useful.
I will test a more complete version of my electrical system with the
main battery attached and see if things work better. The best I can do is
3100 rpm for the dynamo but weıll see how that works. Iıll report my
results. I have attached a composite picture of the test set up for those
of you who are interested. The guys at BandC said driving the dynamo from
the outside end wouldnıt hurt it. The big sheet of aluminum is my stand-in
heat sink for the instrument sub-panel in the plane.
Bob, do you have any idea how soon an improved version of the regulator
might be available?
Nick Gautier
Time: 10:06:58 AM PST US
Subject: Re: B and C SD-8 dynamo problem
>the
>the
>DC
>don=B9t really like the idea of running the dynamo with the drill press
>for
to wake up.
Emacs!
to you.
 Filesize:  122.58 KB
 Viewed:  3659 Time(s)
