kirk bellard
Joined: 31 Mar 2016 Posts: 13 Location: breaux bridge la
Posted: Sat May 14, 2016 4:20 am Post subject: contoured seats |
Any suggestions on light weight contoured seats that won't break the bank? Every time I fly for a couple hours my back hurts for a couple weeks, or maybe I just need to improve my landings lol
Richard Pike
Posted: Sat May 14, 2016 5:00 am Post subject: Re: contoured seats |
Very comfortable.
http://oh2fly.net/oldpoops/FSII%20seat%20page.html
Not too complex to make, requires some welding skills.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Sat May 14, 2016 6:13 am Post subject: contoured seats |
Very comfortable.
Richard Pike
Richard P/Kolbers:
We did something similar to Richards seat when we were building Miss P'fer,
my MKIII, back in 1991. The Ultrastar seat was a plastic waiting room chair
seat. I was scrounging around in the attic of Homer Kolb's barn, Kolb
Aircraft Company, and discovered two US seats. Brother Jim welded up the
seat frames and we were in business.
I went a little further with my seat using a trick learned from the JAARS
(Jungle Aviation and Radio Service). One of their pilots had become
paralyzed when the Heliocourier he was flying stalled and crashed on short
final to a jungle airstrip. When the aircraft pan caked in, he was driven
down through the 4130 steel seat frame. To remedy that they installed a
sheet metal pan under the seat. I followed suit.
_________________ John Hauck
Titus, Alabama |
patrickjladd(at)hotmail.c Guest
Posted: Sun May 15, 2016 3:49 am Post subject: contoured seats |
sheet metal pan under the seat. I followed suit.>.
Good thinking John,
It was a long time ago but i am pretty sure that the Light Aircraft
Association under whose rules my Extra was built insisted on a metal pan
under the seat,plus I think, some pretty stiff rubber shock absorbent
material.
Pat
Posted: Sun May 15, 2016 5:33 am Post subject: contoured seats |
Good thinking John,
material.
Pat
Patrick L/Kolbers:
I take no credit for the idea. That belongs to the JAARS Bible translators.
Many years ago at Sun and Fun, I was looking at the JAARS Heliocourier,
serial number 1. First thing I saw was the chromoly tube seat frame legs
were "Z'd" to collapse during a crash. Then one of the JAARS pilots pointed
out the seat pan and shared the story of the crash that paralyzed their
friend.
Heliocouriers and Kolbs have slow flight characteristics in common. Would
have made a neat aircraft to do my long cross country flights in. I could
have slept in the aircraft like an RV. But, I could hardly afford to feed
the 912, much less that hungry Heliocourier. Besides, it was more
satisfying doing it in something I built in my basement.
I never liked the idea of flying on a fabric seat. Especially crashing on a
fabric seat. I can think of many ways to get injured during a crash. I had
a hard seat in my Firestar. First a Ken Brock seat tank, then a jon boat
fishing seat someone gave me. I went with the seat tank to increase my fuel
capacity for cross country flights. It increased my fuel, but cut down on
available space for my camping gear. I had to sling load my sleeping bag
between the main gear legs. We then built an 18 gal 5052 aluminum fuel tank
that fit the area up top and behind the bulkhead. That opened up the bottom
where the plastic tank was located. The plastic seat allowed more room
behind and under the seat, and the sleeping bag got stowed inside the
aircraft. Worked well, but the 5 rib wing was being overloaded and
overworked. Not good. I took care of compensating for extra weight and
stress when I built the MKIII. Much more comfortable feeling when one gets
caught in nasty weather. The MKIII has survived much better than me.
Titus, Alabama |
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Mon May 16, 2016 4:38 am Post subject: Re: contoured seats |
| kirk bellard wrote: | | Any suggestions on light weight contoured seats that won't break the bank? Every time I fly for a couple hours my back hurts for a couple weeks, or maybe I just need to improve my landings lol |
You probably could use a commercial contoured back support cushion on your present seat. For a low budget test, tape a small pillow in place on your seat so that it is located at the small of your back (just above butt) to see if proper support helps - I am sure it will. I have a perfect (for me) back support that I use my car, bought in a discount store and would love to buy a second one if I could find it again. I carved my own foam seat back for my Firestar II to get the best fit & support.
_________________ Jerry King |
mojavjoe
Posted: Tue May 24, 2016 3:43 pm Post subject: contoured seats |
To: "kolb-list" <kolb-list(at)matronics.com>
Sent: Sunday, May 22, 2016 6:58:56 PM
Subject: Re: Re: contoured seats
Kerk
I found some aluminum patio sling chairs (powder coated steel will work, just heaver) at Home Depot. Cut off the legs and in my case I narrowed them by first removing the cloth (it's held in by a spline inside a pocket sown into the cloth that's slipped through a channel in the frame) cutting out a section of each cross member by 2", inserting 3/8 x 4" steel tubes and riveting them back together. The cloth for the seat can be narrowed by sowing a pocket or as I did fold the cloth in the proper place crease it lay the spline against the fold and thread it back into the channel. I used 2" aluminum angle to make hooks for the upper seat bar. The lower seat cross member is slipped behind the lower seat bar with the ends of the seat frame sitting on top held in place with a s/s pipe clamp. I find this seat very comfortable and it's much lighter than any other seat frame I know of. Hope this is of value to you.
Joe
Sent: Saturday, May 14, 2016 9:00:48 AM
Subject: Re: contoured seats
--> Kolb-List message posted by: "Richard Pike" <thegreybaron(at)charter.net>
Very comfortable.
Richard Pike
Kingsport, TN 3TN0
Would you consider yourself to be a good person?
https://www.youtube.com/watch?v=VWcDXT6pH7A
http://forums.matronics.com/viewtopic.php?p=456236#456236
1.22 MB |
10974 Time(s) |
2.74 MB |
10974 Time(s) |
mojavjoe
Posted: Tue May 24, 2016 3:48 pm Post subject: contoured seats |
Kerk
here are the two attachments I couldn't send in my first email
Joe
Very comfortable.
Richard Pike
Kingsport, TN 3TN0
2.19 MB |
10973 Time(s) |
2.1 MB |
10973 Time(s) |
russk50(at)gmail.com Guest
Posted: Tue May 24, 2016 4:41 pm Post subject: contoured seats |
One thing to remember about Kolb seats - if you ever have to deploy a BRS, you will still be coming down pretty fast. Don’t want your spine to poke out of the top of your head!Good to have a metal pan in the seat or some serious cushioning under it
Russ
| Quote: | On May 24, 2016, at 7:42 PM, mojavjoe(at)comcast.net (mojavjoe(at)comcast.net) wrote:
From: mojavjoe(at)comcast.net (mojavjoe(at)comcast.net)To: "kolb-list" <kolb-list(at)matronics.com>Sent: Sunday, May 22, 2016 6:58:56 PMSubject: Re: Re: contoured seats
Kerk
Joe
From: "Richard Pike" <thegreybaron(at)charter.net>To: "kolb-list" <kolb-list(at)matronics.com>Sent: Saturday, May 14, 2016 9:00:48 AMSubject: Re: contoured seats
Very comfortable.http://oh2fly.net/oldpoops/FSII%20seat%20page.htmlNot too complex to make, requires some welding skills.
--------Richard PikeKolb MKIII N420P (420ldPoops)Kingsport, TN 3TN0
Would you consider yourself to be a good person?https://www.youtube.com/watch?v=VWcDXT6pH7A
<IMG_0183.JPG><IMG_0186.JPG>
