cable lengths
dlm34077
PostPosted: Fri May 13, 2016 3:33 pm    Post subject: cable lengths Reply with quote
You might want to special order some cables from aircraft spruce. They make a Teflon core version about $200 each, but you will not have to change them since the internal cores do not melt and become stiff and unmovable. Also add 1-2” to Vans length, better an inch too much than an inch too little depending on your routing. It is a pain to change a cable with the engine in place. Be sure and use the stainless/aluminum fixture to better seal the
FF heat out of the cabin.
Virus-free. www.avast.com
carl.froehlich(at)verizon
PostPosted: Fri May 13, 2016 3:57 pm    Post subject: cable lengths Reply with quote
I still use the Van’s cables but I have always run them inside a small diameter fire sleeve where they pass under the engine – same with the alternator and starter cables. This has worked well over 14 years.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David
Sent: Friday, May 13, 2016 7:33 PM
Subject: cable lengths
Tim Olson
PostPosted: Fri May 13, 2016 5:00 pm    Post subject: cable lengths Reply with quote
This is from my RV-14 install that I just did, it's basically what Carl is talking about.
I got silver firesleeve just like you use on hoses.  1/2" fit well over the cable.
Sealed the ends with high temp RTV.
http://www.myrv14.com/buildlog/20160428/RV14160420-173853-076.jpg
Then on Amazon is this 3/4" silver wrap that says it's good for 1000F continuous,
and 2000F intermittent if I remember right.  The silver does a good job of
rejecting the heat.
I wish I would have done this on my original RV-10 install.
On 5/13/2016 6:54 PM, Carl Froehlich wrote:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
Carl
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of David
Lenny Iszak
PostPosted: Fri May 13, 2016 5:45 pm    Post subject: Re: cable lengths Reply with quote
Just removed my cables. They are all sticky, but the cover at the end of the mixture cable is melted. The next set will be firesleeved as Tim suggested.
Van's cables would have worked just fine if i would have protected them from heat. They used to be nice and smooth for about 20-30 hours.
Lenny
 Filesize:  45.09 KB
 Viewed:  6780 Time(s)
rv10free2fly(at)yahoo.com
PostPosted: Sun May 15, 2016 10:35 pm    Post subject: cable lengths Reply with quote
Do you have any photos of your fire sleeved mixture, throttle and/or pitch cables please?
Would you recommend doing all three?
Warm regards
Patrick
Lenny
http://forums.matronics.com/viewtopic.php?p=456226#456226
http://forums.matronics.com//files/img_9576_377.jpg
PostPosted: Sun May 15, 2016 10:39 pm    Post subject: cable lengths Reply with quote
Please disregard my previous email Tim, thank you for the image.
Have you fire sleeved all three cables?
Warm regards
Patrick
On 14 May 2016, at 10:59, Tim Olson <Tim(at)MyRV10.com (Tim(at)myrv10.com)> wrote:
rejecting the heat.
Carl
Tim Olson
PostPosted: Mon May 16, 2016 1:58 am    Post subject: cable lengths Reply with quote
On the RV10 I believe I did 2 or 3'of them. I can't remember off hand. I would probably do any of them that come within 8-12" of the exhaust. It can't hurt but may help just for longevity: on the RV14 I am doing I did them all for sure.
On May 16, 2016, at 1:35 AM, Patrick Pulis <rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)> wrote:
Warm regards
Patrick
rejecting the heat.
Carl
