Intermittent Alternator Noise
jmjones2000(at)mindspring
PostPosted: Fri Apr 29, 2016 10:25 am    Post subject: Intermittent Alternator Noise Reply with quote
Need help troubleshooting an intermittent noise.
My aircraft is wired per Bob's 13-8 diagram. When the primary alternator (60A Lycoming alternator) is running, all is well. Everything works, the EFII programmer reads 14.3-14.5 volts and the Dynon EMS-D180 reads 13.8.
When I turn off the main alternator and test the B&C-410H there is an intermittent noise (wine and static in the intercom). Associated with the noise is a low voltage indication on the Dynon (11.5 volts) but the EFII programmer still reads 14.3-14.5 volts. After a few minutes, the noise goes away and the voltage comes up to 13.8 on the Dynon. The situation will continue to cycle with no predictable pattern. Every time I get the noise, the Dynon display voltage drops and every time the noise goes away the Dynon display voltage rises.
After performing an hour long test flight on the B&C alternator and watching this cycle, I shut the aircraft down and a fluke meter showed 12.9 volts on the battery.
The regulators are both solid state VR166 as Bob suggests in the Aeroelectric Connection.
Thoughts or suggestions?
Thanks!
Justin
JOHN TIPTON
PostPosted: Fri Apr 29, 2016 11:09 am    Post subject: Intermittent Alternator Noise Reply with quote
What's a 'fluke meter'
----x--O--x----
On 29 Apr 2016, at 07:18 pm, Justin Jones <jmjones2000(at)mindspring.com> wrote:
Thanks!
Justin
PostPosted: Fri Apr 29, 2016 11:22 am    Post subject: Intermittent Alternator Noise Reply with quote
----x--O--x----
It is a Fluke brand digital multimeter.
Justin
> Thanks!
> Justin
lyleapgmc
PostPosted: Fri Apr 29, 2016 11:26 am    Post subject: Intermittent Alternator Noise Reply with quote
Fluke is a brand of a series of multi-meters usually considered to be of
high quality.
----x--O--x----
> Thanks!
> Justin
rene(at)felker.com
PostPosted: Fri Apr 29, 2016 12:12 pm    Post subject: Intermittent Alternator Noise Reply with quote
It is what you call a bad multi-meter when you are in mixed company. Smile
Do not archive.
Rene'
801-721-6080
lyleapgmc
PostPosted: Fri Apr 29, 2016 2:44 pm    Post subject: Intermittent Alternator Noise Reply with quote
It is a meter that measures the number of flukes in a given period of time.
Do not archive.
Rene'
801-721-6080
halbenjamin101(at)gmail.c
PostPosted: Fri Apr 29, 2016 4:07 pm    Post subject: Intermittent Alternator Noise Reply with quote
Fluke is a good meter....Sorta like a Simpson meter was before Bart came along!
[quote] On Apr 29, 2016, at 6:43 PM, Lyle Peterson <lyleap(at)centurylink.net> wrote:
> Do not archive.
> Rene'
> 801-721-6080
PostPosted: Fri Apr 29, 2016 6:37 pm    Post subject: Re: Intermittent Alternator Noise Reply with quote
The vast majority of electrical problems are caused by bad connections. So check every connection for corrosion and tightness.
Try interchanging the two voltage regulators to see what happens.
Joe Gores
ngeorge(at)continentalmot
PostPosted: Sat Apr 30, 2016 8:09 am    Post subject: Intermittent Alternator Noise Reply with quote
Now that's funny...
Neal George
[quote] On Apr 30, 2016, at 2:11 AM, Hal Benjamin <halbenjamin101(at)gmail.com> wrote:
>> Do not archive.
>> Rene'
>> 801-721-6080
JOHN TIPTON
PostPosted: Sat Apr 30, 2016 11:15 am    Post subject: Intermittent Alternator Noise Reply with quote
What's a 'Simpson meter'
----x--O--x----
[quote] On 30 Apr 2016, at 05:08 pm, Neal George <ngeorge(at)continentalmotors.aero> wrote:
Now that's funny...
Neal George
> Sent from my iPad
>>> Do not archive.
>>> Rene'
>>> 801-721-6080
lyleapgmc
PostPosted: Sat Apr 30, 2016 11:43 am    Post subject: Intermittent Alternator Noise Reply with quote
Another brand of meter. The one I have is an analog meter. It is about
3" x 6" x 8" and used those old fashioned carbon zinc batteries.
Alkaline replacements work. They were also considered good meters in
their time. I don't know if Simpson still makes any measuring equipment.
It won't count the number of the Simpson's appearances on TV because I
change the channel before they get to the introductions.
----x--O--x----
> Now that's funny...
> Neal George
> Sent from my iPhone
>> Sent from my iPad
>>>> Do not archive.
>>>> Rene'
>>>> 801-721-6080
kjashton(at)vnet.net
PostPosted: Sat Apr 30, 2016 1:08 pm    Post subject: Intermittent Alternator Noise Reply with quote
Ha! http://www.simpsonelectric.com
On Apr 30, 2016, at 3:13 PM, John Tipton <jmtipton(at)btopenworld.com> wrote:
What's a 'Simpson meter?
