Advise Needed re Cowl Repair
rmhou(at)yahoo.com
PostPosted: Sat Apr 23, 2016 12:19 pm    Post subject: Advise Needed re Cowl Repair Reply with quote
Found this crack post flight today Sad
I have some idea re how to repair it, but like to hear from the list re your experience.
Thanks in advance.
Sent using CloudMagic Email
 Filesize:  15.94 KB
 Viewed:  6505 Time(s)
 Filesize:  24.25 KB
aerostar6
PostPosted: Tue Apr 26, 2016 11:53 pm    Post subject: Re: Advise Needed re Cowl Repair Reply with quote
I had a similar problem last year, albeit a chord wise crack. My problem was the reinforcing tube that runs around the circumference of the leading edge had a crack propagating from one of the holes drilled to allow rivet installation.
The crack had actually fractured through 50% of the tube, allowing the skin to flex and crack. I drilled out the rivets and removed the section of tube which was affected, and cut away a large patch of the skin.
I would like to tell you that I then fabricated a new section of skin/doubler, fashioned it to exactly follow the whole contour and replaced it, but it was well beyond my skills.
I got a mechanic at my airline to take it away and do the honours!
 Filesize:  2.54 MB
 Viewed:  6458 Time(s)
aerostar6
PostPosted: Wed Apr 27, 2016 12:12 am    Post subject: Re: Advise Needed re Cowl Repair Reply with quote
....and here's the finished article.
 Filesize:  1.5 MB
 Viewed:  6451 Time(s)
aerostar6
PostPosted: Wed Apr 27, 2016 12:14 am    Post subject: Re: Advise Needed re Cowl Repair Reply with quote
Oops! Wrong picture, that's another repair - standby.
