Dick Sipp
Posted: Thu Jul 06, 2006 7:40 pm Post subject: Flap position sensor |
I would like to hear from anyone who has mounted a Ray Allan flap position
sensor (POS 12) on the flap system to drive a Ray Allan LED indicator. A
picture or description of where and how you mounted it would be most
appreciated.
Dick Sipp
40065
ScooterF15
Posted: Fri Jul 07, 2006 10:49 am Post subject: Flap position sensor |
Photos attached of my POS 12 mount. I used 2 pieces of .032 angle, one screwed to the tunnel wall and one pop-riveted to the flap actuator. I connected them with a piece of threated model aircraft pushrod with a brass clevis on one end and a Z bend on the other.
You can also see the flap switch I installed for my Advanced Flight Systems AOA Sport systems.
-Jim McGrew
40134
In a message dated 7/6/2006 9:42:21 P.M. Mountain Daylight Time, rsipp(at)earthlink.net writes:
| Quote: | --> RV10-List message posted by: "Richard Sipp" <rsipp(at)earthlink.net>
appreciated.
Dick Sipp
40065 ========================= es Day
--> ================================================== - NEW MATRONICS LIST WIKI -
_-= sp; -> =========================p; - List Contribution Web Site ==================================================
55.78 KB |
585 Time(s) |
49.84 KB |
583 Time(s) |
VHMUM(at)bigpond.com Guest
Posted: Fri Jul 07, 2006 1:21 pm Post subject: Flap position sensor |
Jim those stick on things that hold the wires ...what are they called as I cant seem to find them out here in OZ
regards Chris
Rick S.
Posted: Fri Jul 07, 2006 1:35 pm Post subject: Flap position sensor |
You can get the whole skinny right here....
http://www.mcmaster.com/
goto page 1371
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
acs(at)acspropeller.com.a Guest
Posted: Fri Jul 07, 2006 2:41 pm Post subject: Flap position sensor |
Chris I didn’t see the original post but if you’re referring to the stick on cable blocks that are used in conjunction with the cable ties to tidy up your electrical wiring,
I found the only place to have them was the big auto barns, at least in Brisbane anyway.
John 40315
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris , Susie Darcy
Sent: Saturday, 8 July 2006 7:20 AM
Subject: Re: Flap position sensor
regards Chris
rvbuilder(at)sausen.net Guest
Posted: Fri Jul 07, 2006 3:03 pm Post subject: Flap position sensor |
Be advised that you need to get versions that use industrial adhesive. The kind that you get from a home store have a tendency to let go after a while. Not something you want to have happen in an area of a lot of moving parts.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Dunne
Sent: Friday, July 07, 2006 5:39 PM
Subject: RE: Flap position sensor
John 40315
regards Chris
ScooterF15
Posted: Fri Jul 07, 2006 5:38 pm Post subject: Flap position sensor |
I buy the cable tie mounting bases from Stein Air. http://www.steinair.com/cableties.htm
Jim
In a message dated 7/7/2006 3:23:45 P.M. Mountain Daylight Time, VHMUM(at)bigpond.com writes:
[quote] Jim those stick on things that hold the wires ...what are they called as I cant seem to find them out here in OZ
regards Chris
jeremy.p.harris(at)boeing Guest
We mounted ours in the tunnel near the flap torque tube. We attached a bell crank/control horn fabricated from some light AL angle and held onto the torque tube with a pipe clamp so no additional holes were drilled in the torque tube. The horn was then linked via 1/4 scale (large) RC aircraft push rod to the 1.2" throw Ray allen potentiometer. The ray allen potentiometer was mounted on another peice of angle on the side wall of the inside of the tunnel. You'll have to work the geometry out to get the correct throw on the control horn mounted to the torque tube. We got about 1/4-1/3" up the horn from the surface of the tube to get the 1.2" of throw for full flap movement. There's some pics on the website but they aren't very good. Hope this helps.
Jeremy
http://jharris.net/Aviation/RV_10.htm if you go about 3/4 down the page, click on the picture of the tunnel. The sensor and brackets are on the bottom of the pic (starboard side of airplane).
http://jharris.net/Aviation/Flap%20Position%20Sensors.JPG
Jeremy P. Harris
Ground Based Mid-Course Defense
WSOPS Engineering
The Boeing Company
Washington, DC
Desk: (703) 414-6057
Office: 825B
Huntsville, AL
Desk (256) 464-4530
Cube: 1225
Cell: (703) 627-6500
Fax: (703) 414-6372
MC: 793C-G007
From: Chris , Susie Darcy [mailto:VHMUM(at)bigpond.com]
Sent: Friday, July 07, 2006 5:20 PM
regards Chris
Dick Sipp
Posted: Fri Jul 07, 2006 6:57 pm Post subject: Flap position sensor |
Outstanding Jim, thanks very much.
Dick Sipp
ron.mcgann(at)baesystems. Guest
Posted: Sun Jul 09, 2006 2:58 pm Post subject: Flap position sensor |
Chris - these are readily available from Dick Smith outlets. I soak them in toluene to remove the adhesive and proseal them to the skins/ribs/bulkheads. They ain't going anywhere.
cheers,
Ron
#187 wiring
[quote] -----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Chris , Susie Darcy
Sent: Saturday, 8 July 2006 6:50 AM
regards Chris
Posted: Sun Jul 09, 2006 9:33 pm Post subject: Flap position sensor |
Thanks Ron will have a look .
GenGrumpy(at)aol.com Guest
Posted: Tue Jul 11, 2006 6:12 pm Post subject: Flap position sensor |
Here is how we've mounted the one in N184JM.
The push rod comes from a remote controlled airplane store.
Grumpy #40404
60 days or less to first flight!
73.17 KB |
443 Time(s) |
83.61 KB |
479 Time(s) |
