Capacitance fuel sensors
rick(at)beebe.org
PostPosted: Wed Apr 13, 2016 6:23 am    Post subject: Capacitance fuel sensors Reply with quote
Does anyone have any experience with capacitance fuel sensors? My 2001
GlaStar has them (from a company called Centroid) and they don't seem to
be working right. I'm not sure if there's any troubleshooting I can do
or if just replacing them is the right option. They're supposed to put
out 0 (empty) to 5 (full) volts but one of them seems to be stuck at
4.75 volts. The other fluctuates around semi-randomly so the gauge will
read 1/4 then full then 1/2 and so forth.
If replacement becomes the only option this new system from Belite
caught my eye:
http://www.beliteaircraftstore.com/capacitance-fuel-probes/
Any thoughts on that?
--Rick
speedy11
PostPosted: Fri Apr 15, 2016 8:19 pm    Post subject: Capacitance fuel sensors Reply with quote
Rick -
I installed the Princeton capacitance probes on my RV-8 and they are so unreliable as to be worthless. Their only value is to close the hole cut in the adapter plate to accommodate them.
I have calibrated them a dozen times - emptying the tanks and refilling them to the top one gallon at a time (mine have optional five point calibration). I talked to Advanced Flight Systems (probes display on the AFS monitor) and to Princeton (when I could get them on the phone) and followed their instructions precisely. Out of caution that I might be doing it wrong, I asked a friend to do the calibration without any input from me. The results in all cases were the same and I get fuel gauge indications exactly as you described.
The concept of capaciitance fuel probes is simple and straight forward. They should be simple to setup and should function without malfunction. However, I have not talked to anyone who has good results from a capacitance system.
The Belite probes are interesting in that you can get them in various lengths and they can accept multiple bends. However, that makes me wonder how they can accurately sense the fluid level since the output is linear.
But, I'm not an engineer.
I have a fuel leak at the fuel probes so maybe it is time for me to buy the Belite probes and give them a try. Worst case is I will have exactly what I have now - nothing.
Fortunately, my fuel flow readings are accurate to about 0.2 gallons over a two hour flight. So, I use the fuel flow reading to track my remaining fuel.
We'll be curious to learn what you decide and how well your fuel system works.
Stan Sutterfield
Daytona Beach
caught my eye:
--Rick
donjohnston
PostPosted: Sat Apr 16, 2016 1:07 am    Post subject: Re: Capacitance fuel sensors Reply with quote
speedy11 wrote:
Rick -
It sounds like you had these problems from day one, right?
I have Princeton capacitance probes as well. They work fine with no problems so far.
ceengland7(at)gmail.com
PostPosted: Sat Apr 16, 2016 4:57 am    Post subject: Capacitance fuel sensors Reply with quote
On Sat, Apr 16, 2016 at 4:07 AM, donjohnston <don(at)velocity-xl.com (don(at)velocity-xl.com)> wrote:
--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com (don(at)velocity-xl.com)>
speedy11 wrote:
> Rick -
Uh.....
chaskuss(at)yahoo.com
PostPosted: Sat Apr 16, 2016 6:04 am    Post subject: Capacitance fuel sensors Reply with quote
Rick,
If you are using auto fuel with ethanol in it, the ethanol content will totally mess up the capacitance senders. It's not the fault of the brand you are using or the design of the senders. This is an issue with ALL capacitance fuel sender systems operating in the presence of fuel with ethanol in it. The only cures are to either eliminate the use of ethanol laced gasoline OR to install a set of float style sending units.
speedy11 wrote:
> Rick -
http://forums.matronics.com/viewtopic.php?p=455083#455083
Lists This Month --
Some AWESOME FREE Gifts!)
Raiser.  Click on
more about
Gifts provided
www.buildersbooks.com
              -Matt
Dralle, List Admin.
AeroElectric-List Email Forum -
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
billhuntersemail(at)gmail
PostPosted: Sat Apr 16, 2016 6:44 am    Post subject: Capacitance fuel sensors Reply with quote
Did you bend the probe in the place where it should not be bent?
Bill Hunter On Apr 16, 2016 9:03 AM, "Charlie England" <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
speedy11 wrote:
> Rick -
Uh.....
PostPosted: Sat Apr 16, 2016 1:25 pm    Post subject: Capacitance fuel sensors Reply with quote
Another thought on capacitance probes...
If they never worked right then I would think the probes were bent in the do
not bend area.
If they worked well at one time and are unreliable now then there might be
water in the system.
If they work now but are very inaccurate, did you calibrate them using auto
fuel (or some other liquid) and are now using 100LL (or some other liquid).
When calibrating they need to be calibrated using the liquid you intend to
run. If you change your type of liquid AVGAS/MOGAS/JETA/WATER or other
containments then they will always read wrong.
Cheers!!!
Bill Hunter
rick(at)beebe.org
PostPosted: Sat Apr 16, 2016 5:30 pm    Post subject: Capacitance fuel sensors Reply with quote
I know you may be addressing Stan's issues but some of it may apply to
me. I just bought the plane in December. The seller had bought a
replacement gauge so he knew there was a problem but I don't know for
how long. I tested the installed gauge and it's fine.
No water shows up when I sump the tanks. As far as I know it's never had
mogas in it. Always 100LL. It's very perplexing.
--Rick
not bend area.
Cheers!!!
Bill Hunter
PostPosted: Sat Apr 16, 2016 7:17 pm    Post subject: Capacitance fuel sensors Reply with quote
A capacitance fuel probe is just a small metallic wire sticking down the
center of a larger diameter metallic tube.
Even if you run MOGAS today (or kerosene or water or vodka) it does not
matter next week what happened today once the offending liquid is removed
and the original liquid is installed in the tank.
All the capacitance probes measure is the resistance between an inner
conductor (wire) and an outer tube that is also a conductor because a given
liquid will have a certain resistance between the outer conductor and the
inner conductor and that resistance will change as the liquid in the gas
tank rises up the probe(s) as you fill or empty the tank.
Has your capacitance probes ever read correctly?
If when building the airplane the builder was too cheap to buy 100LL and
used MOGAS or water or beer to calibrate the fuel probes (pouring in 5
gallons at a time...looking at the reading on the fuel gauge...then pouring
in 5 more gallons...repeat) then the system was calibrated based on the
liquid that was used. If he used 100LL to calibrate the system and then now
the readings are various and unreliable then the question would be where are
the lowest point of the probes located...are they at the very lowest point
of the tank??? If so then there might be some water puddled there at the
very lowest part of the tank and if that just happens to be where the fuel
probe bottom is located then there might be some water puddled around the
very bottom of the fuel probe and this water is screwing around with the
resistance readings of the probes.
If there is no water in the fuel and lets say you have always run MOGAS and
the fuel probes were calibrated using MOGAS and this day you dump in 50
gallons of AVGAS then you could expect to see a difference in the
max/mid/low quantity indications of your gauges...once you have burned or
dumped out that fuel load and have refueled with MOGAS then the gauges would
read correctly because the liquid in the tanks is the correct resistance.
Cheers!!!
Bill Hunter
rick(at)beebe.org
PostPosted: Sat Apr 16, 2016 7:32 pm    Post subject: Capacitance fuel sensors Reply with quote
I presume the builder and the subsequent buyer (his son, actually)
wouldn't have let the plane go 14 years with wrong gauges. The rest of
his craftsmanship is too good for that.
Actually calibration is a lot simpler than that with this system.
There's an 'empty' pot that you adjust with no fuel in the tank until
the gauges (which are really just relabeled volt meters) read empty.
Then fill the tanks and adjust the "full" pot until the gauge reads
full. One of the needles wasn't pointing to full and I was able to
adjust that. But it often seems to drop to 1/4 and then go back up. I
guess I'm concluding that maybe the sender is broken and that inner wire
is moving places it shouldn't.
--Rick
wrmaxwell(at)bigpond.com
PostPosted: Sat Apr 16, 2016 11:05 pm    Post subject: Capacitance fuel sensors Reply with quote
Not quite so Bill. The probe is measuring capacitance, not resistance, hence the name.
On 17/04/2016 1:15 PM, William Hunter wrote:
[quote] [quote]--> AeroElectric-List message posted by: "William Hunter" <billhuntersemail(at)gmail.com> (billhuntersemail(at)gmail.com) A capacitance fuel probe is just a small metallic wire sticking down the center of a larger diameter metallic tube. Even if you run MOGAS today (or kerosene or water or vodka) it does not matter next week what happened today once the offending liquid is removed and the original liquid is installed in the tank. All the capacitance probes measure is the resistance between an inner conductor (wire) and an outer tube that is also a conductor because a given liquid will have a certain resistance between the outer conductor and the inner conductor and that resistance will change as the liquid in the gas tank rises up the probe(s) as you fill or empty the tank. Has your capacitance probes ever read correctly? If when building the airplane the builder was too cheap to buy 100LL and used MOGAS or water or beer to calibrate the fuel probes (pouring in 5 gallons at a time...looking at the reading on the fuel gauge...then pouring in 5 more gallons...repeat) then the system was calibrated based on the liquid that was used. If he used 100LL to calibrate the system and then now the readings are various and unreliable then the question would be where are the lowest point of the probes located...are they at the very lowest point of the tank??? If so then there might be some water puddled there at the very lowest part of the tank and if that just happens to be where the fuel probe bottom is located then there might be some water puddled around the very bottom of the fuel probe and this water is screwing around with the resistance readings of the probes. If there is no water in the fuel and lets say you have always run MOGAS and the fuel probes were calibrated using MOGAS and this day you dump in 50 gallons of AVGAS then you could expect to see a difference in the max/mid/low quantity indications of your gauges...once you have burned or dumped out that fuel load and have refueled with MOGAS then the gauges would read correctly because the liquid in the tanks is the correct resistance. . Cheers!!! Bill Hunter --
PostPosted: Sun Apr 17, 2016 4:04 am    Post subject: Capacitance fuel sensors Reply with quote
!!!DANG!!! My bad…I thought we were talking about “resistant-ance probes”… As Anna Rosanna Danna would say… “well…never mind”
You are right…I misread my Westberg MFG capacitance probes instruction manual…it does talk about the resistance values of the medium being measured…. “The fuel sender works by supplying a small amount of precise power to the outer aluminum tube of the probe and the amount of this power is induced into a second conductor inside the tube (and insulated from it) and it depends on the resistance values of the medium's separating the two conductors a microprocessor in the head of the probe measures the induced potential amplifies it and sends it to the gauge. As the amount of fuel in the probe decreases from burn off the amount of air increases does continuously changing the amount of power being induced.
Well I have learned…when I am trying to pee with the Big Dawgs on the Aeroelectric list I am bound to get some over spray sometimes….
Thanks for keeping me honest!!!
Bill Hunter
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Maxwell
Sent: Sunday, April 17, 2016 12:05 AM
Subject: Re: Re: Capacitance fuel sensors
--> AeroElectric-List message posted by: "William Hunter" <billhuntersemail(at)gmail.com> (billhuntersemail(at)gmail.com) A capacitance fuel probe is just a small metallic wire sticking down thecenter of a larger diameter metallic tube. Even if you run MOGAS today (or kerosene or water or vodka) it does notmatter next week what happened today once the offending liquid is removedand the original liquid is installed in the tank. All the capacitance probes measure is the resistance between an inner
5
6
7
8
9
5
6
7
8
9
3[quote]--
EQUIPMENT_FUEL_PROBE_Westberg_Capacitance.pdf
 Filename:  EQUIPMENT_FUEL_PROBE_Westberg_Capacitance.pdf
 Filesize:  219.99 KB
 Downloaded:  458 Time(s)
stephencliverichards(at)g
PostPosted: Sun Apr 17, 2016 5:15 am    Post subject: Capacitance fuel sensors Reply with quote
We did have a capacitance sensor not sure the make but the zero setting pot whent intermittent so reading kept varying so replaced with a resistor type.
Clive
From: William Hunter (billhuntersemail(at)gmail.com)
Sent: ‎17/‎04/‎2016 13:12
Subject: RE: AeroElectric-List: Re: Capacitance fuel sensors
Bill Hunter
5
6
7
8
9
5
6
7
8
9
3[quote]--
