billhuntersemail(at)gmail Guest
Posted: Wed Apr 06, 2016 8:32 am Post subject: What Avionics Master Switch To Buy??? |
Hi All,
First post!!!
I like Bob’s suggestion in Chapter 17 about using a E-BUS ALT FEED SWITCH in lieu of the traditional Avionics Master Relay…and I want one!!!
Since size matters it is important that I get the right one. The only units on my Avionics Master Bus are the following components:
EQUIPMENT AMP MANUFACTURES DATA SHEET INFO
G-650 COM 7.5 Comm Connector .45A continuous 5.66A Max
G-650 NAV 2 Nav Connector .6A continuous 1.16A Max
G-650 MAIN 3 Main Connector 1.6A continuous 2.8A Max
AUDIO 3 SL-15 0.350amp typ 1.5amp max
XPNDR 3 SV-XPNDR-261 0.4amp
SV-ADSB 3 SV-ADSB-470 0.2amp
With this stack of CBs, what switch should I buy? The Klixon 7270-1-25 Circuit Breaker Toggle Switch - 25 Amp is $150.00!!! (YIKES)
Any help is MOST APPREIATED!!!
Cheers!!!
Bill Hunter
