switches
bobnoffs
PostPosted: Sat Apr 02, 2016 1:51 am    Post subject: switches Reply with quote
i have 2 ecu's and 2 elec fuel pumps. my engine needs one of each to run.the system also never wants 2 of either running at the same time. i think there may be times when i want the master on but no power to either. i plan to use on-off-on switches. is there any reason i am not thinking of [wouldn't take much!] that i would want on-on switches instead?
 thanks again.
 bob noffs
ceengland7(at)gmail.com
PostPosted: Sat Apr 02, 2016 5:21 am    Post subject: switches Reply with quote
-------- Original message --------
Date:04/02/2016 5:49 AM (GMT-05:00)
Subject: AeroElectric-List: switches
 thanks again.
 bob noffs
The 1st thing I think of is that a mechanical failure of a single switch could cause loss of both components.
Like you, I like the idea of 'exclusive or' switching, but wouldn't want both pumps or ctls routed through the same switch.
rnjcurtis(at)charter.net
PostPosted: Sat Apr 02, 2016 5:26 am    Post subject: switches Reply with quote
thanks again.
bob noffs
           Just remember, as has been discussed many times on this forum, switches are prone to failure!!  DO NOT use one switch to select between two critical devices, such as ECU’s.
           I used 4 ea. SPST switches, 1 for each of the 2 ECU’s and 1 for each of the 2 fuel pumps.  This method does not keep you from turning on both ECU’s or pumps, but my system does not care if they are all on.  These switches are powered from the battery bus so therefore are always powered even when the master is off.
Roger
jmjones2000(at)mindspring
PostPosted: Sat Apr 02, 2016 5:45 am    Post subject: switches Reply with quote
I have the same setup that you do and I used a lever-lock on-off switch for each component. No accidental switch actuation in turbulence. You must pull out on the switch to turn it off.
If your system is an EFII system, it comes with an on-on ecu select switch already wired into the harness.
I have an independent power switch for each ecu, fuel pump, and coil pack. This allows me to have the master on without any of the efii system powered.
Justin
On Apr 2, 2016, at 06:24, Roger <rnjcurtis(at)charter.net (rnjcurtis(at)charter.net)> wrote:
thanks again.
bob noffs
Roger
PostPosted: Sat Apr 02, 2016 2:30 pm    Post subject: switches Reply with quote
Electrically dependent engine support is best
brought off the battery bus with EACH device
having its own, separate switch and circuit
protection.
Place 'paired' switches side-by-side so that
their proper positioning is obvious.
When you say "never" at the same time . . . what's
the hazard? Does the engine simply 'change voice',
stumble, or stop dead? THIS IS SOMETHING YOU NEED
TO KNOW. It affects your plan-b architecture and
contributes to your comfortable, competent operation
of the machine. When ever you read/hear 'never', ask
and understand the consequences.
As others have noted, interlocking paired systems
as a hedge against 'accidental' switch positioning
does not yield the best FEMA and probability for
success in all foreseeable failures. In 45 years
of slinging wire in systems on ultra-lights to Hawker
4000, I have used only ONE compliment of lever-lock
and covered switches on 4 installations . . .
[img]cid:.0[/img]
This was done on a system that blew the A## end of the airplane off
and threw out a parachute that made the airplane very difficult to fly
while offering a way to recover an un-flyable airplane.
In this case, lever-locks and covers had nothing to do with
prevention of accidental motion and everything to do with
encouraging focused attention on the action for the purpose
of mitigating an exceedingly stressful flight condition.
I humbly suggest that if anyone is worried about 'accidental'
positioning of controls in a GA aircraft, then your knowledge of
and confidence in the operation of the airplane needs some
attention. Here's a sad example of poor attention
to understanding that got some folks killed and cost a lot
of dollars better expended elsewhere . . .
http://tinyurl.com/nrm5k2r
The two guys up front in this airplane were not an
'accident looking for a place to happen' they were simply
unqualified to be in an airplane they did not understand.
They drove right into that crash . . .
It's a matter of mind set that focuses first on crafting
an elegant system with a confident outcome for a failure
mode effects analysis as the 'cake' . . . followed up with your
understanding of how it all works as the 'frosting'.
If you understand your machine there will be no 'accidents'
in the cockpit.
Further, statistics show that should you ever find yourself
with a very silent engine up front the overwhelming predominance
of root causes are empty fuel tanks . . .
 Filesize:  434.14 KB
 Viewed:  9025 Time(s)
bobnoffs
PostPosted: Wed Apr 06, 2016 7:09 am    Post subject: switches Reply with quote
since an earlier post of mine about my ''electric dependant engine'' i have decided to use 2 on-ff switches instead of one on-off-on to operate backup systems.because of the importance of the alternator as a backup would it be adviseable to use a 0n-0n switch for the alternator? if the alternator switch is not on it would light up a warning light on the panel? seems a more sure way to catch this than with the eis for voltage.
 another question......1'' seems to be a pretty standard spacing for toggles but what distance is generally accepted to separate horizontal rows?
 thanks, bob noffs
PostPosted: Wed Apr 06, 2016 9:11 am    Post subject: switches Reply with quote
           I assume that you have a “LOW VOLTAGE” indicator built into your electrical system           with an indicator on the panel.  If this is the case it will act as an alert that will tell you if the    alternator is not on, and you will not need another warning light.
           Roger
ARGOLDMAN(at)aol.com
PostPosted: Wed Apr 06, 2016 9:44 am    Post subject: switches Reply with quote
Donnknow if I would do that...
Usually a warning light is just that--, a warning about something that is a problem. If that light is on most of the time, your brain will probably ignore it and not see it when you may need it most.
Why not just set your backup regulator at a slightly lower voltage than your primary and then set a low voltage limit trigger on your efis at that voltage. If your main fails, your secondary goes to town, the lower voltage sets off the alarm and you are notified that something is happening, not that something is not happening which you don't want to happen anyway. Of course your indicator light may occasionally flash when your bus voltage temporarily decreases waiting for your primary to regain the voltage...
clear as electrical mud???
Rich
In a message dated 4/6/2016 8:10:55 A.M. Pacific Daylight Time, icubob(at)gmail.com writes:
thanks, bob noffs
PostPosted: Wed Apr 06, 2016 6:18 pm    Post subject: switches Reply with quote
1" works for finger convenience, though many switches will allow 3/4" spacing.
I'm trying to group by function, & add an extra 1/4-1/2" between functions. Ex: strobes, 1", position lights, then 1 1/4" to pitot heat.
Spaces make it easier to find a switch by 'feel'.
Keep anything that might cause an "oh s**t" reaction (ie: fuel pump off) well away from frequently used stuff, like flaps down.
Date:04/06/2016 11:07 AM (GMT-05:00)
 thanks, bob noffs
bobnoffs
PostPosted: Thu Apr 07, 2016 2:34 am    Post subject: switches Reply with quote
thanks guys. these switches are all in location of start key.
 i have thought about the ''oops''. mouser makes switch guards which lock the switch in any position for my back up systems.as a FYI some guards from aviation vendors always turn the switch off when the guard is closed.haven't decided on the guard thing yet.
 bob noffs
On Wed, Apr 6, 2016 at 9:16 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Subject: switches
 thanks, bob noffs
yellowduckduo(at)gmail.co
PostPosted: Thu Apr 07, 2016 3:38 am    Post subject: switches Reply with quote
I would not want a guard that hides the switch position. If a guard is
closed I want it to be confirmation of the switch position. Most
aviation guards do that and further they suggest that the switch is
important enough to not touch without thinking about it a moment. Too
many guarded switches actually destroys that little bit of psychological
protection.
Ken
<http://systems.as> a FYI some guards from aviation vendors always
guard thing yet.
bob noffs
PostPosted: Thu Apr 07, 2016 5:42 am    Post subject: switches Reply with quote
One of the most exciting parts of the build, for me, was the human factors engineering. Switch layout, type of switches, safety concerns with an electric dependent engine, and how pilots will interact with the system. Below is a picture of my final product.
As I mentioned before, all switches critical to the engine running are milspec lever-lock switches. I can't count the times during turbulence that I've reached for something on the panel and touched something else due to bouncing around. I don't to accidentally bump an engine switch off during flight due to turbulence (although any single switch would not shut it down. It would take the correct pair). It was an easy solution that I like, and I wouldn't change a thing.
Justin
On Apr 7, 2016, at 04:36, C&K <yellowduckduo(at)gmail.com> wrote:
I would not want a guard that hides the switch position. If a guard is closed I want it to be confirmation of the switch position. Most aviation guards do that and further they suggest that the switch is important enough to not touch without thinking about it a moment. Too many guarded switches actually destroys that little bit of psychological protection.
Ken
> i have thought about the ''oops''. mouser makes switch guards which lock the switch in any position for my back up systems.as <http://systems.as> a FYI some guards from aviation vendors always turn the switch off when the guard is closed.haven't decided on the guard thing yet.
> bob noffs
 Filesize:  447.29 KB
 Viewed:  8992 Time(s)
 Filesize:  370.32 KB
PostPosted: Thu Apr 07, 2016 9:53 am    Post subject: switches Reply with quote
At 06:36 AM 4/7/2016, you wrote:
--> AeroElectric-List message posted by: C&K <yellowduckduo(at)gmail.com>
I would not want a guard that hides the switch position. If a guard is closed I want it to be confirmation of the switch position. Most aviation guards do that and further they suggest that the switch is important enough to not touch without thinking about it a moment. Too many guarded switches actually destroys that little bit of psychological protection.\
Most off-the-shelf switch covers will force the
switch to one side when closed. Operating the switch
requires that the cover be opened before the switch
can be moved . . . and the cover must remain open.
Closing the cover forces the switch back.
You have to work pretty hard to find covers that
allow 'protection' in either switch position.
billp(at)wwpc.com
PostPosted: Thu Apr 07, 2016 11:23 am    Post subject: switches Reply with quote
There are good quality switches that have a locking feature that will lock the switch in either position. To change the switches position you have to pull the switch bat out to release the movement to change it's position. I have used these in places where I never want the switch to be moved accidentally. I've found them at Digikey. Here's an example:  http://www.digikey.com/product-detail/en/apem-inc/631H%2F22V/679-1212-ND/1280278
These don't use a switch cover to protect against accidental actuation, the protection is built into the mechanical design of the switch. A similar feature can be found in switches of various mounting styles, pole configurations and capacities.
Bill Putney - N5413K
--> AeroElectric-List message posted by: C&K <yellowduckduo(at)gmail.com> (yellowduckduo(at)gmail.com)
JOHN TIPTON
PostPosted: Thu Apr 07, 2016 11:38 am    Post subject: switches Reply with quote
You have to look no further than 'Steinair' for a selection of locking switches:
http://www.steinair.com/store.cfm?tlcatid=23
Regards:
----x--O--x----
On 7 Apr 2016, at 08:20 pm, Bill <billp(at)wwpc.com (billp(at)wwpc.com)> wrote:
There are good quality switches that have a locking feature that will lock the switch in either position. To change the switches position you have to pull the switch bat out to release the movement to change it's position. I have used these in places where I never want the switch to be moved accidentally. I've found them at Digikey. Here's an example: [/url][url=http://www.digikey.com/product-detail/en/apem-inc/631H%2F22V/679-1212-ND/1280278]http://www.digikey.com/product-detail/en/apem-inc/631H%2F22V/679-1212-ND/1280278
bobnoffs
PostPosted: Sat Apr 16, 2016 3:42 am    Post subject: switches Reply with quote
hi all,
 is there a correct way to orient battery and load on a switch when wiring?
 i am asking because of possible arcing in the switch if there is a wrong way.
 bob
PostPosted: Sun Apr 17, 2016 5:29 am    Post subject: switches Reply with quote
At 06:36 AM 4/16/2016, you wrote:
hi all,
 bob
No. See
http://tinyurl.com/zw2f7g3
http://tinyurl.com/jcmdelo
