ChrisM
Posted: Thu Mar 31, 2016 8:21 pm Post subject: D Sub Crimper Recommendation? |
Sounds like the crimp on coax connectors will work well. Possibly Mr Weir was speaking about the twist on variety.
Thank you for the tool suggestions! Extremely helpful.
Wondering if you have a favorite reasonably priced d sub crimper?
Chris M
_________________ ChrisM |
stein(at)steinair.com Guest
Posted: Fri Apr 01, 2016 6:30 am Post subject: D Sub Crimper Recommendation? |
Hi Chris,
There are two distinctly different crimpers, both work fine.
One is the “import” version of the tool with fixed positioners (either standard density or high density) which retails for around $40 and works just fine for several 10’s of thousands of pins before it wears out.
The second is the Mil Spec AFM-8 with replaceable positioners and retails for hundreds of dollars, but can be calibrated and virtually last for hundreds of thousands of crimps and more if maintained.
Stein
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chris Mullins
Sent: Thursday, March 31, 2016 11:19 PM
Subject: D Sub Crimper Recommendation?
Chris M
Posted: Fri Apr 01, 2016 6:52 am Post subject: D Sub Crimper Recommendation? |
At 11:19 PM 3/31/2016, you wrote:
| Quote: | Sounds like the crimp on coax connectors will work well. Possibly Mr Weir was speaking about the twist on variety.
Wondering if you have a favorite reasonably priced d sub crimper? |
Here'a one that is an excellent value
http://tinyurl.com/jqyr4sk
chaskuss(at)yahoo.com Guest
Posted: Fri Apr 01, 2016 2:01 pm Post subject: D Sub Crimper Recommendation? |
On Fri, 4/1/16, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
Subject: Re: D Sub Crimper Recommendation?
Date: Friday, April 1, 2016, 10:49 AM
about the twist
on variety.
crimper?
Will the tool you linked above also do machined high density D Sub pins?
Posted: Fri Apr 01, 2016 4:16 pm Post subject: D Sub Crimper Recommendation? |
This is problematic . . . if the pin
positioner indexes off the END of the pin,
then the quad-crimp will be in about the
right place.
[img]cid:.0[/img]
However, the fussier tools (read $high$) will index
of the largest leading shoulder. In that case, a
positioner set up for D20 might not even 'catch'
an HD22 . . . and the pin falls through.
Then there is the matter of crush depth for the
wire grip. The Eclipse tools I used to sell did put
an adequate crush on an HD22 pin . . . I could not
pull it off with ~5 pounds of force. The pins you
see above were applied with a tip-indexing positioner
in a Buchanan tool. Wire grip position is good . . .
but the HD22 pin is loose on the strands.
The short answer is try it. Look at were the crush
hits the wire barrel . . . it should be centered on
the paint stripes. Then hang a gallon milk
jug about 2/3 full of water on the wire and lift
ot with a pair of pliers on the pin. If the wire doesn't
move, you're good to go.
122.73 KB |
4192 Time(s) |
